[mpich-discuss] mpdboot failure
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Nov 18 16:22:28 CST 2008
Try running all steps of mpdcheck between i32-6 and i32-4 in both directions
as described in Appendex A.2 of the installation guide.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Cesar
> Covarrubias
> Sent: Tuesday, November 18, 2008 4:10 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpdboot failure
> As a follow up, here is an example of the error message in
> /var/log/messages:
> Nov 18 14:08:53 bduc-i32-6 mpd: mpd starting; no mpdid yet
> Nov 18 14:08:53 bduc-i32-6 mpd: mpd has mpdid=bduc-i32-6_37197
> (port=37197)
> Nov 18 14:08:53 bduc-i32-6 mpd: bduc-i32-6_37197 (connect_lhs 900):
> failed to connect to lhs at bduc-i32-4 41311 Nov 18 14:08:53
> bduc-i32-6 mpd: bduc-i32-6_37197 (enter_ring 855): lhs
> connect failed Nov 18 14:08:53 bduc-i32-6 mpd:
> bduc-i32-6_37197 (run 252): failed to enter ring Nov 18
> 14:08:53 bduc-i32-6 mpd: mpd ending mpdid=bduc-i32-6_37197
> (inside cleanup)
> Very Respectfully,
> Cesar Covarrubias
> On Tue, 2008-11-18 at 11:14 -0800, Cesar Covarrubias wrote:
> > Hello,
> > We are still having trouble getting mpd running on a large
> number of
> > our nodes. The error we get is mpdboot_bduc-sched.nacs.uci.edu
> > (handle_mpd_output 392): failed to handshake with mpd on
> bduc-i32-6;
> > recvd output={}. The problem is that it the node it chooses
> to fail on
> > is random. It is not always the same node. All nodes have the
> > /etc/mpd.conf file chmod'ed to 600. mpd is not running on
> any of the
> > nodes. The mpdcheck returns no errors (as you can see by the output
> > below). All the nodes are on a private subnet.
> > Ideas as to why this is failing?
> > Very Respectfully,
> > Cesar Covarrubias
> > -bash-3.2# mpdcheck -f mpd.hosts -ssh -v obtaining hostname via
> > gethostname and getfqdn gethostname gives  bduc-sched.nacs.uci.edu
> > getfqdn gives  bduc-sched.nacs.uci.edu checking out unqualified
> > hostname; make sure is not "localhost", etc.
> > checking out qualified hostname; make sure is not "localhost", etc.
> > obtain IP addrs via qualified and unqualified hostnames;  make sure
> > other than 127.0.0.1
> > gethostbyname_ex:  ('bduc-sched.nacs.uci.edu', ['bduc-sched'],
> > ['128.200.15.19'])
> > ['128.200.15.19'])
> > checking that IP addrs resolve to same host now do some
> gethostbyaddr
> > and gethostbyname_ex for machines in hosts filechecking
> gethostbyXXX
> > for unqualified bduc-i32-1
> > gethostbyname_ex:  ('bduc-i32-1', [], ['192.168.0.10']) checking
> > gethostbyXXX for qualified bduc-i32-1
> > gethostbyXXX for unqualified bduc-i32-3
> > gethostbyname_ex:  ('bduc-i32-3', [], ['192.168.0.12']) checking
> > gethostbyXXX for qualified bduc-i32-3
> > gethostbyXXX for unqualified bduc-i32-4
> > gethostbyname_ex:  ('bduc-i32-4', [], ['192.168.0.13']) checking
> > gethostbyXXX for qualified bduc-i32-4
> > gethostbyXXX for unqualified bduc-i32-5
> > gethostbyname_ex:  ('bduc-i32-5', [], ['192.168.0.14']) checking
> > gethostbyXXX for qualified bduc-i32-5
> > gethostbyXXX for unqualified bduc-i32-6
> > gethostbyname_ex:  ('bduc-i32-6', [], ['192.168.0.15']) checking
> > gethostbyXXX for qualified bduc-i32-6
> > gethostbyXXX for unqualified bduc-i32-7
> > gethostbyname_ex:  ('bduc-i32-7', [], ['192.168.0.16']) checking
> > gethostbyXXX for qualified bduc-i32-7
> > gethostbyXXX for unqualified bduc-i32-8
