[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Tue Mar 25 10:34:40 CDT 2008
Any suggestions ?
On 3/24/08, Krishna Chaitanya <kris.c1986 at gmail.com> wrote:
> That answers a lot of my questions.
> Sticking to MPI_Init for this discussion, the function is defined at two
> places.So,there will be a reference to MPI_Init in lmpich and also a
> reference in lmpe. But, how is it that when an MPI application is being
> compiled, mpicc doesnt complain that there were two references to MPI_Init?
> What exactly has been done to solve this?
> I am actually facing this problem with the PERUSE function that i have
> defined at :
> 1 > /src/peruse/peruse.c and
> 2 > src/mpe2/src/wrappers/src/log_mpi_core.c.
> The first one goes into lmpich and the second one is a part of lmpe.
> However, when I compile my MPI program, I get the following message :
> /home/kc/mpich-install//lib/libmpich.a(peruse.o): In function
> `PERUSE_TRACE_COMM_EVENT':
> /home/kc/mpich-src/src/peruse/peruse.c:324: multiple definition of
> /home/kc/mpich-install//lib/liblmpe.a(log_mpi_core.o):/home/kc/mpich-src/src/mpe2/src/wrappers/src/log_mpi_core.c:6830:
> first defined here
> collect2: ld returned 1 exit status
> Thanks for your time,
> Krishna Chaitanya K
> On Mon, Mar 24, 2008 at 10:22 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > On Mon, 24 Mar 2008, Krishna Chaitanya wrote:
> > > Sorry for re-posting.
> > >> I took a look at the documentation at src/util/multichannel/mpi.c
> > > Guess this is only for windows.
> > > It would be of great help if someone could point me to the
> > > function that takes care of mapping MPI_Init to its wrapper, defined in
> > > src/mpe2/src/wrappers/src/log_mpi_core.c, when the library is compiled
> > with
> > > the --enable-mpe switch., instead of the function defined in
> > > src/mpi/init/init.c
> > The function in src/mpi/init/init.c is defined when linked with -lmpich,
> > i.e. mpicc. The functions in log_mpi_core.c is defined when linked with
> > "mpicc -mpe=mpilog". Try do "mpicc .... -show" will show you what
> > libraries and their link order.
> > A.Chan
> > > Krishna Chaitanya K
> > > On Sun, Mar 23, 2008 at 2:29 PM, Krishna Chaitanya <kris.c1986 at gmail.com
> > > wrote:
> > >>> See section "CUSTOMIZING LOGFILES" in mpich2-xxx/src/mpe2/README.
> > >> Correct me if I am wrong :
> > >> Since I am dealing with PERUSE events, whenever such an event occurs, a
> > >> PERUSE function, defined in <mpich-dir>/src/peruse/peruse.c, is invoked
> > by
> > >> the MPI library. I am trying to get this event displayed in the
> > jumpshot
> > >> output. For this to be done, I need to define a wrapper function which
> > gets
> > >> invoked when a PERUSE event occurs, to log the event and then to call
> > the
> > >> actuall peruse function, which is similar to the way the wrapper
> > function at
> > >> log_mpi_core.c is called, when MPI_Init is called.
> > >> Could you please clarify on the dynamic mapping?
> > >> I took a look at the documentation at src/util/multichannel/mpi.c. I
> > >> think, I understood what is going on in LoadFunctions() and the way the
> > >> function pointers are assigned addresses depending the dll that is
> > being
> > >> used.
> > >> Krishna Chaitanya K
> > >> On Sun, Mar 23, 2008 at 12:59 PM, Anthony Chan <chan at mcs.anl.gov>
> > >>> You don't need to modify MPE libraries.
> > >>> A.Chan
> > >>> On Sun, 23 Mar 2008, Krishna Chaitanya wrote:
> > >>>> I have modified the mpe library to log the events that I am
> > interested
> > >>> in
> > >>>> monitoring. But, I am bit hazy about how a function like MPI_Init is
> > >>>> actually linked to the MPI_Init routine in the file log_mpi_core.c
> > >>> when we
> > >>>> compile the MPI application with the -mpe=mpilog switch. Could
> > someone
> > >>> point
> > >>>> me to the routine that takes care of such a mapping?
> > >>>> Thanks,
> > >>>> Krishna Chaitanya K
> > >>>> On Sat, Mar 22, 2008 at 3:01 AM, Krishna Chaitanya <
> > >>>> wrote:
> > >>>>> Thanks a lot. I installed the latest jdk version and I am now able
> > to
> > >>> look
> > >>>>> at the jumpshot output.
