[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Sat Mar 22 02:01:25 CDT 2008
Thanks a lot. I installed the latest jdk version and I am now able to look
at the jumpshot output.
Krishna Chaitanya K
On Sat, Mar 22, 2008 at 1:45 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> The error that you showed earlier does not suggest the problem is with
> running jumpshot on your machine with limited memory.  If your clog2 file
> isn't too bad, send it to me.
> On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> > I resolved that issue.
> > My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree) hangs
> each
> > time I launch jumpshot with the slogfile. Since this is an independent
> > project, I am constrained when it comes to the availability of machines.
> > Would you recommend that I give it a try on a 64bit AMD, 512MB RAM? (
> Will
> > have to start from installing linux on this machine. Is it worth the
> effort
> > ?) If it requires higher configuration, would you please suggest a
> lighter
> > graphical tool that I can use to present the  occurrence of events and
> the
> > corresponding times?
> > Thanks,
> > Krishna Chaitanya K
> > On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> >>> The file block pointer to the Tree Directory is NOT initialized!,
> can't
> >> read
> >>> it.
> >> That means the slog2 file isn't generated completely.  Something went
> >> wrong in the convertion process (assuming your clog2 file is complete).
> >> If your MPI program doesn't finish MPI_Finalize normally, your clog2
> >> file will be incomplete.
> >>>         IS there any environment variable that needs to be initialsed?
> >> Nothing needs to be initialized by hand.
> >> A.Chan
> >>> Thanks,
> >>> Krishna Chaitanya K
> >>> On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <goodell at mcs.anl.gov>
> >> wrote:
> >>>> It's pretty hard to debug this issue via email.  However, you could
> >>>> try running valgrind on your modified MPICH2 to see if any obvious
> >>>> bugs pop out.  When you do, make sure that you configure with "--
> >>>> enable-g=dbg,meminit" in order to avoid spurious warnings and to be
> >>>> able to see stack traces.
> >>>> -Dave
> >>>> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> >>>>> The problem seems to be with the communicator in MPI_Bcast() (/src/
> >>>>> mpi/coll/bcast.c).
> >>>>> The comm_ptr is initialized to NULL and after a call to
> >>>>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> >>>>> communicator object which was created throught MPI_Init().
> >>>>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with a
> >>>>> value other than MPI_SUCCESS.
> >>>>> During some traces, it used to crash at this point itself. On some
> >>>>> other traces, it used to go into the progress engine as I described
> >>>>> in my previous mails.
> >>>>> What could be the reason? Hope someone chips in. I havent been able
> >>>>> to figure this out for sometime now.
> >>>>> Krishna Chaitanya K
> >>>>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> >>>>> <kris.c1986 at gmail.com> wrote:
> >>>>> This might help :
> >>>>> In the MPID_Comm structure, I have included the following line for
> >>>>> the peruse place-holder :
> >>>>>  struct mpich_peruse_handle_t** c_peruse_handles;
> >>>>> And in the function, MPID_Init_thread(), i have the line
> >>>>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> >>>>>  when the rest of the members of the comm_world structure are being
> >>>>> populated.
> >>>>> Thanks,
> >>>>> Krishna Chaitanya K
> >>>>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> >>>>> Thanks for the help. I am facing an weird problem right now. To
> >>>>> incorporate the PERUSE component, I have modified the communicator
> >>>>> data structure to incude the PERUSE handles. The program executes
> >>>>> as expected when compiled without the "mpe=mpilog" flag.When I
> >>>>> compile it with the mpe component, the program gives this output :
> >>>>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> >>>>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> >>>>> MPI_COMM_WORLD) failed
> >>>>> MPI_Bcast(717): Invalid communicator
> >>>>> On tracing further, I understood this :
> >>>>> MPI_Init () (  log_mpi_core.c )
> >>>>>  -- >  PMPI_Init ( the communicator object is created here )
> >>>>>  -- >  MPE_Init_log ()
> >>>>>         -- > CLOG_Local_init()
> >>>>>               -- > CLOG_Buffer_init4write ()
> >>>>>                     -- > CLOG_Preamble_env_init()
> >>>>>                           -- >   MPI_Bcast ()  (bcast.c)
> >>>>>                                   -- > MPIR_Bcast ()
> >>>>>                                          -- >  MPIC_Recv ()  /
> >>>>> MPIC_Send()
> >>>>>                                          -- >  MPIC_Wait()
> >>>>>                                       < Program crashes >
> >>>>>      The MPIC_Wait function is invoking the progress engine, which
> >>>>> works properly without the mpe component.
> >>>>>       Even within the progress engine, MPIDU_Sock_wait() and
> >>>>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> >>>>> times before the program crashes in the MPIDU_Socki_handle_read()
> >>>>> or the MPIDU_Socki_handle_write() functions. ( The read() and the
> >>>>> write() functions work two times, I think)
> >>>>>      I am finding it very hard to reason why the program crashes
> >>>>> with mpe. Could you please suggest where I need to look at to sort
> >>>>> this issue out?
> >>>>> Thanks,
> >>>>> Krishna Chaitanya K
> >>>>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> >>>>> wrote:
> >>>>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> >>>>>> Hi,
> >>>>>>          I tried configuring MPICH2 by doing :
> >>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> >>>>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> >>>>>>          It  flashed an error messaage saying :
> >>>>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> >>>>> Configure aborted
> >>>>> The --with-logging is for MPICH2's internal logging, not MPE's
> >>>>> logging.
> >>>>> As what you did below is fine is fine.
> >>>>>>          After that, I tried :
> >>>>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> >>>>> CFLAGS=-g
> >>>>>>         The installation was normal, when I tried compiling an
> >>>>> example
> >>>>>> program by doing :
> >>>>>> mpicc -mpilog -o sample  sample.c
> >>>>>> cc1: error: unrecognized command line option "-mpilog"
> >>>>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more
> details,
> >>>>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> >>>>> A.Chan
> >>>>>>          Can anyone please tell me what needs to be done to use
> >>>>> the SLOG
> >>>>>> logging format?
> >>>>>> Thanks,
> >>>>>> Krishna Chaitanya K
> >>>>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080322/d4f94acd/attachment.htm>
