[mpich-discuss] Scalability of Intel quad core (Harpertown) cluster
    Hee Il Kim
    heeilkim at gmail.com
    Mon Mar 31 14:39:06 CDT 2008
Thanks Scott,
I'm eager to try Open-MX. I'm using Netgear GSM7224 switch which supports
flow control ( IEEE 802.3x Flow Control) and jumbo frame. I don't understand
the interoperability. I assume it doesn't require at the moment.
Hee Il
2008/3/31, Scott Atchley <atchley at myri.com>:
> On Mar 28, 2008, at 1:50 AM, Hee Il Kim wrote:
> > - If the gigabit network was the cause, could it be improved with
> > Open-MX?
> Hi Kim,
> Depending on your Ethernet switch, Open-MX should be able to lower
> your latency and reduce your CPU usage. I see about 10.5 us
> internally using the e1000 driver with interrupt coalescing turned
> off, others report that they have seen as low as 6.5 us (I do not
> know what NICs they used or if it the machines were switched or back-
> to-back).
> To use Open-MX, your switch must support flow control for send and
> receive (some don't) and jumbo frames. If you need interoperability
> with native MX over Ethernet (some hosts with Myri-10G NICs connected
> to an Ethernet switch, some hosts with non-Myricom NICs), then your
> switch must handle at least 4 KB frames. If you do not need
> interoperability, then you can use 8 or 9 KB frames and possibly see
> slightly better performance (fewer interrupts).
> Brice released version 0.4.0 which has working interoperability with
> native MX and is nearly feature complete. See http://www.open-mx.org
> for the status and source code.
> Scott
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080401/c1449f43/attachment.htm>
