[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Mon Mar 24 10:39:34 CDT 2008
That answers a lot of my questions.
Sticking to MPI_Init for this discussion, the function is defined at two
places.So,there will be a reference to MPI_Init in lmpich and also a
reference in lmpe. But, how is it that when an MPI application is being
compiled, mpicc doesnt complain that there were two references to MPI_Init?
What exactly has been done to solve this?
I am actually facing this problem with the PERUSE function that i have
defined at :
1 > /src/peruse/peruse.c             and
2 > src/mpe2/src/wrappers/src/log_mpi_core.c.
    The first one goes into lmpich and the second one is a part of lmpe.
However, when I compile my MPI program, I get the following message :
/home/kc/mpich-install//lib/libmpich.a(peruse.o): In function
`PERUSE_TRACE_COMM_EVENT':
/home/kc/mpich-src/src/peruse/peruse.c:324: multiple definition of
/home/kc/mpich-install//lib/liblmpe.a(log_mpi_core.o):/home/kc/mpich-src/src/mpe2/src/wrappers/src/log_mpi_core.c:6830:
first defined here
collect2: ld returned 1 exit status
Thanks for your time,
Krishna Chaitanya K
On Mon, Mar 24, 2008 at 10:22 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> On Mon, 24 Mar 2008, Krishna Chaitanya wrote:
> >   Sorry for re-posting.
> >> I took a look at the documentation at src/util/multichannel/mpi.c
> >           Guess this is only for windows.
> >           It would be of great help if someone could point me to the
> > function that takes care of mapping MPI_Init to its wrapper, defined in
> > src/mpe2/src/wrappers/src/log_mpi_core.c, when the library is compiled
> with
> > the --enable-mpe switch., instead of the function defined in
> > src/mpi/init/init.c
> The function in src/mpi/init/init.c is defined when linked with -lmpich,
> i.e. mpicc. The functions in log_mpi_core.c is defined when linked with
> "mpicc -mpe=mpilog".  Try do "mpicc .... -show" will show you what
> libraries and their link order.
> A.Chan
> > Krishna Chaitanya K
> > On Sun, Mar 23, 2008 at 2:29 PM, Krishna Chaitanya <kris.c1986 at gmail.com
> > wrote:
> >>> See section "CUSTOMIZING LOGFILES" in mpich2-xxx/src/mpe2/README.
> >> Correct me if I am wrong :
> >> Since I am dealing with PERUSE events, whenever such an event occurs, a
> >> PERUSE function, defined in <mpich-dir>/src/peruse/peruse.c, is invoked
> by
> >> the MPI library. I am trying to get this event displayed in the
> jumpshot
> >> output. For this to be done, I need to define a wrapper function which
> gets
> >> invoked when a PERUSE event occurs, to log the event and then to call
> the
> >> actuall peruse function, which is similar to the way the wrapper
> function at
> >> log_mpi_core.c is called, when MPI_Init is called.
> >> Could you please clarify on the dynamic mapping?
> >> I took a look at the documentation at src/util/multichannel/mpi.c. I
> >> think, I understood what is going on in LoadFunctions() and the way the
> >> function pointers are assigned addresses depending the dll that is
> being
> >> used.
> >> Krishna Chaitanya K
> >> On Sun, Mar 23, 2008 at 12:59 PM, Anthony Chan <chan at mcs.anl.gov>
> >>> You don't need to modify MPE libraries.
> >>> A.Chan
> >>> On Sun, 23 Mar 2008, Krishna Chaitanya wrote:
> >>>> I have modified the mpe library to log the events that I am
> interested
> >>> in
> >>>> monitoring. But, I am bit hazy about how a function like MPI_Init is
> >>>> actually linked to the MPI_Init routine in the file log_mpi_core.c
> >>> when we
> >>>> compile the MPI application with the -mpe=mpilog switch. Could
> someone
> >>> point
> >>>> me to the routine that takes care of such a mapping?
> >>>> Thanks,
> >>>> Krishna Chaitanya K
> >>>> On Sat, Mar 22, 2008 at 3:01 AM, Krishna Chaitanya <
> >>> kris.c1986 at gmail.com>
> >>>> wrote:
> >>>>> Thanks a lot. I installed the latest jdk version and I am now able
> to
> >>> look
> >>>>> at the jumpshot output.
