[mpich-discuss] mpdboot failure
    Cesar Covarrubias
    cesar at uci.edu
    Tue Nov 18 16:33:17 CST 2008
Rajeev,
Thanks for your reply.
If you look at the bottom of my first email, I provided the output of
mpdcheck -f mpd.hosts -ssh -v. Running mpdcheck -l on each node doesn't
return any errors.
Very Respectfully,
Cesar Covarrubias
On Tue, 2008-11-18 at 16:22 -0600, Rajeev Thakur wrote:
> Try running all steps of mpdcheck between i32-6 and i32-4 in both directions
> as described in Appendex A.2 of the installation guide.
> Rajeev
> > -----Original Message-----
> > From: mpich-discuss-bounces at mcs.anl.gov
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Cesar
> > Covarrubias
> > Sent: Tuesday, November 18, 2008 4:10 PM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: Re: [mpich-discuss] mpdboot failure
> > As a follow up, here is an example of the error message in
> > /var/log/messages:
> > Nov 18 14:08:53 bduc-i32-6 mpd: mpd starting; no mpdid yet
> > Nov 18 14:08:53 bduc-i32-6 mpd: mpd has mpdid=bduc-i32-6_37197
> > (port=37197)
> > Nov 18 14:08:53 bduc-i32-6 mpd: bduc-i32-6_37197 (connect_lhs 900):
> > failed to connect to lhs at bduc-i32-4 41311 Nov 18 14:08:53
> > bduc-i32-6 mpd: bduc-i32-6_37197 (enter_ring 855): lhs
> > connect failed Nov 18 14:08:53 bduc-i32-6 mpd:
> > bduc-i32-6_37197 (run 252): failed to enter ring Nov 18
> > 14:08:53 bduc-i32-6 mpd: mpd ending mpdid=bduc-i32-6_37197
> > (inside cleanup)
> > Very Respectfully,
> > Cesar Covarrubias
> > On Tue, 2008-11-18 at 11:14 -0800, Cesar Covarrubias wrote:
> > > Hello,
> > > We are still having trouble getting mpd running on a large
> > number of
> > > our nodes. The error we get is mpdboot_bduc-sched.nacs.uci.edu
> > > (handle_mpd_output 392): failed to handshake with mpd on
> > bduc-i32-6;
> > > recvd output={}. The problem is that it the node it chooses
> > to fail on
> > > is random. It is not always the same node. All nodes have the
> > > /etc/mpd.conf file chmod'ed to 600. mpd is not running on
> > any of the
> > > nodes. The mpdcheck returns no errors (as you can see by the output
> > > below). All the nodes are on a private subnet.
> > > Ideas as to why this is failing?
> > > Very Respectfully,
> > > Cesar Covarrubias
> > > -bash-3.2# mpdcheck -f mpd.hosts -ssh -v obtaining hostname via
> > > gethostname and getfqdn gethostname gives  bduc-sched.nacs.uci.edu
> > > getfqdn gives  bduc-sched.nacs.uci.edu checking out unqualified
> > > hostname; make sure is not "localhost", etc.
> > > checking out qualified hostname; make sure is not "localhost", etc.
> > > obtain IP addrs via qualified and unqualified hostnames;  make sure
> > > other than 127.0.0.1
> > > gethostbyname_ex:  ('bduc-sched.nacs.uci.edu', ['bduc-sched'],
> > > ['128.200.15.19'])
> > > ['128.200.15.19'])
> > > checking that IP addrs resolve to same host now do some
> > gethostbyaddr
> > > and gethostbyname_ex for machines in hosts filechecking
> > gethostbyXXX
> > > for unqualified bduc-i32-1
> > > gethostbyname_ex:  ('bduc-i32-1', [], ['192.168.0.10']) checking
> > > gethostbyXXX for qualified bduc-i32-1
> > > gethostbyXXX for unqualified bduc-i32-3
> > > gethostbyname_ex:  ('bduc-i32-3', [], ['192.168.0.12']) checking
> > > gethostbyXXX for qualified bduc-i32-3
> > > gethostbyXXX for unqualified bduc-i32-4
> > > gethostbyname_ex:  ('bduc-i32-4', [], ['192.168.0.13']) checking
> > > gethostbyXXX for qualified bduc-i32-4
> > > gethostbyXXX for unqualified bduc-i32-5
> > > gethostbyname_ex:  ('bduc-i32-5', [], ['192.168.0.14']) checking
> > > gethostbyXXX for qualified bduc-i32-5
> > > gethostbyXXX for unqualified bduc-i32-6
> > > gethostbyname_ex:  ('bduc-i32-6', [], ['192.168.0.15']) checking
> > > gethostbyXXX for qualified bduc-i32-6
> > > gethostbyXXX for unqualified bduc-i32-7
> > > gethostbyname_ex:  ('bduc-i32-7', [], ['192.168.0.16']) checking
> > > gethostbyXXX for qualified bduc-i32-7
> > > gethostbyXXX for unqualified bduc-i32-8
> > > gethostbyname_ex:  ('bduc-i32-8', [], ['192.168.0.17']) checking
> > > gethostbyXXX for qualified bduc-i32-8
> > > gethostbyXXX for unqualified bduc-i32-9
> > > gethostbyname_ex:  ('bduc-i32-9', [], ['192.168.0.18']) checking
> > > gethostbyXXX for qualified bduc-i32-9
> > > gethostbyXXX for unqualified bduc-i32-10
> > > gethostbyname_ex:  ('bduc-i32-10', [], ['192.168.0.19']) checking
> > > gethostbyXXX for qualified bduc-i32-10
> > > gethostbyXXX for unqualified bduc-i32-11
> > > gethostbyname_ex:  ('bduc-i32-11', [], ['192.168.0.20']) checking
> > > gethostbyXXX for qualified bduc-i32-11
> > > gethostbyXXX for unqualified bduc-i32-12
> > > gethostbyname_ex:  ('bduc-i32-12', [], ['192.168.0.21']) checking
> > > gethostbyXXX for qualified bduc-i32-12
> > > gethostbyXXX for unqualified bduc-i32-13
> > > gethostbyname_ex:  ('bduc-i32-13', [], ['192.168.0.22']) checking
> > > gethostbyXXX for qualified bduc-i32-13
