[mpich-discuss] Mpich2: problems with communications
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Sep 17 11:36:37 CDT 2008
Looks like the two processes are not able to connect to each other. Is there
a firewall or something in the networking configuration on the two machines
that may prevent that. You can use the mpdcheck utility to diagnose the
problem. See Appendix A.2 of the installation guide.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of The Source
Sent: Wednesday, September 17, 2008 10:46 AM
Subject: Re: [mpich-discuss] Mpich2: problems with communications
cpi starts and writes the following:
Process 0 of 2 is on WARZONE
Process 1 of 2 is on F9Virtual64
Nothing more. It never exits. I didn't pass any parameters to cpi. Should I?
MPI_Bcast(&size, 1, MPI_INT, 0, MPI_COMM_WORLD) returns success, my program
then prints that it is about to call next broadcast, but that's it, next
broadcast never returns.
My second node is virtual Fedora 9 x86_64 (VMWare), running on server node
(real Fedora 9 x86_64). Could it be the problem?
Rajeev Thakur пишет:
Does the cpi example from the examples directory run?
Does this program fail after the very first broadcast, i.e.,
    if(MPI_Bcast(&size, 1, MPI_INT, 0, MPI_COMM_WORLD)!=MPI_SUCCESS)
Rajeev
-----Original Message-----
Sent: Wednesday, September 17, 2008 7:45 AM
Subject: [mpich-discuss] Mpich2: problems with communications
I'm using mpich2 1.0.7. I installed and configured it on 2
machines, started daemons.
The problems begin when I launch my program: first MPI_Bcast
succeeds, but the second one (or any other communication
function) hangs. Source code is attached.
Also when I call MPI_Bcast, second machine deamon prints the
following:
F9Virtual64_mpdman_1 (run282): invalid msg from lhs;
expecting ringsize
got: {}
Can anyone look at the code and tell me what's wrong?
#include <mpi.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <sys/time.h>
int main(int arg_c, char** arg_v)
    if(arg_c<2)
        printf("Input file not specified\n");
        return 0;
    if(MPI_Init(&arg_c, &arg_v)!=MPI_SUCCESS)
        printf("MPI initialization failed\n");
        return 0;
    int ProcNum, ProcRank;
    MPI_Comm_size(MPI_COMM_WORLD, &ProcNum);
    MPI_Comm_rank(MPI_COMM_WORLD, &ProcRank);
    int size;
    double e;
    double* A;
    double* b;
    double* x, *xprev;
    FILE* f=0;
    if(!ProcRank)
        f=fopen(arg_v[1], "r");
        if(!f)
            printf("Error opening input file\n");
            MPI_Finalize();
            return 0;
        fscanf(f, "%d", &size);
        printf("Enter desired accuracy\n");
        scanf("%lf", &e);
    if(!ProcRank)
        printf("Broadcasting matrix size\n");
        if(!ProcRank)
            printf("Failed to broadcast matrix size\n");
    if(!ProcRank)
        printf("Broadcasting accuracy\n");
    if(MPI_Bcast(&e, 1, MPI_DOUBLE, 0, MPI_COMM_WORLD)!=MPI_SUCCESS)
        if(!ProcRank)
            printf("Failed to broadcast accuracy\n");
    A=new double[size*size];
    b=new double[size];
    x=new double[size];
    xprev=new double[size];
    memset(x, 0, size*sizeof(double));
    memset(xprev, 0, size*sizeof(double));
    if(!ProcRank)
        for(int i=0; i<size; i++)
            for(int j=0; j<size; j++)
                fscanf(f, "%lf", &(A[i*size+j]));
            fscanf(f, "%lf", &(b[i]));
        fclose(f);
    if(!ProcRank)
        printf("Waiting all processes to be initialized\n");
    MPI_Barrier(MPI_COMM_WORLD);
    if(!ProcRank)
        printf("Broadcasting matrix\n");
    MPI_Bcast(A, size*size, MPI_DOUBLE, 0, MPI_COMM_WORLD);
    if(!ProcRank)
        printf("Broadcasting b\n");
    MPI_Bcast(b, size, MPI_DOUBLE, 0, MPI_COMM_WORLD);
    double cursum, totalsum;
    int fin, itercount=0;
    if(!ProcRank)
        printf("Starting calculation\n");
    struct timeval tv1, tv2;
    gettimeofday(&tv1, 0);
    do
        MPI_Bcast(xprev, size, MPI_DOUBLE, 0, MPI_COMM_WORLD);
        itercount++;
            int snum=(size)/ProcNum;
            cursum=0.0;
            totalsum=0.0;
            for(int n=ProcRank*snum;
n<((ProcRank==ProcNum-1)?(size):((ProcRank+1)*snum)); n++)
                if(n<=i-1)
                    cursum+=A[i*size+n]*x[n];
                else
                    cursum+=A[i*size+n]*xprev[n];
            MPI_Reduce(&cursum, &totalsum, 1, MPI_DOUBLE,
MPI_SUM, 0, MPI_COMM_WORLD);
            if(!ProcRank)
                x[i]=xprev[i]-1.0/A[i*size+i]*(totalsum-b[i]);
        if(!ProcRank)
            fin=1;
                if(fabs(x[i]-xprev[i])>e)
                    fin=0;
            if(!fin)
                memcpy(xprev, x, size*sizeof(double));
        MPI_Bcast(&fin, 1, MPI_INT, 0, MPI_COMM_WORLD);
    while(!fin);
    gettimeofday(&tv2, 0);
    if(!ProcRank)
        printf("Matrix A:\n");
                printf("%lf ", A[i*size+j]);
            printf("\n");
        printf("\n");
        printf("Line b:\n");
            printf("%lf ", b[i]);
        printf("\n");
        printf("Iteration number: %d\n", itercount);
        printf("Calculation time: %d microseconds\n",
(tv2.tv_sec-tv1.tv_sec)*1000000+(tv2.tv_usec-tv1.tv_usec));
        printf("Results: \n");
            printf("x%d=%lf\n", i+1, x[i]);
    delete [] A;
    delete [] b;
    delete [] x;
    delete [] xprev;
    MPI_Finalize();
    return 0;
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080917/1991bb53/attachment.htm>
