[mpich-discuss] uninitialized MPI_request in ad_write_coll.c and ad_rea_coll.c
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Sat May 10 18:15:21 CDT 2008
File mpich2-1.0.7/src/mpi/romio/adio/common/ad_write_coll.c, lines 666 and
671, array requests[] are allocated but not initialized. Since not all of
the requests[] elements will be used by MPI_Irecv() and MPI_Isend(), it is
not safe to use the entire requests[] in MPI_Testall() or MPI_Waitall()
from lines 751 to 761. Maybe this is why these is a #ifdef NEEDS_MPI_TEST
in line 747?
The same problem happens in ad_read_coll.c
The fix would be to initialize all elements to MPI_REQUEST_NULL.
Otherwise, one must keep track the number of requests posted.
Wei-keng