> > > gethostbyXXX for unqualified bduc-i32-14
> > > gethostbyname_ex:  ('bduc-i32-14', [], ['192.168.0.23']) checking
> > > gethostbyXXX for qualified bduc-i32-14
> > > gethostbyXXX for unqualified bduc-i32-15
> > > gethostbyname_ex:  ('bduc-i32-15', [], ['192.168.0.24']) checking
> > > gethostbyXXX for qualified bduc-i32-15
> > > gethostbyXXX for unqualified bduc-i32-16
> > > gethostbyname_ex:  ('bduc-i32-16', [], ['192.168.0.25']) checking
> > > gethostbyXXX for qualified bduc-i32-16
> > > gethostbyXXX for unqualified bduc-i32-17
> > > gethostbyname_ex:  ('bduc-i32-17', [], ['192.168.0.26']) checking
> > > gethostbyXXX for qualified bduc-i32-17
> > > gethostbyXXX for unqualified bduc-i32-18
> > > gethostbyname_ex:  ('bduc-i32-18', [], ['192.168.0.27']) checking
> > > gethostbyXXX for qualified bduc-i32-18
> > > gethostbyXXX for unqualified bduc-i32-19
> > > gethostbyname_ex:  ('bduc-i32-19', [], ['192.168.0.28']) checking
> > > gethostbyXXX for qualified bduc-i32-19
> > > gethostbyXXX for unqualified bduc-i32-20
> > > gethostbyname_ex:  ('bduc-i32-20', [], ['192.168.0.29']) checking
> > > gethostbyXXX for qualified bduc-i32-20
> > > gethostbyXXX for unqualified bduc-i32-21
> > > gethostbyname_ex:  ('bduc-i32-21', [], ['192.168.0.30']) checking
> > > gethostbyXXX for qualified bduc-i32-21
> > > gethostbyXXX for unqualified bduc-i32-22
> > > gethostbyname_ex:  ('bduc-i32-22', [], ['192.168.0.31']) checking
> > > gethostbyXXX for qualified bduc-i32-22
> > > gethostbyXXX for unqualified bduc-i32-24
> > > gethostbyname_ex:  ('bduc-i32-24', [], ['192.168.0.33']) checking
> > > gethostbyXXX for qualified bduc-i32-24
> > > gethostbyXXX for unqualified bduc-i32-25
> > > gethostbyname_ex:  ('bduc-i32-25', [], ['192.168.0.34']) checking
> > > gethostbyXXX for qualified bduc-i32-25
> > > gethostbyXXX for unqualified bduc-i32-27
> > > gethostbyname_ex:  ('bduc-i32-27', [], ['192.168.0.36']) checking
> > > gethostbyXXX for qualified bduc-i32-27
> > > gethostbyXXX for unqualified bduc-i32-28
> > > gethostbyname_ex:  ('bduc-i32-28', [], ['192.168.0.37']) checking
> > > gethostbyXXX for qualified bduc-i32-28
> > > gethostbyXXX for unqualified bduc-i32-29
> > > gethostbyname_ex:  ('bduc-i32-29', [], ['192.168.0.38']) checking
> > > gethostbyXXX for qualified bduc-i32-29
> > > gethostbyXXX for unqualified bduc-i32-30
> > > gethostbyname_ex:  ('bduc-i32-30', [], ['192.168.0.39']) checking
> > > gethostbyXXX for qualified bduc-i32-30
> > > gethostbyXXX for unqualified bduc-i32-31
> > > gethostbyname_ex:  ('bduc-i32-31', [], ['192.168.0.40']) checking
> > > gethostbyXXX for qualified bduc-i32-31
> > > gethostbyXXX for unqualified bduc-i32-32
> > > gethostbyname_ex:  ('bduc-i32-32', [], ['192.168.0.41']) checking
> > > gethostbyXXX for qualified bduc-i32-32
> > > gethostbyXXX for unqualified bduc-i32-33
> > > gethostbyname_ex:  ('bduc-i32-33', [], ['192.168.0.42']) checking
> > > gethostbyXXX for qualified bduc-i32-33
> > > gethostbyXXX for unqualified bduc-i32-34
> > > gethostbyname_ex:  ('bduc-i32-34', [], ['192.168.0.43']) checking
> > > gethostbyXXX for qualified bduc-i32-34
> > > gethostbyXXX for unqualified bduc-i32-35
> > > gethostbyname_ex:  ('bduc-i32-35', [], ['192.168.0.44']) checking
> > > gethostbyXXX for qualified bduc-i32-35
> > > gethostbyXXX for unqualified bduc-i32-36
> > > gethostbyname_ex:  ('bduc-i32-36', [], ['192.168.0.45']) checking
> > > gethostbyXXX for qualified bduc-i32-36
> > > gethostbyXXX for unqualified bduc-i32-37
> > > gethostbyname_ex:  ('bduc-i32-37', [], ['192.168.0.46']) checking
> > > gethostbyXXX for qualified bduc-i32-37
> > > gethostbyXXX for unqualified bduc-i32-38
> > > gethostbyname_ex:  ('bduc-i32-38', [], ['192.168.0.47']) checking
> > > gethostbyXXX for qualified bduc-i32-38
> > > gethostbyXXX for unqualified bduc-i32-39
> > > gethostbyname_ex:  ('bduc-i32-39', [], ['192.168.0.48']) checking
> > > gethostbyXXX for qualified bduc-i32-39
> > > gethostbyXXX for unqualified bduc-i32-40
> > > gethostbyname_ex:  ('bduc-i32-40', [], ['192.168.0.49']) checking
> > > gethostbyXXX for qualified bduc-i32-40
> > > trying: ssh bduc-i32-1 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-3 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-4 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-5 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-6 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-7 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-8 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-9 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-10 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-11 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-12 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-13 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-14 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-15 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-16 