> > >>>>> Krishna Chaitanya K
> > >>>>> On Sat, Mar 22, 2008 at 1:45 AM, Anthony Chan <chan at mcs.anl.gov>
> > >>> wrote:
> > >>>>>> The error that you showed earlier does not suggest the problem is
> > >>> with
> > >>>>>> running jumpshot on your machine with limited memory. If your
> > clog2
> > >>>>>> file
> > >>>>>> isn't too bad, send it to me.
> > >>>>>> On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> > >>>>>>> I resolved that issue.
> > >>>>>>> My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree)
> > >>> hangs
> > >>>>>> each
> > >>>>>>> time I launch jumpshot with the slogfile. Since this is an
> > >>> independent
> > >>>>>>> project, I am constrained when it comes to the availability of
> > >>>>>> machines.
> > >>>>>>> Would you recommend that I give it a try on a 64bit AMD, 512MB
> > RAM?
> > >>>>>> Will
> > >>>>>>> have to start from installing linux on this machine. Is it worth
> > >>> the
> > >>>>>> effort
> > >>>>>>> ?) If it requires higher configuration, would you please suggest a
> > >>>>>> lighter
> > >>>>>>> graphical tool that I can use to present the occurrence of events
> > >>> and
> > >>>>>> the
> > >>>>>>> corresponding times?
> > >>>>>>> Thanks,
> > >>>>>>> Krishna Chaitanya K
> > >>>>>>> On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov>
> > >>>>>>>>> The file block pointer to the Tree Directory is NOT
> > initialized!,
> > >>>>>> can't
> > >>>>>>>> read
> > >>>>>>>>> it.
> > >>>>>>>> That means the slog2 file isn't generated completely. Something
> > >>> went
> > >>>>>>>> wrong in the convertion process (assuming your clog2 file is
> > >>>>>> complete).
> > >>>>>>>> If your MPI program doesn't finish MPI_Finalize normally, your
> > >>> clog2
> > >>>>>>>> file will be incomplete.
> > >>>>>>>>> IS there any environment variable that needs to be
> > >>>>>> initialsed?
> > >>>>>>>> Nothing needs to be initialized by hand.
> > >>>>>>>> A.Chan
> > >>>>>>>>> Thanks,
> > >>>>>>>>> Krishna Chaitanya K
> > >>>>>>>>> On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <
> > >>> goodell at mcs.anl.gov>
> > >>>>>>>> wrote:
> > >>>>>>>>>> It's pretty hard to debug this issue via email. However, you
> > >>> could
> > >>>>>>>>>> try running valgrind on your modified MPICH2 to see if any
> > >>> obvious
> > >>>>>>>>>> bugs pop out. When you do, make sure that you configure with
> > >>>>>>>>>> enable-g=dbg,meminit" in order to avoid spurious warnings and
> > to
> > >>> be
> > >>>>>>>>>> able to see stack traces.
> > >>>>>>>>>> -Dave
> > >>>>>>>>>> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> > >>>>>>>>>>> The problem seems to be with the communicator in MPI_Bcast()
> > >>>>>> (/src/
> > >>>>>>>>>>> mpi/coll/bcast.c).
> > >>>>>>>>>>> The comm_ptr is initialized to NULL and after a call to
> > >>>>>>>>>>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to
> > >>> the
> > >>>>>>>>>>> communicator object which was created throught MPI_Init().
> > >>>>>>>>>>> However, MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns
> > >>> with
> > >>>>>> a
> > >>>>>>>>>>> value other than MPI_SUCCESS.
> > >>>>>>>>>>> During some traces, it used to crash at this point itself. On
> > >>> some
> > >>>>>>>>>>> other traces, it used to go into the progress engine as I
> > >>>>>> described
> > >>>>>>>>>>> in my previous mails.
> > >>>>>>>>>>> What could be the reason? Hope someone chips in. I havent been
> > >>>>>> able
> > >>>>>>>>>>> to figure this out for sometime now.
> > >>>>>>>>>>> Krishna Chaitanya K
> > >>>>>>>>>>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> > >>>>>>>>>>> This might help :
> > >>>>>>>>>>> In the MPID_Comm structure, I have included the following line
> > >>> for
> > >>>>>>>>>>> the peruse place-holder :
> > >>>>>>>>>>> struct mpich_peruse_handle_t** c_peruse_handles;
> > >>>>>>>>>>> And in the function, MPID_Init_thread(), i have the line
> > >>>>>>>>>>> MPIR_Process.comm_world->c_peruse_handles = NULL;
> > >>>>>>>>>>> when the rest of the members of the comm_world structure are
> > >>>>>> being
> > >>>>>>>>>>> populated.
