[mpich-discuss] Disk IO on multi-core MPI?
Dorian Krause
ddkrause at uni-bonn.de
Thu Nov 13 13:57:04 CST 2008
Thomas Blom wrote:
> Hi,
> This post may belong somewhere else, but I'm having a hard time
> locating good information on disk i/o as it relates to MPI software
> running on multi-core machines.
> I'm in a position to influence what type of node configuration we use
> for a new cluster doing bioinformatic-type work == lots of disk I/O.
> It occurs to me that multiple MPI processes running on the same
> multicore node may not prove very effective if they are constantly
> invalidating each others' disk cache etc...
> I'm wondering about the idea of instead of a single disk for storage,
> using multiple disks (e.g. 1 per core) to avoid these kinds of
> collisions. Is this a common practice? Certainly it complicates the
> underlying code a little, since core N now needs to read/write a
> different disk than core M on the same machine.
> There must be well-written papers about this very issue out there, but
> I haven't found any yet.
> thanks,
> thomas blom, austin tx
If you talk about a whole cluster of multicore processors you will have
to use a shared filesystem anyway?! In this case I wouldn't matter
because disks aren't bound to nodes anymore. Depending on your
applications I would definitely prefer a parallel filesystem (PVFS,
Lustre, GPFS, ...) instead of e.g. NFS. It can make a huge difference!
Dorian