> >>>>> Krishna Chaitanya K
> >>>>> On Sat, Mar 22, 2008 at 1:45 AM, Anthony Chan <chan at mcs.anl.gov>
> >>> wrote:
> >>>>>> The error that you showed earlier does not suggest the problem is
> >>> with
> >>>>>> running jumpshot on your machine with limited memory.  If your
> clog2
> >>>>>> file
> >>>>>> isn't too bad, send it to me.
> >>>>>> On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> >>>>>>> I resolved that issue.
> >>>>>>> My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree)
> >>> hangs
> >>>>>> each
> >>>>>>> time I launch jumpshot with the slogfile. Since this is an
> >>> independent
> >>>>>>> project, I am constrained when it comes to the availability of
> >>>>>> machines.
> >>>>>>> Would you recommend that I give it a try on a 64bit AMD, 512MB
> RAM?
> >>>>>> Will
> >>>>>>> have to start from installing linux on this machine. Is it worth
> >>> the
> >>>>>> effort
> >>>>>>> ?) If it requires higher configuration, would you please suggest a
> >>>>>> lighter
> >>>>>>> graphical tool that I can use to present the  occurrence of events
> >>> and
> >>>>>> the
> >>>>>>> corresponding times?
> >>>>>>> Thanks,
> >>>>>>> Krishna Chaitanya K
> >>>>>>> On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov>
> >>>>>>>>> The file block pointer to the Tree Directory is NOT
> initialized!,
> >>>>>> can't
> >>>>>>>> read
> >>>>>>>>> it.
> >>>>>>>> That means the slog2 file isn't generated completely.  Something
> >>> went
> >>>>>>>> wrong in the convertion process (assuming your clog2 file is
> >>>>>> complete).
> >>>>>>>> If your MPI program doesn't finish MPI_Finalize normally, your
> >>> clog2
> >>>>>>>> file will be incomplete.
> >>>>>>>>>         IS there any environment variable that needs to be
> >>>>>> initialsed?
> >>>>>>>> Nothing needs to be initialized by hand.
> >>>>>>>> A.Chan
> >>>>>>>>> Thanks,
> >>>>>>>>> Krishna Chaitanya K
> >>>>>>>>> On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <
> >>> goodell at mcs.anl.gov>
> >>>>>>>> wrote:
> >>>>>>>>>> It's pretty hard to debug this issue via email.  However, you
> >>> could
> >>>>>>>>>> try running valgrind on your modified MPICH2 to see if any
> >>> obvious
> >>>>>>>>>> bugs pop out.  When you do, make sure that you configure with
> >>>>>>>>>> enable-g=dbg,meminit" in order to avoid spurious warnings and
> to
> >>> be
> >>>>>>>>>> able to see stack traces.
> >>>>>>>>>> -Dave
> >>>>>>>>>> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> >>>>>>>>>>> The problem seems to be with the communicator in MPI_Bcast()
> >>>>>> (/src/
> >>>>>>>>>>> mpi/coll/bcast.c).
> >>>>>>>>>>> The comm_ptr is initialized to NULL and after a call to
> >>>>>>>>>>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to
> >>> the
> >>>>>>>>>>> communicator object which was created throught MPI_Init().
> >>>>>>>>>>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns
> >>> with
> >>>>>> a
> >>>>>>>>>>> value other than MPI_SUCCESS.
> >>>>>>>>>>> During some traces, it used to crash at this point itself. On
> >>> some
> >>>>>>>>>>> other traces, it used to go into the progress engine as I
> >>>>>> described
> >>>>>>>>>>> in my previous mails.
> >>>>>>>>>>> What could be the reason? Hope someone chips in. I havent been
> >>>>>> able
> >>>>>>>>>>> to figure this out for sometime now.
> >>>>>>>>>>> Krishna Chaitanya K
> >>>>>>>>>>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> >>>>>>>>>>> <kris.c1986 at gmail.com> wrote:
> >>>>>>>>>>> This might help :
> >>>>>>>>>>> In the MPID_Comm structure, I have included the following line
> >>> for
> >>>>>>>>>>> the peruse place-holder :
> >>>>>>>>>>>  struct mpich_peruse_handle_t** c_peruse_handles;
> >>>>>>>>>>> And in the function, MPID_Init_thread(), i have the line
> >>>>>>>>>>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> >>>>>>>>>>>  when the rest of the members of the comm_world structure are
> >>>>>> being
> >>>>>>>>>>> populated.
