[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Mon Mar 24 09:12:30 CDT 2008
   Sorry for re-posting.
>I took a look at the documentation at src/util/multichannel/mpi.c
           Guess this is only for windows.
           It would be of great help if someone could point me to the
function that takes care of mapping MPI_Init to its wrapper, defined in
src/mpe2/src/wrappers/src/log_mpi_core.c, when the library is compiled with
the --enable-mpe switch., instead of the function defined in
src/mpi/init/init.c
Krishna Chaitanya K
On Sun, Mar 23, 2008 at 2:29 PM, Krishna Chaitanya <kris.c1986 at gmail.com>
wrote:
> > See section "CUSTOMIZING LOGFILES" in mpich2-xxx/src/mpe2/README.
> Correct me if I am wrong :
> Since I am dealing with PERUSE events, whenever such an event occurs, a
> PERUSE function, defined in <mpich-dir>/src/peruse/peruse.c, is invoked by
> the MPI library. I am trying to get this event displayed in the jumpshot
> output. For this to be done, I need to define a wrapper function which gets
> invoked when a PERUSE event occurs, to log the event and then to call the
> actuall peruse function, which is similar to the way the wrapper function at
> log_mpi_core.c is called, when MPI_Init is called.
> Could you please clarify on the dynamic mapping?
> I took a look at the documentation at src/util/multichannel/mpi.c. I
> think, I understood what is going on in LoadFunctions() and the way the
> function pointers are assigned addresses depending the dll that is being
> used.
> Krishna Chaitanya K
> On Sun, Mar 23, 2008 at 12:59 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > You don't need to modify MPE libraries.
> > A.Chan
> > On Sun, 23 Mar 2008, Krishna Chaitanya wrote:
> > > I have modified the mpe library to log the events that I am interested
> > in
> > > monitoring. But, I am bit hazy about how a function like MPI_Init is
> > > actually linked to the MPI_Init routine in the file log_mpi_core.c
> > when we
> > > compile the MPI application with the -mpe=mpilog switch. Could someone
> > point
> > > me to the routine that takes care of such a mapping?
> > > Thanks,
> > > Krishna Chaitanya K
> > > On Sat, Mar 22, 2008 at 3:01 AM, Krishna Chaitanya <
> > > wrote:
> > >> Thanks a lot. I installed the latest jdk version and I am now able to
> > look
> > >> at the jumpshot output.
> > >> Krishna Chaitanya K
> > >> On Sat, Mar 22, 2008 at 1:45 AM, Anthony Chan <chan at mcs.anl.gov>
> > wrote:
> > >>> The error that you showed earlier does not suggest the problem is
> > with
> > >>> running jumpshot on your machine with limited memory.  If your clog2
> > >>> file
> > >>> isn't too bad, send it to me.
> > >>> On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> > >>>> I resolved that issue.
> > >>>> My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree)
> > hangs
> > >>> each
> > >>>> time I launch jumpshot with the slogfile. Since this is an
> > independent
> > >>>> project, I am constrained when it comes to the availability of
> > >>> machines.
> > >>>> Would you recommend that I give it a try on a 64bit AMD, 512MB RAM?
> > >>> Will
> > >>>> have to start from installing linux on this machine. Is it worth
> > the
> > >>> effort
> > >>>> ?) If it requires higher configuration, would you please suggest a
> > >>> lighter
> > >>>> graphical tool that I can use to present the  occurrence of events
> > and
> > >>> the
> > >>>> corresponding times?
> > >>>> Thanks,
> > >>>> Krishna Chaitanya K
> > >>>> On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov>
> > >>>>>> The file block pointer to the Tree Directory is NOT initialized!,
> > >>> can't
> > >>>>> read
> > >>>>>> it.
> > >>>>> That means the slog2 file isn't generated completely.  Something
> > went
> > >>>>> wrong in the convertion process (assuming your clog2 file is
> > >>> complete).
> > >>>>> If your MPI program doesn't finish MPI_Finalize normally, your
> > clog2
> > >>>>> file will be incomplete.
> > >>>>>>         IS there any environment variable that needs to be
> > >>> initialsed?
> > >>>>> Nothing needs to be initialized by hand.
> > >>>>> A.Chan
> > >>>>>> Thanks,
> > >>>>>> Krishna Chaitanya K
> > >>>>>> On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <
> > goodell at mcs.anl.gov>
> > >>>>> wrote:
> > >>>>>>> It's pretty hard to debug this issue via email.  However, you
> > could
> > >>>>>>> try running valgrind on your modified MPICH2 to see if any
> > obvious
> > >>>>>>> bugs pop out.  When you do, make sure that you configure with
> > >>>>>>> enable-g=dbg,meminit" in order to avoid spurious warnings and to
> > be
> > >>>>>>> able to see stack traces.
> > >>>>>>> -Dave
> > >>>>>>> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> > >>>>>>>> The problem seems to be with the communicator in MPI_Bcast()
> > >>> (/src/
> > >>>>>>>> mpi/coll/bcast.c).
> > >>>>>>>> The comm_ptr is initialized to NULL and after a call to
> > >>>>>>>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to
> > the
> > >>>>>>>> communicator object which was created throught MPI_Init().
