[mpich-discuss] MPI_Alloc_mem: optimized memory usage
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Nov 10 12:56:41 CST 2008
Yes, it is useful for MPI-2 one-sided communication, but perhaps less useful
for send-recv.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of James S Perrin
> Sent: Monday, November 10, 2008 5:24 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPI_Alloc_mem: optimized memory usage
> Thanks for the info Rajeev. Would this be something worth
> looking at in
> future releases in the nemesis channel as we run more systems
> with more
> and more cores per node?
> Regards
> James
> Rajeev Thakur wrote:
> > In the sshm channel (scalable shared memory), which is now
> deprecated,
> > Alloc_mem allocated shared memory for use in one-sided
> communication. I
> > believe in other cases at present, Alloc_mem just calls malloc.
> > Rajeev
> James S Perrin
> >> Sent: Friday, November 07, 2008 11:55 AM
> >> To: mpich
> >> Subject: [mpich-discuss] MPI_Alloc_mem: optimized memory usage
> >> Hi,
> >> 	Are MPICH2 calls optimized for SMP/multi-core
> >> architectures if I
> >> allocate buffers using MPI_Alloc_mem()? I was reading the in
> >> the MPI2.1
> >> spec that MPI_Alloc_mem can be implemented to take advantage
> >> of shared
> >> memory pools when available meaning I can keep my code
> portable and
> >> clean. Presumably this would only be available in ch3:ssm
> and nemesis
> >> channels.
> >> Regards
> >> James
>    James S. Perrin
>    Visualization
>    Research Computing Services
>    Devonshire House, University Precinct
>    The University of Manchester
>    Oxford Road, Manchester, M13 9PL
>    t: +44 (0) 161 275 6945
>    e: james.perrin at manchester.ac.uk
>    w: www.manchester.ac.uk/researchcomputing
>   "The test of intellect is the refusal to belabour the obvious"
>   - Alfred Bester
