[mpich-discuss] [Error]Because the system lacked sufficient buffer space or because a queue was full (errno 10055)
    Seifer Lin
    seiferlin at gmail.com
    Mon Oct  6 02:43:45 CDT 2008
Hi Everyone:
I am using MPICH2 1.0.3 x64 on Windows XP x64 edition and got the following
message just after the start of mpiexec.
job aborted:
process: node: exit code: error message:
0: localhost: 13: Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(225)........: Initialization failed
MPID_Init(81).....................: channel initialization failed
MPIDI_CH3_Init(35)............:
MPIDI_CH3I_Progress_init(305):
MPIDU_Sock_listen(903)....: unable to create a socket
easy_create(173)...............: WSASocket failed, An operation on a socket
could
not be performed because the system lacked sufficient buffer space ort
because a
queue was full. (errno 10055)
If I try to restart the smpd:
The same error message is shown again.
After I reboot the system, the symptom disappears.
But after running several parallel tasks, the error message appears again.
Does anyone know what is the problem about?
best regards,
Seifer Lin
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081006/a5c1b6dc/attachment.htm>
