[mpich-discuss] IMB 3.1 with TOL 0 crashes on Allreduce
Calin Iaru
calin at dolphinics.com
Fri May 30 08:16:54 CDT 2008
Hi Jayesh,
besides Allreduce, there is Reduce and Reduce_Scatter that fails.
Best regards,
Calin
Jayesh Krishna wrote:
> Hi,
> I tried running the IMB 3.1 suite for allreduce on a single machine
> with upto 8 procs and did not get any errors.
> 1) Make sure that both node-1 & node-2 have the same data model (data
> type representation). Please note that MPICH2 currently does not
> support heterogeneous systems (wrt the data models used by the
> machines, for eg: you cannot run MPI procs across x86 and x64
> machines). If you need to run your program across a heterogeneous
> system please use MPICH1 instead.
> 2) Try running the benchmark on a single node/host (mpiexec -n 2
> imb-mpi1.exe allreduce) and let us know the results.
> 3) Are you able to run other tests in the IMB 3.1 suite ?
> Regards,
> Jayesh
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Calin Iaru
> Sent: Monday, May 26, 2008 5:50 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] IMB 3.1 with TOL 0 crashes on Allreduce
> The problem is that the latest mpich2 in combination with IMB 3.1
> generates a data corruption error when running on 2 nodes. IMB was
> compiled with the CHECK flag and TOL set to 0 inside IMB_declare.h. I
> am not sure if this is a transport error or a verification error; it
> could be that the problem lies in the application code.
> E:\Program Files\MPICH2\bin>mpiexec.exe -hosts 2 node-1 node-2
> \\node-1\e$\imb-mpi1.exe allreduce
> # Intel (R) MPI Benchmark Suite V3.1, MPI-1 part
> # Date : Fri May 23 14:44:12 2008
> # Machine : x86 Family 15 Model 4 Stepping 1, GenuineIntel
> # System : Windows 2003
> # Release : 5.2.3790
> # Version : Service Pack 1
> # MPI Version : 2.0
> # MPI Thread Environment: MPI_THREAD_SINGLE
> # Calling sequence was:
> # \\node-1\e$\imb-mpi1.exe allreduce
> # Minimum message length in bytes: 0
> # Maximum message length in bytes: 4194304
> # MPI_Datatype : MPI_BYTE
> # MPI_Datatype for reductions : MPI_FLOAT
> # MPI_Op : MPI_SUM
> # List of Benchmarks to run:
> # Allreduce
> # Benchmarking Allreduce
> # #processes = 2
> #bytes #repetitions t_min[usec] t_max[usec] t_avg[usec]
> defects
> 0 1000 0.51 0.52
> 0.51 0.00
> 4 1000 80.30 80.35
> 80.33 0.00
> 1: Error Allreduce, size = 8, sample #0
> Process 1: Got invalid buffer:
> Buffer entry: 2.300000
> 0: Error Allreduce, size = 8, sample #0
> Process 0: Got invalid buffer:
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080530/f56f993d/attachment.txt>
