[mpich-discuss] FW: Mpich2 test suite and related errors
Rajeev Thakur
thakur at mcs.anl.gov
Wed Oct 8 13:35:45 CDT 2008
rdwrord is an MPI-IO test. The problem is likely because the test directory
is on an NFS file system, and NFS is known to be problematic for MPI-IO. You
can either ignore errors from the I/O tests, or if you don't need MPI-IO
functionality, you can configure MPICH2 with --disable-romio, and the I/O
tests won't be run.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Rajeev Thakur
> Sent: Wednesday, October 08, 2008 10:23 AM
> To: mpich-discuss at mcs.anl.gov
> Cc: asekhar at dow.com
> Subject: [mpich-discuss] FW: Mpich2 test suite and related errors
> Subject: Mpich2 test suite and related errors
> Date: Wed, 8 Oct 2008 08:48:02 -0400
> From: "ThirumalaiswamySekhar, Arvind (A)" <asekhar at dow.com>
> To: <mpich-discuss at mcs.anl.gov>
> Hello
> I tried my first installation of mpi on a linux cluster and
> have been more
> or less successful with the examples. I am trying to
> establish the complete
> tests using the test suite. I have my source files installed
> in a location
> and the actual bin directory and command files located in a separate
> directory(used a prefix during configure). I have the bin
> directory shared
> across the nodes but not the source directory. I migrated the
> test directory
> to the shared location and tried "make testing". I get an
> error with the
> rdwrord and the following tests.
> It shows a timeout =3D180 and "unexpected error"
> Is this because of the migration of the test directory? Is
> there any way I
> could make testing on the bin directory without having to
> migrate the test
> directory?
> Sincerely
> Arvind