> > >>>>>>>>>>> Thanks,
> > >>>>>>>>>>> Krishna Chaitanya K
> > >>>>>>>>>>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> > >>>>>>>>>>> Thanks for the help. I am facing an weird problem right now.
> > To
> > >>>>>>>>>>> incorporate the PERUSE component, I have modified the
> > >>> communicator
> > >>>>>>>>>>> data structure to incude the PERUSE handles. The program
> > >>> executes
> > >>>>>>>>>>> as expected when compiled without the "mpe=mpilog" flag.When I
> > >>>>>>>>>>> compile it with the mpe component, the program gives this
> > >>> output :
> > >>>>>>>>>>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> > >>>>>>>>>>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT,
> > >>> root=0,
> > >>>>>>>>>>> MPI_COMM_WORLD) failed
> > >>>>>>>>>>> MPI_Bcast(717): Invalid communicator
> > >>>>>>>>>>> On tracing further, I understood this :
> > >>>>>>>>>>> MPI_Init () ( log_mpi_core.c )
> > >>>>>>>>>>> -- > PMPI_Init ( the communicator object is created here )
> > >>>>>>>>>>> -- > MPE_Init_log ()
> > >>>>>>>>>>> -- > CLOG_Local_init()
> > >>>>>>>>>>> -- > CLOG_Buffer_init4write ()
> > >>>>>>>>>>> -- > CLOG_Preamble_env_init()
> > >>>>>>>>>>> -- > MPI_Bcast () (bcast.c)
> > >>>>>>>>>>> -- > MPIR_Bcast ()
> > >>>>>>>>>>> -- > MPIC_Recv () /
> > >>>>>>>>>>> MPIC_Send()
> > >>>>>>>>>>> -- > MPIC_Wait()
> > >>>>>>>>>>> < Program crashes >
> > >>>>>>>>>>> The MPIC_Wait function is invoking the progress engine,
> > >>> which
> > >>>>>>>>>>> works properly without the mpe component.
> > >>>>>>>>>>> Even within the progress engine, MPIDU_Sock_wait() and
> > >>>>>>>>>>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple
> > >>> of
> > >>>>>>>>>>> times before the program crashes in the
> > >>> MPIDU_Socki_handle_read()
> > >>>>>>>>>>> or the MPIDU_Socki_handle_write() functions. ( The read() and
> > >>> the
> > >>>>>>>>>>> write() functions work two times, I think)
> > >>>>>>>>>>> I am finding it very hard to reason why the program
> > >>> crashes
> > >>>>>>>>>>> with mpe. Could you please suggest where I need to look at to
> > >>> sort
> > >>>>>>>>>>> this issue out?
> > >>>>>>>>>>> Thanks,
> > >>>>>>>>>>> Krishna Chaitanya K
> > >>>>>>>>>>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <
> > chan at mcs.anl.gov
> > >>>>>>>>>>> wrote:
> > >>>>>>>>>>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > >>>>>>>>>>>> Hi,
> > >>>>>>>>>>>> I tried configuring MPICH2 by doing :
> > >>>>>>>>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > >>>>>>>>>>>> --with-logging=SLOG CC=gcc CFLAGS=-g && make && make
> > >>> install
> > >>>>>>>>>>>> It flashed an error messaage saying :
> > >>>>>>>>>>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> > >>>>>>>>>>> Configure aborted
> > >>>>>>>>>>> The --with-logging is for MPICH2's internal logging, not MPE's
> > >>>>>>>>>>> logging.
> > >>>>>>>>>>> As what you did below is fine is fine.
> > >>>>>>>>>>>> After that, I tried :
> > >>> CC=gcc
> > >>>>>>>>>>> CFLAGS=-g
> > >>>>>>>>>>>> && make && make install
> > >>>>>>>>>>>> The installation was normal, when I tried compiling
> > an
> > >>>>>>>>>>> example
> > >>>>>>>>>>>> program by doing :
> > >>>>>>>>>>>> mpicc -mpilog -o sample sample.c
> > >>>>>>>>>>>> cc1: error: unrecognized command line option "-mpilog"
> > >>>>>>>>>>> Do "mpicc -mpe=mpilog -o sample sample.c" instead. For more
> > >>>>>> details,
> > >>>>>>>>>>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > >>>>>>>>>>> A.Chan
> > >>>>>>>>>>>> Can anyone please tell me what needs to be done to
> > >>> use
> > >>>>>>>>>>> the SLOG
> > >>>>>>>>>>>> logging format?
> > >>>>>>>>>>>> Thanks,
> > >>>>>>>>>>>> Krishna Chaitanya K
> > >>>>>>>>>>>> In the middle of difficulty, lies opportunity
