[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Sun Mar 23 13:29:34 CDT 2008
> See section "CUSTOMIZING LOGFILES" in mpich2-xxx/src/mpe2/README.
Correct me if I am wrong :
Since I am dealing with PERUSE events, whenever such an event occurs, a
PERUSE function, defined in <mpich-dir>/src/peruse/peruse.c, is invoked by
the MPI library. I am trying to get this event displayed in the jumpshot
output. For this to be done, I need to define a wrapper function which gets
invoked when a PERUSE event occurs, to log the event and then to call the
actuall peruse function, which is similar to the way the wrapper function at
log_mpi_core.c is called, when MPI_Init is called.
Could you please clarify on the dynamic mapping?
I took a look at the documentation at src/util/multichannel/mpi.c. I think,
I understood what is going on in LoadFunctions() and the way the function
pointers are assigned addresses depending the dll that is being used.
Krishna Chaitanya K
> You don't need to modify MPE libraries.
> A.Chan
> On Sun, 23 Mar 2008, Krishna Chaitanya wrote:
> > I have modified the mpe library to log the events that I am interested
> in
> > monitoring. But, I am bit hazy about how a function like MPI_Init is
> > actually linked to the MPI_Init routine in the file log_mpi_core.c when
> we
> > compile the MPI application with the -mpe=mpilog switch. Could someone
> point
> > me to the routine that takes care of such a mapping?
> > Thanks,
> > Krishna Chaitanya K
> > On Sat, Mar 22, 2008 at 3:01 AM, Krishna Chaitanya <kris.c1986 at gmail.com
> > wrote:
> >> Thanks a lot. I installed the latest jdk version and I am now able to
> look
> >> at the jumpshot output.
> >> Krishna Chaitanya K
> >> On Sat, Mar 22, 2008 at 1:45 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> >>> The error that you showed earlier does not suggest the problem is with
> >>> running jumpshot on your machine with limited memory.  If your clog2
> >>> file
> >>> isn't too bad, send it to me.
> >>> On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> >>>> I resolved that issue.
> >>>> My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree) hangs
> >>> each
> >>>> time I launch jumpshot with the slogfile. Since this is an
> independent
> >>>> project, I am constrained when it comes to the availability of
> >>> machines.
> >>>> Would you recommend that I give it a try on a 64bit AMD, 512MB RAM? (
> >>> Will
> >>>> have to start from installing linux on this machine. Is it worth the
> >>> effort
> >>>> ?) If it requires higher configuration, would you please suggest a
> >>> lighter
> >>>> graphical tool that I can use to present the  occurrence of events
> and
> >>> the
> >>>> corresponding times?
> >>>> Thanks,
> >>>> Krishna Chaitanya K
> >>>> On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov>
> >>>>>> The file block pointer to the Tree Directory is NOT initialized!,
> >>> can't
> >>>>> read
> >>>>>> it.
> >>>>> That means the slog2 file isn't generated completely.  Something
> went
> >>>>> wrong in the convertion process (assuming your clog2 file is
> >>> complete).
> >>>>> If your MPI program doesn't finish MPI_Finalize normally, your clog2
> >>>>> file will be incomplete.
> >>>>>>         IS there any environment variable that needs to be
> >>> initialsed?
> >>>>> Nothing needs to be initialized by hand.
> >>>>> A.Chan
> >>>>>> Thanks,
> >>>>>> Krishna Chaitanya K
> >>>>>> On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <goodell at mcs.anl.gov>
> >>>>> wrote:
> >>>>>>> It's pretty hard to debug this issue via email.  However, you
> could
> >>>>>>> try running valgrind on your modified MPICH2 to see if any obvious
> >>>>>>> bugs pop out.  When you do, make sure that you configure with "--
> >>>>>>> enable-g=dbg,meminit" in order to avoid spurious warnings and to
> be
> >>>>>>> able to see stack traces.
> >>>>>>> -Dave
> >>>>>>> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> >>>>>>>> The problem seems to be with the communicator in MPI_Bcast()
> >>> (/src/
> >>>>>>>> mpi/coll/bcast.c).
> >>>>>>>> The comm_ptr is initialized to NULL and after a call to
> >>>>>>>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> >>>>>>>> communicator object which was created throught MPI_Init().
> >>>>>>>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with
> >>> a
> >>>>>>>> value other than MPI_SUCCESS.
> >>>>>>>> During some traces, it used to crash at this point itself. On
> some
> >>>>>>>> other traces, it used to go into the progress engine as I
> >>> described
> >>>>>>>> in my previous mails.
