[mpich-discuss] Trouble in getting the logging interface to work
Krishna Chaitanya kris.c1986 at gmail.com
Fri Mar 21 23:31:26 CDT 2008
Sorry for posting again on the same issue. I was able to take a look at the
text output being generated before my computer stopped responding. Could you
please take a look and suggest what needs to be done to resolve the
exceptions being generated.
Krishna Chaitanya K
[kris.c1986 at zeus examples]$ jumpshot cpi.slog2
GUI_LIBDIR is set. GUI_LIBDIR = /home/kc/mpich-install//lib
Java is version 1.4.2.
Starting the SLOG-2 Display Program .....
Jumpshot-4 setup file : /home/kc/.jumpshot4.conf
Initialize Parameters:
Y_AXIS_ROOT_LABEL = SLOG-2
INIT_SLOG2_LEVEL_READ = 4
AUTO_WINDOWS_LOCATION = true
SCREEN_HEIGHT_RATIO = 0.5
TIME_SCROLL_UNIT_RATIO = 0.01
Y_AXIS_ROOT_VISIBLE = true
ACTIVE_REFRESH = false
ROW_RESIZE_MODE = Row
BACKGROUND_COLOR = black
STATE_HEIGHT_FACTOR = 0.9
NESTING_HEIGHT_FACTOR = 0.8
ARROW_ANTIALIASING = default
MIN_WIDTH_TO_DRAG = 4
CLICK_RADIUS_TO_LINE = 3
LEFTCLICK_INSTANT_ZOOM = true
STATE_BORDER = ColorRaised
ARROW_HEAD_LENGTH = 10
ARROW_HEAD_WIDTH = 6
EVENT_BASE_WIDTH = 8
PREVIEW_STATE_DISPLAY = CumulativeExclusionRatio
PREVIEW_STATE_BORDER = ColorXOR
PREVIEW_STATE_BORDER_W = 3
PREVIEW_STATE_BORDER_H = 0
PREVIEW_STATE_LEGEND_H = 2
PREVIEW_ARROW_LOG_BASE = 5
SEARCH_ARROW_LENGTH = 20
SEARCH_FRAME_THICKNESS = 3
SEARCHED_OBJECT_ON_TOP = false
HISTOGRAM_ZERO_ORIGIN = true
SUMMARY_STATE_BORDER = ColorRaised
SUMMARY_ARROW_LOG_BASE = 5
LEGEND_PREVIEW_ORDER = true
LEGEND_TOPOLOGY_ORDER = true
slog_ins.tZoomFtr = 2.0
Exception during event dispatch:
java.lang.ExceptionInInitializerError
   at java.lang.Class.initializeClass(libgcj.so.7rh)
   at viewer.timelines.CanvasTimeline.initializeAllOffImages(
CanvasTimeline.java:194)
   at viewer.zoomable.ScrollableObject.componentResized(
ScrollableObject.java:585)
   at viewer.zoomable.ViewportTime.componentResized(ViewportTime.java:219)
   at viewer.zoomable.ViewportTimeYaxis.fireComponentResized(
ViewportTimeYaxis.java:95)
   at viewer.zoomable.ActionYaxisTreeCommit.actionPerformed(
ActionYaxisTreeCommit.java:49)
   at javax.swing.AbstractButton.fireActionPerformed(libgcj.so.7rh)
   at javax.swing.AbstractButton$1.actionPerformed(libgcj.so.7rh)
   at javax.swing.DefaultButtonModel.fireActionPerformed(libgcj.so.7rh)
   at javax.swing.DefaultButtonModel.setPressed(libgcj.so.7rh)
   at javax.swing.AbstractButton.doClick(libgcj.so.7rh)
   at viewer.zoomable.ActionPptyRefresh.actionPerformed(
ActionPptyRefresh.java:43)
   at
viewer.timelines.PreviewStateComboBox$PreviewModeActionListener.actionPerformed
(PreviewStateComboBox.java:71)
   at javax.swing.JComboBox.fireActionEvent(libgcj.so.7rh)
   at javax.swing.JComboBox.selectedItemChanged(libgcj.so.7rh)
   at javax.swing.JComboBox.contentsChanged(libgcj.so.7rh)
   at javax.swing.AbstractListModel.fireContentsChanged(libgcj.so.7rh)
   at javax.swing.DefaultComboBoxModel.setSelectedItem(libgcj.so.7rh)
   at javax.swing.JComboBox.setSelectedItem(libgcj.so.7rh)
   at viewer.timelines.PreviewStateComboBox.init(PreviewStateComboBox.java
:59)
   at viewer.timelines.TimelinePanel.init(TimelinePanel.java:400)
   at viewer.timelines.TimelineFrame.init(TimelineFrame.java:57)
   at viewer.first.LogFileOperations$1.finished(LogFileOperations.java:246)
   at viewer.common.SwingWorker$1.run(SwingWorker.java:103)
   at java.awt.event.InvocationEvent.dispatch(libgcj.so.7rh)
   at java.awt.EventQueue.dispatchEvent(libgcj.so.7rh)
   at java.awt.EventDispatchThread.run(libgcj.so.7rh)
Caused by: java.lang.IllegalArgumentException: width (=0) and height (=0)
must be > 0
   at java.awt.image.DirectColorModel.createCompatibleWritableRaster(
libgcj.so.7rh)
   at java.awt.image.BufferedImage.<init>(libgcj.so.7rh)
   at viewer.common.CustomCursor.getBestCursorImage(CustomCursor.java:62)
   at viewer.common.CustomCursor.initCursors(CustomCursor.java:86)
   at viewer.common.CustomCursor.<clinit>(CustomCursor.java:35)
   ...33 more
java.lang.NoClassDefFoundError: viewer.common.CustomCursor
   at java.awt.Component.processComponentEvent(libgcj.so.7rh)
   at java.awt.Component.processEvent(libgcj.so.7rh)
   at java.awt.Container.processEvent(libgcj.so.7rh)
   at java.awt.Component.dispatchEventImpl(libgcj.so.7rh)
   at java.awt.Container.dispatchEventImpl(libgcj.so.7rh)
   at java.awt.Component.dispatchEvent(libgcj.so.7rh)
On Fri, Mar 21, 2008 at 1:47 PM, Krishna Chaitanya <kris.c1986 at gmail.com>
wrote:
> I resolved that issue.