> >>>>>>>>>>> Thanks,
> >>>>>>>>>>> Krishna Chaitanya K
> >>>>>>>>>>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> >>>>>>>>>>> Thanks for the help. I am facing an weird problem right now.
> To
> >>>>>>>>>>> incorporate the PERUSE component, I have modified the
> >>> communicator
> >>>>>>>>>>> data structure to incude the PERUSE handles. The program
> >>> executes
> >>>>>>>>>>> as expected when compiled without the "mpe=mpilog" flag.When I
> >>>>>>>>>>> compile it with the mpe component, the program gives this
> >>> output :
> >>>>>>>>>>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> >>>>>>>>>>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT,
> >>> root=0,
> >>>>>>>>>>> MPI_COMM_WORLD) failed
> >>>>>>>>>>> MPI_Bcast(717): Invalid communicator
> >>>>>>>>>>> On tracing further, I understood this :
> >>>>>>>>>>> MPI_Init () (  log_mpi_core.c )
> >>>>>>>>>>>  -- >  PMPI_Init ( the communicator object is created here )
> >>>>>>>>>>>  -- >  MPE_Init_log ()
> >>>>>>>>>>>         -- > CLOG_Local_init()
> >>>>>>>>>>>               -- > CLOG_Buffer_init4write ()
> >>>>>>>>>>>                     -- > CLOG_Preamble_env_init()
> >>>>>>>>>>>                           -- >   MPI_Bcast ()  (bcast.c)
> >>>>>>>>>>>                                   -- > MPIR_Bcast ()
> >>>>>>>>>>>                                          -- >  MPIC_Recv ()  /
> >>>>>>>>>>> MPIC_Send()
> >>>>>>>>>>>                                          -- >  MPIC_Wait()
> >>>>>>>>>>>                                       < Program crashes >
> >>>>>>>>>>>      The MPIC_Wait function is invoking the progress engine,
> >>> which
> >>>>>>>>>>> works properly without the mpe component.
> >>>>>>>>>>>       Even within the progress engine, MPIDU_Sock_wait() and
> >>>>>>>>>>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple
> >>> of
> >>>>>>>>>>> times before the program crashes in the
> >>> MPIDU_Socki_handle_read()
> >>>>>>>>>>> or the MPIDU_Socki_handle_write() functions. ( The read() and
> >>> the
> >>>>>>>>>>> write() functions work two times, I think)
> >>>>>>>>>>>      I am finding it very hard to reason why the program
> >>> crashes
> >>>>>>>>>>> with mpe. Could you please suggest where I need to look at to
> >>> sort
> >>>>>>>>>>> this issue out?
> >>>>>>>>>>> Thanks,
> >>>>>>>>>>> Krishna Chaitanya K
> >>>>>>>>>>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <
> chan at mcs.anl.gov
> >>>>>>>>>>> wrote:
> >>>>>>>>>>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> >>>>>>>>>>>> Hi,
> >>>>>>>>>>>>          I tried configuring MPICH2 by doing :
> >>>>>>>>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> >>>>>>>>>>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make
> >>> install
> >>>>>>>>>>>>          It  flashed an error messaage saying :
> >>>>>>>>>>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> >>>>>>>>>>> Configure aborted
> >>>>>>>>>>> The --with-logging is for MPICH2's internal logging, not MPE's
> >>>>>>>>>>> logging.
> >>>>>>>>>>> As what you did below is fine is fine.
> >>>>>>>>>>>>          After that, I tried :
> >>> CC=gcc
> >>>>>>>>>>> CFLAGS=-g
> >>>>>>>>>>>> && make && make install
> >>>>>>>>>>>>         The installation was normal, when I tried compiling
> an
> >>>>>>>>>>> example
> >>>>>>>>>>>> program by doing :
> >>>>>>>>>>>> mpicc -mpilog -o sample  sample.c
> >>>>>>>>>>>> cc1: error: unrecognized command line option "-mpilog"
> >>>>>>>>>>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more
> >>>>>> details,
> >>>>>>>>>>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> >>>>>>>>>>> A.Chan
> >>>>>>>>>>>>          Can anyone please tell me what needs to be done to
> >>> use
> >>>>>>>>>>> the SLOG
> >>>>>>>>>>>> logging format?
> >>>>>>>>>>>> Thanks,
> >>>>>>>>>>>> Krishna Chaitanya K
> >>>>>>>>>>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080324/e33da59f/attachment.htm>
