[mpich-discuss] errors while running the test suite of mpich2
    Kamaraju Kusumanchi
    kamaraju at gmail.com
    Wed Oct 22 15:32:52 CDT 2008
What kind of functionality will I be loosing by disabling this option?
raju
On Wed, Oct 22, 2008 at 3:35 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> If you configure with --disable-aio, many of the I/O ones will go away. Some
> of the others may be timing out because you are writing to NFS, which is
> slow.
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
>> Kamaraju Kusumanchi
>> Sent: Wednesday, October 22, 2008 11:39 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] errors while running the test suite of mpich2
>> The cluster configuration is something like
>>                master
>>           ETHERNET SWITCH
>> node1  node2 .......... node16 node17
>>         INFINIBAND SWITCH
>> All the compilations have to be performed on the master node. All the
>> executions have to be performed on the slave nodes only.
>> I configured mpich2 1.0.7 (on the master node) using gfortran 4.3.2,
>> gcc 4.3.2 with the following command
>> ~/software/unZipped/mpich2-1.0.7/configure --enable-f77 --enable-f90
>> --prefix=/home6/raju/software/compiledLibs/mpich2_1.0.7_gcc_4.
> 3.2_gfortran_4.3.2
>> 2>&1 | tee configure.log
>> then I compiled the source code (on the master node) using the command
>> nohup make > make.log 2>&1 &
>> Then I installed the software using
>> nohup make install > install.log 2>&1 &
>> Next I logged into the slave node and performed installcheck using
>> mpd&
>> make installcheck 2>&1 | tee installcheck.log
>> After that, I ran the testsuite (on the slave node) using
>> make testing 2>&1 | tee make_testing.log
>> At this stage, I am getting errors such as
>> Looking in ./f77/pt2pt/testlist
>> Processing directory info
>> Looking in ./f77/info/testlist
>> Processing directory spawn
>> Looking in ./f77/spawn/testlist
>> Processing directory io
>> Looking in ./f77/io/testlist
>> Unexpected output in iwriteatf: mpiexec_node1.ank.mae.cornell.edu
>> (handle_sig_occurred 1122): job ending due to env var
>> MPIEXEC_TIMEOUT=180
>> Program iwriteatf exited without No Errors
>> Unexpected output in iwritef: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program iwritef exited without No Errors
>> Unexpected output in iwriteshf: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program iwriteshf exited without No Errors
>> Unexpected output in writef: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writef exited without No Errors
>> Unexpected output in writeatf: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeatf exited without No Errors
>> Unexpected output in writeallf: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeallf exited without No Errors
>> Unexpected output in writeshf: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeshf exited without No Errors
>> Unexpected output in writeordf: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeordf exited without No Errors
>> Unexpected output in writeatallf: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeatallf exited without No Errors
>> Unexpected output in writeatallbef: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeatallbef exited without No Errors
>> Unexpected output in writeallbef: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeallbef exited without No Errors
>> Unexpected output in writeordbef: mpiexec_node1.ank.mae.cornell.edu
>> MPIEXEC_TIMEOUT=180
>> Program writeordbef exited without No Errors
>> Processing directory rma
>> Looking in ./f77/rma/testlist
>> Processing directory init
>> Looking in ./f77/init/testlist
>> Processing directory attr
>> Looking in ./cxx/attr/testlist
>> Processing directory pt2pt
>> Looking in ./cxx/pt2pt/testlist
>> Failed to build bsend1cxx; make[3]: Entering directory
>> `/home6/raju/software/compileHere/mpich2-1.0.7/test/mpi/cxx/pt2pt'
>> /home6/raju/software/compiledLibs/mpich2_1.0.7_gcc_4.3.2_gfort
> ran_4.3.2/bin/mpicxx
>> -DHAVE_CONFIG_H -I.
>> -I/home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt
>> -I../../include
>> t/../../include
>>   -c
>> /home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt/
>> bsend1cxx.cxx
>> bsend1cxx.cxx:
>> In function 'int main(int, char**)':
>> bsend1cxx.cxx:81:
>> error: 'strcmp' was not declared in this scope
>> bsend1cxx.cxx:91:
>> make[3]: *** [bsend1cxx.o] Error 1
>> make[3]: Leaving directory
>> I am attaching all the log files for your reference. I have tried
>> mpich2 1.0.8rc1. I am getting similar errors when running the test
>> suite. Could someone please tell me how to fix these problems?
>> thanks
>> raju