> >>>>>>>> What could be the reason? Hope someone chips in. I havent been
> >>> able
> >>>>>>>> to figure this out for sometime now.
> >>>>>>>> Krishna Chaitanya K
> >>>>>>>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> >>>>>>>> <kris.c1986 at gmail.com> wrote:
> >>>>>>>> This might help :
> >>>>>>>> In the MPID_Comm structure, I have included the following line
> for
> >>>>>>>> the peruse place-holder :
> >>>>>>>>  struct mpich_peruse_handle_t** c_peruse_handles;
> >>>>>>>> And in the function, MPID_Init_thread(), i have the line
> >>>>>>>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> >>>>>>>>  when the rest of the members of the comm_world structure are
> >>> being
> >>>>>>>> populated.
> >>>>>>>> Thanks,
> >>>>>>>> Krishna Chaitanya K
> >>>>>>>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> >>>>>>>> Thanks for the help. I am facing an weird problem right now. To
> >>>>>>>> incorporate the PERUSE component, I have modified the
> communicator
> >>>>>>>> data structure to incude the PERUSE handles. The program executes
> >>>>>>>> as expected when compiled without the "mpe=mpilog" flag.When I
> >>>>>>>> compile it with the mpe component, the program gives this output
> >>>>>>>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> >>>>>>>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT,
> root=0,
> >>>>>>>> MPI_COMM_WORLD) failed
> >>>>>>>> MPI_Bcast(717): Invalid communicator
> >>>>>>>> On tracing further, I understood this :
> >>>>>>>> MPI_Init () (  log_mpi_core.c )
> >>>>>>>>  -- >  PMPI_Init ( the communicator object is created here )
> >>>>>>>>  -- >  MPE_Init_log ()
> >>>>>>>>         -- > CLOG_Local_init()
> >>>>>>>>               -- > CLOG_Buffer_init4write ()
> >>>>>>>>                     -- > CLOG_Preamble_env_init()
> >>>>>>>>                           -- >   MPI_Bcast ()  (bcast.c)
> >>>>>>>>                                   -- > MPIR_Bcast ()
> >>>>>>>>                                          -- >  MPIC_Recv ()  /
> >>>>>>>> MPIC_Send()
> >>>>>>>>                                          -- >  MPIC_Wait()
> >>>>>>>>                                       < Program crashes >
> >>>>>>>>      The MPIC_Wait function is invoking the progress engine,
> which
> >>>>>>>> works properly without the mpe component.
> >>>>>>>>       Even within the progress engine, MPIDU_Sock_wait() and
> >>>>>>>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> >>>>>>>> times before the program crashes in the MPIDU_Socki_handle_read()
> >>>>>>>> or the MPIDU_Socki_handle_write() functions. ( The read() and the
> >>>>>>>> write() functions work two times, I think)
> >>>>>>>>      I am finding it very hard to reason why the program crashes
> >>>>>>>> with mpe. Could you please suggest where I need to look at to
> sort
> >>>>>>>> this issue out?
> >>>>>>>> Thanks,
> >>>>>>>> Krishna Chaitanya K
> >>>>>>>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> >>>>>>>> wrote:
> >>>>>>>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> >>>>>>>>> Hi,
> >>>>>>>>>          I tried configuring MPICH2 by doing :
> >>>>>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> >>>>>>>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> >>>>>>>>>          It  flashed an error messaage saying :
> >>>>>>>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> >>>>>>>> Configure aborted
> >>>>>>>> The --with-logging is for MPICH2's internal logging, not MPE's
> >>>>>>>> logging.
> >>>>>>>> As what you did below is fine is fine.
> >>>>>>>>>          After that, I tried :
> >>>>>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> >>>>>>>> CFLAGS=-g
> >>>>>>>>>         The installation was normal, when I tried compiling an
> >>>>>>>> example
> >>>>>>>>> program by doing :
> >>>>>>>>> mpicc -mpilog -o sample  sample.c
> >>>>>>>>> cc1: error: unrecognized command line option "-mpilog"
> >>>>>>>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more
> >>> details,
> >>>>>>>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> >>>>>>>> A.Chan
> >>>>>>>>>          Can anyone please tell me what needs to be done to use
> >>>>>>>> the SLOG
> >>>>>>>>> logging format?
> >>>>>>>>> Thanks,
> >>>>>>>>> Krishna Chaitanya K
> >>>>>>>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080323/25ec6101/attachment.htm>
