[mpich-discuss] MPICH2 on Windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Sep 12 09:27:17 CDT 2008
 Do you have windows firewall running on your machine ? You must turn the
windows firewall off (OR look into the MPICH2 windows developer's guide on
how to configure the windows firewall for MPICH2 - windows developer's
guide is available at
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=down
loads) before running your MPI application.
 Can you run cpi.exe (<MPICH2-INSTALL-DIR>\examples) provided with MPICH2
installation (mpiexec -n 2 cpi.exe)?
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Hisham Adel
Sent: Wednesday, September 10, 2008 5:41 PM
To: MPI; MPI_questions
Subject: [mpich-discuss] MPICH2 on Windows
Hi
I need help use MPICH2 on windows.
I have build a program and it work on LINUX I wrote it in C.
I want now o run it on Windows XP I Used VS2005 to compile the program and
when I try to run the program MPICH2 it give no response.
when I Break the task it give me the welcome screen.
"__0__ HISHAM
Command line: C:\Program Files\DeinoMPI\bin\program.exe
ERROR: Executable unable not start due to missing dlls: MSVCR80.DLL "
When I am compiling the code in VS2005 and run it through VS2005 it give
me the welcome screen then I give it the inputs but it stops cause of MPI
functions cause it needs mpiexec.
Also when I run it from cmd it gave me no response.
The run command from terminal
"mpiexec -n 1 program.exe"
Need help
Thanks in advance
Hisham Adel Hassan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080912/47872493/attachment.htm>
