[mpich-discuss] errors while running the test suite of mpich2
Kamaraju Kusumanchi
kamaraju at gmail.com
Wed Oct 22 11:39:03 CDT 2008
The cluster configuration is something like
master
ETHERNET SWITCH
node1 node2 .......... node16 node17
INFINIBAND SWITCH
All the compilations have to be performed on the master node. All the
executions have to be performed on the slave nodes only.
I configured mpich2 1.0.7 (on the master node) using gfortran 4.3.2,
gcc 4.3.2 with the following command
~/software/unZipped/mpich2-1.0.7/configure --enable-f77 --enable-f90
--prefix=/home6/raju/software/compiledLibs/mpich2_1.0.7_gcc_4.3.2_gfortran_4.3.2
2>&1 | tee configure.log
then I compiled the source code (on the master node) using the command
nohup make > make.log 2>&1 &
Then I installed the software using
nohup make install > install.log 2>&1 &
Next I logged into the slave node and performed installcheck using
mpd&
make installcheck 2>&1 | tee installcheck.log
After that, I ran the testsuite (on the slave node) using
make testing 2>&1 | tee make_testing.log
At this stage, I am getting errors such as
Looking in ./f77/pt2pt/testlist
Processing directory info
Looking in ./f77/info/testlist
Processing directory spawn
Looking in ./f77/spawn/testlist
Processing directory io
Looking in ./f77/io/testlist
Unexpected output in iwriteatf: mpiexec_node1.ank.mae.cornell.edu
(handle_sig_occurred 1122): job ending due to env var
MPIEXEC_TIMEOUT=180
Program iwriteatf exited without No Errors
Unexpected output in iwritef: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program iwritef exited without No Errors
Unexpected output in iwriteshf: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program iwriteshf exited without No Errors
Unexpected output in writef: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writef exited without No Errors
Unexpected output in writeatf: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeatf exited without No Errors
Unexpected output in writeallf: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeallf exited without No Errors
Unexpected output in writeshf: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeshf exited without No Errors
Unexpected output in writeordf: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeordf exited without No Errors
Unexpected output in writeatallf: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeatallf exited without No Errors
Unexpected output in writeatallbef: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeatallbef exited without No Errors
Unexpected output in writeallbef: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeallbef exited without No Errors
Unexpected output in writeordbef: mpiexec_node1.ank.mae.cornell.edu
MPIEXEC_TIMEOUT=180
Program writeordbef exited without No Errors
Processing directory rma
Looking in ./f77/rma/testlist
Processing directory init
Looking in ./f77/init/testlist
Processing directory attr
Looking in ./cxx/attr/testlist
Processing directory pt2pt
Looking in ./cxx/pt2pt/testlist
Failed to build bsend1cxx; make[3]: Entering directory
`/home6/raju/software/compileHere/mpich2-1.0.7/test/mpi/cxx/pt2pt'
/home6/raju/software/compiledLibs/mpich2_1.0.7_gcc_4.3.2_gfortran_4.3.2/bin/mpicxx
-DHAVE_CONFIG_H -I.
-I/home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt
-I../../include
-I/home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt/../../include
-c /home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt/bsend1cxx.cxx
/home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt/bsend1cxx.cxx:
In function 'int main(int, char**)':
/home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt/bsend1cxx.cxx:81:
error: 'strcmp' was not declared in this scope
/home6/raju/software/unZipped/mpich2-1.0.7/test/mpi/cxx/pt2pt/bsend1cxx.cxx:91:
make[3]: *** [bsend1cxx.o] Error 1
make[3]: Leaving directory
I am attaching all the log files for your reference. I have tried
mpich2 1.0.8rc1. I am getting similar errors when running the test
suite. Could someone please tell me how to fix these problems?
thanks
raju
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081022/b836bef4/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081022/b836bef4/attachment-0001.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081022/b836bef4/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081022/b836bef4/attachment-0003.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081022/b836bef4/attachment-0004.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081022/b836bef4/attachment-0005.bin>
