[mpich-discuss] MPI_Comm_connect and firewall
Rajeev Thakur
thakur at mcs.anl.gov
Tue Sep 9 09:16:13 CDT 2008
That is the so-called "business card" that is used to identify a process
in the ch3:sock channel in MPICH2. You can do a cut-and-paste if you
want to enter it manually.
Robert Kubrick wrote:
> Thanks. I don't understand why the port name has to be so long and
> complicate. This is what I have on my server machine:
> Processor 0 (19011, Receiver) initialized
> Processor 0 opened port
> tag#0$port#61162$description#192.168.2.1$ifname#192.168.2.1$
> Publishing port
> tag#0$port#61162$description#192.168.2.1$ifname#192.168.2.1$ as service
> myfriend-0
> Processor 0 waiting for connections on
> tag#0$port#61162$description#192.168.2.1$ifname#192.168.2.1$, service
> myfriend-0...
> So unless I use the name service through MPI_Lookup_name (which I doubt
> works on remote connections), I have to enter
> 'tag#0$port#61162$description#192.168.2.1$ifname#192.168.2.1$' on the
> client as the port name to connect to the MPI server.
> Or am I missing something?
> On Sep 9, 2008, at 4:40 AM, Rajeev Thakur wrote:
>> Try setting the environment variable MPICH_PORT_RANGE to min:max to
>> indicate the port range.
>>> I need to connect an MPI program to a server behind a firewall, using
>>> MPI_Comm_connect. How can I configure the IP port that MPI_Open_port
>>> should use on the server?
>>> So for port:
>>> tag#0$port#57718$description#192.168.2.1$ifname#192.168.2.1$
>>> How can I change 57718 to another port authorized for remote connection?
