[mpich-discuss] uninitialized MPI_request in ad_write_coll.c and ad_rea_coll.c
Wei-keng Liao
wkliao at ece.northwestern.edu
Sat May 10 23:17:03 CDT 2008
Please ignore my earlier post. There is nothing wrong with these 2 files.
Wei-keng
On Sat, 10 May 2008, Wei-keng Liao wrote:
> File mpich2-1.0.7/src/mpi/romio/adio/common/ad_write_coll.c, lines 666 and
> 671, array requests[] are allocated but not initialized. Since not all of
> the requests[] elements will be used by MPI_Irecv() and MPI_Isend(), it is
> not safe to use the entire requests[] in MPI_Testall() or MPI_Waitall()
> from lines 751 to 761. Maybe this is why these is a #ifdef NEEDS_MPI_TEST
> in line 747?
> The same problem happens in ad_read_coll.c
> The fix would be to initialize all elements to MPI_REQUEST_NULL.
> Otherwise, one must keep track the number of requests posted.
> Wei-keng
