[mpich-discuss] unable to get mpich2 1.0.7 working
    Kamaraju Kusumanchi
    kamaraju at gmail.com
    Tue Sep  9 20:25:30 CDT 2008
I am trying to compile mpich2 1.0.7 using gfortran 4.3.2, gcc 4.3.2.
First I compiled gcc 4.3.2, gfortran 4.3.2 from its source.
Then, I configured the mpich2 1.0.7's source code with
Configuring MPICH2 version 1.0.7 with '--enable-f77' '--enable-f90'
'--enable-cxx' '--prefix=/home6/raju/software/compiledLibs/mpich2_1.0.7_gcc_4.3.2_gfortran_4.3.2'
'CC=gcc' 'CXX=g++' 'F77=gfortran' 'F90=gfortran'
The config.log is attached in this email.
Then I compiled it using
make 2>&1 | tee make.log
Then I tried to run the tests with
make testing 2>&1 | tee make_testing.log
However the tests fail with the following errors
Processing directory info
Looking in ./f77/info/testlist
Processing directory spawn
Looking in ./f77/spawn/testlist
Processing directory io
Looking in ./f77/io/testlist
Unexpected output in iwriteatf: mpiexec_ank.mae.cornell.edu
(handle_sig_occurred 1122): job ending due to env var
MPIEXEC_TIMEOUT=180
Program iwriteatf exited without No Errors
Unexpected output in iwritef: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program iwritef exited without No Errors
Unexpected output in iwriteshf: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program iwriteshf exited without No Errors
Unexpected output in writef: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writef exited without No Errors
Unexpected output in writeatf: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeatf exited without No Errors
Unexpected output in writeallf: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeallf exited without No Errors
Unexpected output in writeshf: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeshf exited without No Errors
Unexpected output in writeordf: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeordf exited without No Errors
Unexpected output in writeatallf: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeatallf exited without No Errors
Unexpected output in writeatallbef: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeatallbef exited without No Errors
Unexpected output in writeallbef: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeallbef exited without No Errors
Unexpected output in writeordbef: mpiexec_ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeordbef exited without No Errors
Can someone please tell me what I am doing wrong?
I am attaching the configure.log, config.log, make.log,
make_testing.log for your reference.
$gcc -v
Using built-in specs.
Target: x86_64-unknown-linux-gnu
Configured with: /home6/raju/software/unZipped/gcc-4.3.2/configure
--prefix=/home6/raju/software/compiledSoftware/gcc_4.3.2_20080827
Thread model: posix
gcc version 4.3.2 (GCC)
$gfortran -v
Thread model: posix
$uname -a
Linux node1.ank.mae.cornell.edu 2.6.18-53.1.14.el5 #1 SMP Wed Mar 5
11:37:38 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
$cat /etc/redhat-release
CentOS release 5.2 (Final)
thanks
raju
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080909/274aa7e1/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080909/274aa7e1/attachment-0001.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080909/274aa7e1/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080909/274aa7e1/attachment-0003.bin>