> > gethostbyname_ex:  ('bduc-i32-8', [], ['192.168.0.17']) checking
> > gethostbyXXX for qualified bduc-i32-8
> > gethostbyXXX for unqualified bduc-i32-9
> > gethostbyname_ex:  ('bduc-i32-9', [], ['192.168.0.18']) checking
> > gethostbyXXX for qualified bduc-i32-9
> > gethostbyXXX for unqualified bduc-i32-10
> > gethostbyname_ex:  ('bduc-i32-10', [], ['192.168.0.19']) checking
> > gethostbyXXX for qualified bduc-i32-10
> > gethostbyXXX for unqualified bduc-i32-11
> > gethostbyname_ex:  ('bduc-i32-11', [], ['192.168.0.20']) checking
> > gethostbyXXX for qualified bduc-i32-11
> > gethostbyXXX for unqualified bduc-i32-12
> > gethostbyname_ex:  ('bduc-i32-12', [], ['192.168.0.21']) checking
> > gethostbyXXX for qualified bduc-i32-12
> > gethostbyXXX for unqualified bduc-i32-13
> > gethostbyname_ex:  ('bduc-i32-13', [], ['192.168.0.22']) checking
> > gethostbyXXX for qualified bduc-i32-13
> > gethostbyXXX for unqualified bduc-i32-14
> > gethostbyname_ex:  ('bduc-i32-14', [], ['192.168.0.23']) checking
> > gethostbyXXX for qualified bduc-i32-14
> > gethostbyXXX for unqualified bduc-i32-15
> > gethostbyname_ex:  ('bduc-i32-15', [], ['192.168.0.24']) checking
> > gethostbyXXX for qualified bduc-i32-15
> > gethostbyXXX for unqualified bduc-i32-16
> > gethostbyname_ex:  ('bduc-i32-16', [], ['192.168.0.25']) checking
> > gethostbyXXX for qualified bduc-i32-16
> > gethostbyXXX for unqualified bduc-i32-17
> > gethostbyname_ex:  ('bduc-i32-17', [], ['192.168.0.26']) checking
> > gethostbyXXX for qualified bduc-i32-17
> > gethostbyXXX for unqualified bduc-i32-18
> > gethostbyname_ex:  ('bduc-i32-18', [], ['192.168.0.27']) checking
> > gethostbyXXX for qualified bduc-i32-18
> > gethostbyXXX for unqualified bduc-i32-19
> > gethostbyname_ex:  ('bduc-i32-19', [], ['192.168.0.28']) checking
> > gethostbyXXX for qualified bduc-i32-19
> > gethostbyXXX for unqualified bduc-i32-20
> > gethostbyname_ex:  ('bduc-i32-20', [], ['192.168.0.29']) checking
> > gethostbyXXX for qualified bduc-i32-20
> > gethostbyXXX for unqualified bduc-i32-21
> > gethostbyname_ex:  ('bduc-i32-21', [], ['192.168.0.30']) checking
> > gethostbyXXX for qualified bduc-i32-21
> > gethostbyXXX for unqualified bduc-i32-22
> > gethostbyname_ex:  ('bduc-i32-22', [], ['192.168.0.31']) checking
> > gethostbyXXX for qualified bduc-i32-22
> > gethostbyXXX for unqualified bduc-i32-24
> > gethostbyname_ex:  ('bduc-i32-24', [], ['192.168.0.33']) checking
> > gethostbyXXX for qualified bduc-i32-24
> > gethostbyXXX for unqualified bduc-i32-25
> > gethostbyname_ex:  ('bduc-i32-25', [], ['192.168.0.34']) checking
> > gethostbyXXX for qualified bduc-i32-25
> > gethostbyXXX for unqualified bduc-i32-27
> > gethostbyname_ex:  ('bduc-i32-27', [], ['192.168.0.36']) checking
> > gethostbyXXX for qualified bduc-i32-27
> > gethostbyXXX for unqualified bduc-i32-28
> > gethostbyname_ex:  ('bduc-i32-28', [], ['192.168.0.37']) checking
> > gethostbyXXX for qualified bduc-i32-28
> > gethostbyXXX for unqualified bduc-i32-29
> > gethostbyname_ex:  ('bduc-i32-29', [], ['192.168.0.38']) checking
> > gethostbyXXX for qualified bduc-i32-29
> > gethostbyXXX for unqualified bduc-i32-30
> > gethostbyname_ex:  ('bduc-i32-30', [], ['192.168.0.39']) checking
> > gethostbyXXX for qualified bduc-i32-30
> > gethostbyXXX for unqualified bduc-i32-31
> > gethostbyname_ex:  ('bduc-i32-31', [], ['192.168.0.40']) checking
