[mpich-discuss] IMB 3.1 with TOL 0 crashes on Allreduce
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri May 30 09:41:36 CDT 2008
  Any inputs on the other points that I mentioned in my prev email ?
Jayesh
-----Original Message-----
Sent: Friday, May 30, 2008 8:17 AM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] IMB 3.1 with TOL 0 crashes on Allreduce
Hi Jayesh,
    besides Allreduce, there is Reduce and Reduce_Scatter that fails.
Best regards,
    Calin
Jayesh Krishna wrote:
>  Hi,
>   I tried running the IMB 3.1 suite for allreduce on a single machine
> with upto 8 procs and did not get any errors.
> 1) Make sure that both node-1 & node-2 have the same data model (data
> type representation). Please note that MPICH2 currently does not
> support heterogeneous systems (wrt the data models used by the
> machines, for eg: you cannot run MPI procs across x86 and x64
> machines). If you need to run your program across a heterogeneous
> system please use MPICH1 instead.
> 2) Try running the benchmark on a single node/host (mpiexec -n 2
> imb-mpi1.exe allreduce) and let us know the results.
> 3) Are you able to run other tests in the IMB 3.1 suite ?
> Regards,
> Jayesh
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Calin Iaru
> Sent: Monday, May 26, 2008 5:50 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] IMB 3.1 with TOL 0 crashes on Allreduce
> The problem is that the latest mpich2 in combination with IMB 3.1
> generates a data corruption error when running on 2 nodes. IMB was
> compiled with the CHECK flag and TOL set to 0 inside IMB_declare.h. I
> am not sure if this is a transport error or a verification error; it
> could be that the problem lies in the application code.
> E:\Program Files\MPICH2\bin>mpiexec.exe -hosts 2 node-1 node-2
> \\node-1\e$\imb-mpi1.exe allreduce
> #    Intel (R) MPI Benchmark Suite V3.1, MPI-1 part
> # Date                  : Fri May 23 14:44:12 2008
> # Machine               : x86 Family 15 Model 4 Stepping 1, GenuineIntel
> # System                : Windows 2003
> # Release               : 5.2.3790
> # Version               : Service Pack 1
> # MPI Version           : 2.0
> # MPI Thread Environment: MPI_THREAD_SINGLE
> # Calling sequence was:
> # \\node-1\e$\imb-mpi1.exe allreduce
> # Minimum message length in bytes:   0
> # Maximum message length in bytes:   4194304
> # MPI_Datatype                   :   MPI_BYTE
> # MPI_Datatype for reductions    :   MPI_FLOAT
> # MPI_Op                         :   MPI_SUM
> # List of Benchmarks to run:
> # Allreduce
> # Benchmarking Allreduce
> # #processes = 2
>        #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]
> defects
>             0         1000         0.51         0.52
> 0.51         0.00
>             4         1000        80.30        80.35
> 80.33         0.00
> 1: Error Allreduce, size = 8, sample #0 Process 1: Got invalid buffer:
> Buffer entry: 2.300000
> 0: Error Allreduce, size = 8, sample #0 Process 0: Got invalid buffer:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080530/2127151b/attachment.htm>
