[mpich-discuss] mpdtrace cannot connect (cygwin & mpd),      previous smpd remnants?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Mar 31 09:07:39 CDT 2008
  Is your windows firewall turned on ? (If yes, 1. Stop any instances of mpd
running 2. Stop firewall 3.Try running "mpd&" & "mpiexec -n 1
/bin/hostname".)
  Can you see mpd running in the windows Task Manager ?
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Ingo Bojak
Sent: Monday, March 31, 2008 8:55 AM
Subject: Re: [mpich-discuss] mpdtrace cannot connect (cygwin & mpd),
Ingo Bojak wrote:
> After a complete wipe (make distclean, deleting source, bin, and build
> directory) I have build it  all from scratch. I am using the latest
> stable version, I'm running configure/make under cygwin, and "which"
> points to the right files (path is set) after, .mpd.conf is there. I
> get *exactly* the same problems reported previously. mpd starts up,
> but is not recognized by mpdtrace?!
Further detail:
mpdcheck -s
in one cygwin window, plus
mpdcheck -c computername portnumber
in another cygwin window actually produce the output as shown in the
installation guide
http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-d
oc-install.pdf
in Appendix A.1.1., page 28 bottom, page 29 top. It's just mpdtrace and also
things like mpiexec -n 1 /bin/hostname which do not work and bring back the
response that mpd cannot be reached.
So I figure it's not a network / port problem?
Cheers,
Ingo