> > gethostbyXXX for qualified bduc-i32-31
> > gethostbyXXX for unqualified bduc-i32-32
> > gethostbyname_ex:  ('bduc-i32-32', [], ['192.168.0.41']) checking
> > gethostbyXXX for qualified bduc-i32-32
> > gethostbyXXX for unqualified bduc-i32-33
> > gethostbyname_ex:  ('bduc-i32-33', [], ['192.168.0.42']) checking
> > gethostbyXXX for qualified bduc-i32-33
> > gethostbyXXX for unqualified bduc-i32-34
> > gethostbyname_ex:  ('bduc-i32-34', [], ['192.168.0.43']) checking
> > gethostbyXXX for qualified bduc-i32-34
> > gethostbyXXX for unqualified bduc-i32-35
> > gethostbyname_ex:  ('bduc-i32-35', [], ['192.168.0.44']) checking
> > gethostbyXXX for qualified bduc-i32-35
> > gethostbyXXX for unqualified bduc-i32-36
> > gethostbyname_ex:  ('bduc-i32-36', [], ['192.168.0.45']) checking
> > gethostbyXXX for qualified bduc-i32-36
> > gethostbyXXX for unqualified bduc-i32-37
> > gethostbyname_ex:  ('bduc-i32-37', [], ['192.168.0.46']) checking
> > gethostbyXXX for qualified bduc-i32-37
> > gethostbyXXX for unqualified bduc-i32-38
> > gethostbyname_ex:  ('bduc-i32-38', [], ['192.168.0.47']) checking
> > gethostbyXXX for qualified bduc-i32-38
> > gethostbyXXX for unqualified bduc-i32-39
> > gethostbyname_ex:  ('bduc-i32-39', [], ['192.168.0.48']) checking
> > gethostbyXXX for qualified bduc-i32-39
> > gethostbyXXX for unqualified bduc-i32-40
> > gethostbyname_ex:  ('bduc-i32-40', [], ['192.168.0.49']) checking
> > gethostbyXXX for qualified bduc-i32-40
> > trying: ssh bduc-i32-1 -x -n /bin/echo hello
> > trying: ssh bduc-i32-3 -x -n /bin/echo hello
> > trying: ssh bduc-i32-4 -x -n /bin/echo hello
> > trying: ssh bduc-i32-5 -x -n /bin/echo hello
> > trying: ssh bduc-i32-6 -x -n /bin/echo hello
> > trying: ssh bduc-i32-7 -x -n /bin/echo hello
> > trying: ssh bduc-i32-8 -x -n /bin/echo hello
> > trying: ssh bduc-i32-9 -x -n /bin/echo hello
> > trying: ssh bduc-i32-10 -x -n /bin/echo hello
> > trying: ssh bduc-i32-11 -x -n /bin/echo hello
> > trying: ssh bduc-i32-12 -x -n /bin/echo hello
> > trying: ssh bduc-i32-13 -x -n /bin/echo hello
> > trying: ssh bduc-i32-14 -x -n /bin/echo hello
> > trying: ssh bduc-i32-15 -x -n /bin/echo hello
> > trying: ssh bduc-i32-16 -x -n /bin/echo hello
> > trying: ssh bduc-i32-17 -x -n /bin/echo hello
> > trying: ssh bduc-i32-18 -x -n /bin/echo hello
> > trying: ssh bduc-i32-19 -x -n /bin/echo hello
> > trying: ssh bduc-i32-20 -x -n /bin/echo hello
> > trying: ssh bduc-i32-21 -x -n /bin/echo hello
> > trying: ssh bduc-i32-22 -x -n /bin/echo hello
> > trying: ssh bduc-i32-24 -x -n /bin/echo hello
> > trying: ssh bduc-i32-25 -x -n /bin/echo hello
> > trying: ssh bduc-i32-27 -x -n /bin/echo hello
> > trying: ssh bduc-i32-28 -x -n /bin/echo hello
> > trying: ssh bduc-i32-29 -x -n /bin/echo hello
> > trying: ssh bduc-i32-30 -x -n /bin/echo hello
> > trying: ssh bduc-i32-31 -x -n /bin/echo hello
> > trying: ssh bduc-i32-32 -x -n /bin/echo hello
> > trying: ssh bduc-i32-33 -x -n /bin/echo hello
> > trying: ssh bduc-i32-34 -x -n /bin/echo hello
> > trying: ssh bduc-i32-35 -x -n /bin/echo hello
> > trying: ssh bduc-i32-36 -x -n /bin/echo hello
> > trying: ssh bduc-i32-37 -x -n /bin/echo hello
> > trying: ssh bduc-i32-38 -x -n /bin/echo hello
> > trying: ssh bduc-i32-39 -x -n /bin/echo hello
> > trying: ssh bduc-i32-40 -x -n /bin/echo hello starting server:
> > /sge62/mpich2/bin/mpdcheck.py -s starting client: ssh
> bduc-i32-1 -x -n
> > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 43076
> > starting server: /sge62/mpich2/bin/mpdcheck.py -s starting
> client: ssh
> > bduc-i32-3 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 38649 starting server:
> bduc-i32-4 -x -n
> > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 40831
> client: ssh
> > bduc-i32-5 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 57153 starting server:
> bduc-i32-6 -x -n
> > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 60407
> client: ssh
> > bduc-i32-7 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 52646 starting server:
> bduc-i32-8 -x -n
> > /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47523
> client: ssh
> > bduc-i32-9 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 50172 starting server:
> bduc-i32-10 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 51821
> client: ssh
> > bduc-i32-11 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 36082 starting server:
> bduc-i32-12 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 57250
> client: ssh
> > bduc-i32-13 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 47474 starting server:
> bduc-i32-14 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 51971
> client: ssh
> > bduc-i32-15 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 54481 starting server:
> bduc-i32-16 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 49851
> client: ssh
> > bduc-i32-17 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 33898 starting server:
> bduc-i32-18 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 56621
> client: ssh
> > bduc-i32-19 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 37119 starting server:
> bduc-i32-20 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 38601
> client: ssh
> > bduc-i32-21 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 43570 starting server:
> bduc-i32-22 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 42130
> client: ssh
> > bduc-i32-24 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 41582 starting server:
> bduc-i32-25 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 50515
> client: ssh
> > bduc-i32-27 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 48864 starting server:
> bduc-i32-28 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47361
> client: ssh
> > bduc-i32-29 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 44604 starting server:
> bduc-i32-30 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 41417
> client: ssh
> > bduc-i32-31 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 48330 starting server:
> bduc-i32-32 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 47243
> client: ssh
> > bduc-i32-33 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 35428 starting server:
> bduc-i32-34 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 59147
> client: ssh
> > bduc-i32-35 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 54136 starting server:
> bduc-i32-36 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 56116
> client: ssh
> > bduc-i32-37 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 59475 starting server:
> bduc-i32-38 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 52834
> client: ssh
> > bduc-i32-39 -x -n /sge62/mpich2/bin/mpdcheck.py -c
> > bduc-sched.nacs.uci.edu 58080 starting server:
> bduc-i32-40 -x
> > -n /sge62/mpich2/bin/mpdcheck.py -c bduc-sched.nacs.uci.edu 57115
