[mpich-discuss] Race condition in smpd?
Dave Goodell
goodell at mcs.anl.gov
Fri Oct 24 09:56:35 CDT 2008
I believe you can prevent smpd from modifying the host file by
setting the following environment variable:
SMPD_OPTION_NO_DYNAMIC_HOSTS=1. Also, remove all lines from the
~/.smpd file except for the passphrase line.
-Dave
On Oct 24, 2008, at 9:44 AM, John Fettig wrote:
> I'm trying to get "tight integration" of mpich2 going with rocks/sge,
> and am encountering the following problem. When I launch the job on a
> couple of machines, everything works fine. In ~/.smpd, I have
> phrase=somephrase
> Here, the home directory is NFS shared between the compute nodes.
> However, if I launch on much more than 2 machines, it seems there is a
> race to write to this file which causes it to be truncated. This
> results in subsequent machines prompting for a phrase, and the job
> failing because they are waiting for user input.
> I have worked around this by assigning a phrase in the program that
> starts smpd for every job, however this is a hack and I would
> rather let
> users set their own phrase. Are you aware of such a problem?
> John
