[mpich-discuss] Debugging
Jayesh Krishna
jayesh at mcs.anl.gov
Fri May 2 09:12:09 CDT 2008
The problem that you see might not be related to building debug version
of your code (It could some race condition bug which manifests in debug
version - due to the compiler-added code).
Valgrind should help.
I would also recommend that you turn on the "run time error checking"
(esp "Check Array and String bounds") when compiling your program
("Configuration properties" --> Fortran --> Run-time --> *).
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Gib Bogle
Sent: Friday, May 02, 2008 12:45 AM
Subject: [mpich-discuss] Debugging
Should I expect to be able to build an Intel Fortran debug executable on
Windows? When I do this with a program that runs in the release version,
the debug version fails with an access violation.
Also, should I be able to compile with lower optimization than /O3? This
same program (release
version) runs with /O3 or /O2 but when it is built with /O1 an array
subscript goes out of bounds.
Would valgrind be helpful?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080502/1be78864/attachment.htm>
