[mpich-discuss] MPI_Alloc_mem: optimized memory usage
Dorian Krause
ddkrause at uni-bonn.de
Tue Nov 11 11:14:07 CST 2008
Rajeev Thakur wrote:
> Yes, it is useful for MPI-2 one-sided communication, but perhaps less useful
> for send-recv.
> Rajeev
What would be the advantage on commodity hardware? Can we do better than
malloc if the Interconnect doesn't support something like RDMA?
Dorian
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of James S Perrin
>> Sent: Monday, November 10, 2008 5:24 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] MPI_Alloc_mem: optimized memory usage
>> Thanks for the info Rajeev. Would this be something worth
>> looking at in
>> future releases in the nemesis channel as we run more systems
>> with more
>> and more cores per node?
>> Regards
>> James
>>> In the sshm channel (scalable shared memory), which is now
>> deprecated,
>>> Alloc_mem allocated shared memory for use in one-sided
>> communication. I
>>> believe in other cases at present, Alloc_mem just calls malloc.
>>> Rajeev
>> James S Perrin
>>>> Sent: Friday, November 07, 2008 11:55 AM
>>>> To: mpich
>>>> Subject: [mpich-discuss] MPI_Alloc_mem: optimized memory usage
>>>> Hi,
>>>> Are MPICH2 calls optimized for SMP/multi-core
>>>> architectures if I
>>>> allocate buffers using MPI_Alloc_mem()? I was reading the in
>>>> the MPI2.1
>>>> spec that MPI_Alloc_mem can be implemented to take advantage
>>>> of shared
>>>> memory pools when available meaning I can keep my code
>> portable and
>>>> clean. Presumably this would only be available in ch3:ssm
>> and nemesis
>>>> channels.
>>>> Regards
>>>> James
>> James S. Perrin
>> Visualization
>> Research Computing Services
>> Devonshire House, University Precinct
>> The University of Manchester
>> Oxford Road, Manchester, M13 9PL
>> t: +44 (0) 161 275 6945
>> e: james.perrin at manchester.ac.uk
>> w: www.manchester.ac.uk/researchcomputing
>> "The test of intellect is the refusal to belabour the obvious"
>> - Alfred Bester
