[mpich-discuss] Trouble in getting the logging interface to work
Krishna Chaitanya kris.c1986 at gmail.com
Sun Mar 23 10:21:03 CDT 2008
I have modified the mpe library to log the events that I am interested in
monitoring. But, I am bit hazy about how a function like MPI_Init is
actually linked to the MPI_Init routine in the file log_mpi_core.c when we
compile the MPI application with the -mpe=mpilog switch. Could someone point
me to the routine that takes care of such a mapping?
Krishna Chaitanya K
On Sat, Mar 22, 2008 at 3:01 AM, Krishna Chaitanya <kris.c1986 at gmail.com>
wrote:
> Thanks a lot. I installed the latest jdk version and I am now able to look
> at the jumpshot output.
> Krishna Chaitanya K
> On Sat, Mar 22, 2008 at 1:45 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > The error that you showed earlier does not suggest the problem is with
> > running jumpshot on your machine with limited memory.  If your clog2
> > file
> > isn't too bad, send it to me.
> > On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> > > I resolved that issue.
> > > My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree) hangs
> > each
> > > time I launch jumpshot with the slogfile. Since this is an independent
> > > project, I am constrained when it comes to the availability of
> > machines.
> > > Would you recommend that I give it a try on a 64bit AMD, 512MB RAM? (
> > Will
> > > have to start from installing linux on this machine. Is it worth the
> > effort
> > > ?) If it requires higher configuration, would you please suggest a
> > lighter
> > > graphical tool that I can use to present the  occurrence of events and
> > the
> > > corresponding times?
> > > Thanks,
> > > Krishna Chaitanya K
> > > On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov>
> > >>> The file block pointer to the Tree Directory is NOT initialized!,
> > can't
> > >> read
> > >>> it.
> > >> That means the slog2 file isn't generated completely.  Something went
> > >> wrong in the convertion process (assuming your clog2 file is
> > complete).
> > >> If your MPI program doesn't finish MPI_Finalize normally, your clog2
> > >> file will be incomplete.
> > >>>         IS there any environment variable that needs to be
> > initialsed?
> > >> Nothing needs to be initialized by hand.
> > >> A.Chan
> > >>> Thanks,
> > >>> Krishna Chaitanya K
> > >>> On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <goodell at mcs.anl.gov>
> > >> wrote:
> > >>>> It's pretty hard to debug this issue via email.  However, you could
> > >>>> try running valgrind on your modified MPICH2 to see if any obvious
> > >>>> bugs pop out.  When you do, make sure that you configure with "--
> > >>>> enable-g=dbg,meminit" in order to avoid spurious warnings and to be
> > >>>> able to see stack traces.
> > >>>> -Dave
> > >>>> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> > >>>>> The problem seems to be with the communicator in MPI_Bcast()
> > (/src/
> > >>>>> mpi/coll/bcast.c).
> > >>>>> The comm_ptr is initialized to NULL and after a call to
> > >>>>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> > >>>>> communicator object which was created throught MPI_Init().
> > >>>>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with
> > a
> > >>>>> value other than MPI_SUCCESS.
> > >>>>> During some traces, it used to crash at this point itself. On some
> > >>>>> other traces, it used to go into the progress engine as I
> > described
> > >>>>> in my previous mails.
> > >>>>> What could be the reason? Hope someone chips in. I havent been
> > able
> > >>>>> to figure this out for sometime now.
> > >>>>> Krishna Chaitanya K
> > >>>>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> > >>>>> <kris.c1986 at gmail.com> wrote:
> > >>>>> This might help :
> > >>>>> In the MPID_Comm structure, I have included the following line for
> > >>>>> the peruse place-holder :
> > >>>>>  struct mpich_peruse_handle_t** c_peruse_handles;
> > >>>>> And in the function, MPID_Init_thread(), i have the line
> > >>>>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> > >>>>>  when the rest of the members of the comm_world structure are
> > being
> > >>>>> populated.
> > >>>>> Thanks,
> > >>>>> Krishna Chaitanya K
> > >>>>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> > >>>>> Thanks for the help. I am facing an weird problem right now. To
> > >>>>> incorporate the PERUSE component, I have modified the communicator
> > >>>>> data structure to incude the PERUSE handles. The program executes
> > >>>>> as expected when compiled without the "mpe=mpilog" flag.When I
> > >>>>> compile it with the mpe component, the program gives this output :
> > >>>>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> > >>>>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> > >>>>> MPI_COMM_WORLD) failed
> > >>>>> MPI_Bcast(717): Invalid communicator
> > >>>>> On tracing further, I understood this :
> > >>>>> MPI_Init () (  log_mpi_core.c )
> > >>>>>  -- >  PMPI_Init ( the communicator object is created here )
> > >>>>>  -- >  MPE_Init_log ()
> > >>>>>         -- > CLOG_Local_init()
> > >>>>>               -- > CLOG_Buffer_init4write ()
> > >>>>>                     -- > CLOG_Preamble_env_init()
> > >>>>>                           -- >   MPI_Bcast ()  (bcast.c)
> > >>>>>                                   -- > MPIR_Bcast ()
> > >>>>>                                          -- >  MPIC_Recv ()  /
> > >>>>> MPIC_Send()
> > >>>>>                                          -- >  MPIC_Wait()
> > >>>>>                                       < Program crashes >
> > >>>>>      The MPIC_Wait function is invoking the progress engine, which
> > >>>>> works properly without the mpe component.
> > >>>>>       Even within the progress engine, MPIDU_Sock_wait() and
> > >>>>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> > >>>>> times before the program crashes in the MPIDU_Socki_handle_read()
> > >>>>> or the MPIDU_Socki_handle_write() functions. ( The read() and the
> > >>>>> write() functions work two times, I think)
> > >>>>>      I am finding it very hard to reason why the program crashes
> > >>>>> with mpe. Could you please suggest where I need to look at to sort
> > >>>>> this issue out?
> > >>>>> Thanks,
> > >>>>> Krishna Chaitanya K
> > >>>>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> > >>>>> wrote:
> > >>>>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > >>>>>> Hi,
> > >>>>>>          I tried configuring MPICH2 by doing :
> > >>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > >>>>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> > >>>>>>          It  flashed an error messaage saying :
> > >>>>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> > >>>>> Configure aborted
> > >>>>> The --with-logging is for MPICH2's internal logging, not MPE's
> > >>>>> logging.
> > >>>>> As what you did below is fine is fine.
> > >>>>>>          After that, I tried :
> > >>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> > >>>>> CFLAGS=-g
> > >>>>>>         The installation was normal, when I tried compiling an
> > >>>>> example
> > >>>>>> program by doing :
> > >>>>>> mpicc -mpilog -o sample  sample.c
> > >>>>>> cc1: error: unrecognized command line option "-mpilog"
> > >>>>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more
> > details,
> > >>>>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > >>>>> A.Chan
> > >>>>>>          Can anyone please tell me what needs to be done to use
> > >>>>> the SLOG
> > >>>>>> logging format?
> > >>>>>> Thanks,
> > >>>>>> Krishna Chaitanya K
> > >>>>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080323/66ee9c1a/attachment.htm>