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-17 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-18 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-19 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-20 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-21 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-22 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-24 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-25 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-27 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-28 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-29 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-30 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-31 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-32 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-33 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-34 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-35 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-36 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-37 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-38 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-39 -x -n /bin/echo hello
> > > trying: ssh bduc-i32-40 -x -n /bin/echo hello starting server:
> > > /sge62/mpich2/bin/mpdcheck.py -s starting client: ssh
> > bduc-i32-1 -x -n
> > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 43076
> > > starting server: /sge62/mpich2/bin/mpdcheck.py -s starting
> > client: ssh
> > > bduc-i32-3 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 38649 starting server:
> > bduc-i32-4 -x -n
> > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 40831
> > client: ssh
> > > bduc-i32-5 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 57153 starting server:
> > bduc-i32-6 -x -n
> > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 60407
> > client: ssh
> > > bduc-i32-7 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 52646 starting server:
> > bduc-i32-8 -x -n
> > > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47523
> > client: ssh
> > > bduc-i32-9 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 50172 starting server:
> > bduc-i32-10 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 51821
> > client: ssh
> > > bduc-i32-11 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 36082 starting server:
> > bduc-i32-12 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 57250
> > client: ssh
> > > bduc-i32-13 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 47474 starting server:
> > bduc-i32-14 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 51971
> > client: ssh
> > > bduc-i32-15 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 54481 starting server:
> > bduc-i32-16 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 49851
> > client: ssh
> > > bduc-i32-17 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 33898 starting server:
> > bduc-i32-18 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 56621
> > client: ssh
> > > bduc-i32-19 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 37119 starting server:
> > bduc-i32-20 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 38601
> > client: ssh
> > > bduc-i32-21 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 43570 starting server:
> > bduc-i32-22 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 42130
> > client: ssh
> > > bduc-i32-24 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 41582 starting server:
> > bduc-i32-25 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 50515
> > client: ssh
> > > bduc-i32-27 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 48864 starting server:
> > bduc-i32-28 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47361
> > client: ssh
> > > bduc-i32-29 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 44604 starting server:
> > bduc-i32-30 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 41417
> > client: ssh
> > > bduc-i32-31 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 48330 starting server:
> > bduc-i32-32 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47243
> > client: ssh
> > > bduc-i32-33 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 35428 starting server:
> > bduc-i32-34 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 59147
> > client: ssh
> > > bduc-i32-35 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 54136 starting server:
> > bduc-i32-36 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 56116
> > client: ssh
> > > bduc-i32-37 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 59475 starting server:
> > bduc-i32-38 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 52834
> > client: ssh
> > > bduc-i32-39 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > > bduc-sched.nacs.uci.edu 58080 starting server:
> > bduc-i32-40 -x
> > > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 57115
