[mpich-discuss] forrtl errors
    Christopher Tanner
    christopher.tanner at gatech.edu
    Tue Oct  7 15:43:02 CDT 2008
Gus / All -
I've NFS mounted the /home directory on all nodes. To ensure that the
permissions are correct and the NFS export mechanism is correct, I
ssh'ed to each node and made sure I could read and write files to the /
home/<user> directory. Is this sufficient to ensure that mpiexec can
read and read to the home directory?
I'm launching the process from the /home/<user> directory, where the
data files to be read/wrote are. The executable is in the NFS exported
directory /usr/local/bin.
Regarding the code itself making I/O errors, this is what I assumed
initially. Since it occurred on two different applications, I'm
assuming it's the MPI and not the application, but I could be wrong.
Does anything here stand out as bad?
I emailed out the output from my configure command -- hopefully this
may shed some light on the issue.
Chris Tanner
Space Systems Design Lab
Georgia Institute of Technology
On Oct 7, 2008, at 3:37 PM, Gus Correa wrote:
> Hi Christopher and list
> A number of different problems can generate I/O errors in a parallel
> environment.
> Some that I came across with (there are certainly more):
> 1) Permissions on the target directory. (Can you read and write
> there?)
> 2) If you are running on separate hosts (a cluster or a "NOW"),
> are you doing I?O to local disks/filesystems, or to a NFS mounted
> directory?
> 2.A) If local disks, are the presumed directories already created
> there, and with the right permissions?
> 2.B) If NFS, is the export/mount mechanism operating properly?
> 3)  On which directory do your processes start in each execution host?
> The same as in the host where you launch the mpiexec command or on a
> different directory? (See mpiexec -wdir option, assuming you are
> using the mpiexec that comes with MPICH2. There are other mpiexec
> commands, though.)
> 4) Code (Fortran code, I presume) that makes wrong assumptions about
> file status,.
> e.g. "open(fin,file='myfile',status=old)" but 'myfile' doesn't exist
> yet.
> Witting a very simple MPI test program that where each process opens/
> creates, writes, and closes,
> a different file may help you sort this out.
> Also, I wonder if your precompiled commercial applications are using
> the same MPICH2 that
> you configured, or some other MPI version.
> I hope this helps,
> Gus Correa
> Gustavo J. Ponce Correa, PhD - Email: gus at ldeo.columbia.edu
> Lamont-Doherty Earth Observatory - Columbia University
> P.O. Box 1000 [61 Route 9W] - Palisades, NY, 10964-8000 - USA
> Christopher Tanner wrote:
>> Hi All -
>> I am receiving the same errors in multiple applications when I try
>> to  run them over MPICH2. They all read:
>> forrtl: Input/output error
>> forrtl: No such file or directory
>> forrtl: severe ...
>> This doesn't happen when I try to run any tests (i.e. mpiexec ...
>> hostname), only whenever I run the applications. Additionally, it
>> happens with pre-compiled (i.e. commercial applications)
>> applications  as well as applications compiled on the machine (i.e.
>> open-source  applications). At first I thought it was something to
>> do with the  application, now I'm starting to think I've done
>> something wrong with  MPICH2. Below is the configure command I used:
>> ./configure --prefix=/usr/local/mpi/mpich2 --enable-f77 --enable-
>> f90 -- enable-cxx --enable-sharedlibs=gcc --enable-fast=defopt
>> CC=icc CFLAGS=- m64 CXX=icpc CXXFLAGS=-m64 F77=ifort FFLAGS=-m64
>> F90=ifort F90FLAGS=-m64
>> Anyone have any clues? Thanks!
>> Chris Tanner