> > >>>>>>>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns
> > with
> > >>> a
> > >>>>>>>> value other than MPI_SUCCESS.
> > >>>>>>>> During some traces, it used to crash at this point itself. On
> > some
> > >>>>>>>> other traces, it used to go into the progress engine as I
> > >>> described
> > >>>>>>>> in my previous mails.
> > >>>>>>>> What could be the reason? Hope someone chips in. I havent been
> > >>> able
> > >>>>>>>> to figure this out for sometime now.
> > >>>>>>>> Krishna Chaitanya K
> > >>>>>>>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> > >>>>>>>> <kris.c1986 at gmail.com> wrote:
> > >>>>>>>> This might help :
> > >>>>>>>> In the MPID_Comm structure, I have included the following line
> > for
> > >>>>>>>> the peruse place-holder :
> > >>>>>>>>  struct mpich_peruse_handle_t** c_peruse_handles;
> > >>>>>>>> And in the function, MPID_Init_thread(), i have the line
> > >>>>>>>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> > >>>>>>>>  when the rest of the members of the comm_world structure are
> > >>> being
> > >>>>>>>> populated.
> > >>>>>>>> Thanks,
> > >>>>>>>> Krishna Chaitanya K
> > >>>>>>>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> > >>>>>>>> Thanks for the help. I am facing an weird problem right now. To
> > >>>>>>>> incorporate the PERUSE component, I have modified the
> > communicator
> > >>>>>>>> data structure to incude the PERUSE handles. The program
> > executes
> > >>>>>>>> as expected when compiled without the "mpe=mpilog" flag.When I
> > >>>>>>>> compile it with the mpe component, the program gives this
> > output :
> > >>>>>>>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> > >>>>>>>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT,
> > root=0,
> > >>>>>>>> MPI_COMM_WORLD) failed
> > >>>>>>>> MPI_Bcast(717): Invalid communicator
> > >>>>>>>> On tracing further, I understood this :
> > >>>>>>>> MPI_Init () (  log_mpi_core.c )
> > >>>>>>>>  -- >  PMPI_Init ( the communicator object is created here )
> > >>>>>>>>  -- >  MPE_Init_log ()
> > >>>>>>>>         -- > CLOG_Local_init()
> > >>>>>>>>               -- > CLOG_Buffer_init4write ()
> > >>>>>>>>                     -- > CLOG_Preamble_env_init()
> > >>>>>>>>                           -- >   MPI_Bcast ()  (bcast.c)
> > >>>>>>>>                                   -- > MPIR_Bcast ()
> > >>>>>>>>                                          -- >  MPIC_Recv ()  /
> > >>>>>>>> MPIC_Send()
> > >>>>>>>>                                          -- >  MPIC_Wait()
> > >>>>>>>>                                       < Program crashes >
> > >>>>>>>>      The MPIC_Wait function is invoking the progress engine,
> > which
> > >>>>>>>> works properly without the mpe component.
> > >>>>>>>>       Even within the progress engine, MPIDU_Sock_wait() and
> > >>>>>>>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple
> > of
> > >>>>>>>> times before the program crashes in the
> > MPIDU_Socki_handle_read()
> > >>>>>>>> or the MPIDU_Socki_handle_write() functions. ( The read() and
> > the
> > >>>>>>>> write() functions work two times, I think)
> > >>>>>>>>      I am finding it very hard to reason why the program
> > crashes
> > >>>>>>>> with mpe. Could you please suggest where I need to look at to
> > sort
> > >>>>>>>> this issue out?
> > >>>>>>>> Thanks,
> > >>>>>>>> Krishna Chaitanya K
> > >>>>>>>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov
> > >>>>>>>> wrote:
> > >>>>>>>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > >>>>>>>>> Hi,
> > >>>>>>>>>          I tried configuring MPICH2 by doing :
> > >>>>>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > >>>>>>>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make
> > install
> > >>>>>>>>>          It  flashed an error messaage saying :
> > >>>>>>>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> > >>>>>>>> Configure aborted
> > >>>>>>>> The --with-logging is for MPICH2's internal logging, not MPE's
> > >>>>>>>> logging.
> > >>>>>>>> As what you did below is fine is fine.
> > >>>>>>>>>          After that, I tried :
> > CC=gcc
> > >>>>>>>> CFLAGS=-g
> > >>>>>>>>> && make && make install
> > >>>>>>>>>         The installation was normal, when I tried compiling an
> > >>>>>>>> example
> > >>>>>>>>> program by doing :
> > >>>>>>>>> mpicc -mpilog -o sample  sample.c
> > >>>>>>>>> cc1: error: unrecognized command line option "-mpilog"
> > >>>>>>>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more
> > >>> details,
> > >>>>>>>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > >>>>>>>> A.Chan
> > >>>>>>>>>          Can anyone please tell me what needs to be done to
> > use
> > >>>>>>>> the SLOG
> > >>>>>>>>> logging format?
> > >>>>>>>>> Thanks,
> > >>>>>>>>> Krishna Chaitanya K
> > >>>>>>>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080324/fadd9f2a/attachment.htm>
