[mpich-discuss] mpiexec and working directory
    Tiago Silva
    tsilva at coas.oregonstate.edu
    Fri Nov  7 12:26:18 CST 2008
So could that explain this behavior? I need to justify asking a very
busy sysadmin to get the daemons  on a 25 node cluster.
Tiago
Rajeev Thakur wrote:
> Oh, you are using SMPD. Can you try with the default MPD process manager?
> You have to build MPICH2 again for that.
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Tiago Silva
>> Sent: Friday, November 07, 2008 12:18 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] mpiexec and working directory
>> Thanks Rajeev, this shows the problem nicely:
>> [tsilva at admin1 work]$ /n1ge6/mpich2/smpd/bin/mpiexec -nopm
>> -ssh -l -n 2 pwd
>> /raid1/tsilva
>> /raid1/tsilva
>> -ssh -l -wdir
>> /tmp/ -n 2 pwd
>> /raid1/tsilva
>> /raid1/tsilva
>> [tsilva at admin1 work]$ ls runjob.err
>> runjob.err
>> -ssh -l -wdir
>> /tmp/ -n 2 ls -l runjob.err
>> ls: runjob.err: No such file or directory
>> Could this have anything to do with running mpiexec
>> deamonless (although
>> mpich was compiled with smpd)?
>> I noticed the same behavior with my regular setup of also deamonless
>> mpirun and mpich1. Only after calling mpi_init in the code did the
>> working dir change from being $home to the local dir.
>> Cheers,
>> Tiago
>>> Can you try these simple commands:
>>> mpiexec -l -n 2 pwd
>>>   ## shows if you execute in the dir you think you are in
>>> mpiexec -l -wdir /tmp -n 2 pwd
>>>   ## similar to above but shows you moved to /tmp
>>> mpiexec -l -n 2 ls -l some_filename
>>>   ## shows if some expected file really is in the working dir
>>>> Sent: Friday, November 07, 2008 1:26 AM
>>>> Quoting Rajeev Thakur <thakur at mcs.anl.gov>:
>>>>> If you cd to the directory containing the executable, say
>>>> a.out, and
>>>>> do "mpiexec -n 2 a.out" does it expect to find input
>> files in your
>>>>> home directory? That's odd.
>>>> That is correct. I have tried another simpler code and the
>>>> same thing happens.
>> Tiago Silva
>>>>>> Sent: Thursday, November 06, 2008 6:02 PM
>>>>>>> 1.0.3 is an ancient version of MPICH2. Try the latest
>>>>>> version, 1.0.8.
>>>>>> I will ask my systems administrator to do so.
>>>>>>> The parameters to mpiexec are not identical between MPICH-1 and
>>>>>>> MPICH2. Do mpiexec --help. Make sure you are calling
>>>>>> MPICH2's mpiexec, not MPICH-1's.
>>>>>> I am actually invoking mpiexec with its full path. Is there any
>>>>>> incorrect parameter on my mpiexec call?
>>>>>> I
>>>>>>> If your input files are in the same directory as the
>>>>>> executable, you
>>>>>>> should not need to specify anything.
>>>>>> But that is exactly the problem. The executable can't find
>>>> the input
>>>>>> files on the working directory.
