[mpich-discuss] MPI_File_set_view Error:	ADIOI_Count_contiguous_blocks
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri May 30 12:52:51 CDT 2008
> Uhmm, no idea, regular NFS PC hard drives? (All are blade clusters.)
You won't get much performance if you use NFS-mounted home directories.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Ingo Bojak
> Sent: Friday, May 30, 2008 11:23 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPI_File_set_view Error:
> Robert Latham wrote:
> > - How many processes are writing?
> All processes in the ring, i.e., typically no less than 8 and no more
> than about 40.
> > - About how much data is each process writing?
> Two scenarios:
> 1) in single state variable tracking about (20,000 to 70,000) doubles
> repeatedly, data evenly spread over nodes.
> 2) in checkpoint dumping about (20,000 to 70,000) x 70 doubles, once,
> also evenly spread
> > - Is the data noncontiguous in memory? file? both?
> The data is noncontiguous in the file (complicated write pattern set
> with fileview for every process). The dara is noncontiguous
> in memory,
> actually transpose to what would be needed for write out, so
> I currently
> transpose it into a contiguous write-out buffer for the
> writing with the
> file view.
> > - What's the interconnect for this machine?
> Good question, since it will run on several different
> clusters, and I'm
> not terribly  familiar with the details of all of them. I
> think Gigabit
> ethernet on one, and 20 Gb/s Infiniband on the other.
> > - How fast is your storage?
> Cheers,
> Ingo