> My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree) hangs each
> time I launch jumpshot with the slogfile. Since this is an independent
> project, I am constrained when it comes to the availability of machines.
> Would you recommend that I give it a try on a 64bit AMD, 512MB RAM? ( Will
> have to start from installing linux on this machine. Is it worth the effort
> ?) If it requires higher configuration, would you please suggest a lighter
> graphical tool that I can use to present the  occurrence of events and the
> corresponding times?
> Thanks,
> Krishna Chaitanya K
> On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> > > The file block pointer to the Tree Directory is NOT initialized!,
> > can't read
> > > it.
> > That means the slog2 file isn't generated completely.  Something went
> > wrong in the convertion process (assuming your clog2 file is complete).
> > If your MPI program doesn't finish MPI_Finalize normally, your clog2
> > file will be incomplete.
> > >         IS there any environment variable that needs to be initialsed?
> > Nothing needs to be initialized by hand.
> > A.Chan
> > > Thanks,
> > > Krishna Chaitanya K
> > > On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <goodell at mcs.anl.gov>
> > wrote:
> > >> It's pretty hard to debug this issue via email.  However, you could
> > >> try running valgrind on your modified MPICH2 to see if any obvious
> > >> bugs pop out.  When you do, make sure that you configure with "--
> > >> enable-g=dbg,meminit" in order to avoid spurious warnings and to be
> > >> able to see stack traces.
> > >> -Dave
> > >> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> > >>> The problem seems to be with the communicator in MPI_Bcast() (/src/
> > >>> mpi/coll/bcast.c).
> > >>> The comm_ptr is initialized to NULL and after a call to
> > >>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> > >>> communicator object which was created throught MPI_Init().
> > >>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with a
> > >>> value other than MPI_SUCCESS.
> > >>> During some traces, it used to crash at this point itself. On some
> > >>> other traces, it used to go into the progress engine as I described
> > >>> in my previous mails.
> > >>> What could be the reason? Hope someone chips in. I havent been able
> > >>> to figure this out for sometime now.
> > >>> Krishna Chaitanya K
> > >>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> > >>> <kris.c1986 at gmail.com> wrote:
> > >>> This might help :
> > >>> In the MPID_Comm structure, I have included the following line for
> > >>> the peruse place-holder :
> > >>>  struct mpich_peruse_handle_t** c_peruse_handles;
> > >>> And in the function, MPID_Init_thread(), i have the line
> > >>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> > >>>  when the rest of the members of the comm_world structure are being
> > >>> populated.
> > >>> Thanks,
> > >>> Krishna Chaitanya K
> > >>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> > >>> Thanks for the help. I am facing an weird problem right now. To
> > >>> incorporate the PERUSE component, I have modified the communicator
> > >>> data structure to incude the PERUSE handles. The program executes
> > >>> as expected when compiled without the "mpe=mpilog" flag.When I
> > >>> compile it with the mpe component, the program gives this output :
> > >>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> > >>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> > >>> MPI_COMM_WORLD) failed
> > >>> MPI_Bcast(717): Invalid communicator
> > >>> On tracing further, I understood this :
> > >>> MPI_Init () (  log_mpi_core.c )
> > >>>  -- >  PMPI_Init ( the communicator object is created here )
> > >>>  -- >  MPE_Init_log ()
> > >>>         -- > CLOG_Local_init()
> > >>>               -- > CLOG_Buffer_init4write ()
> > >>>                     -- > CLOG_Preamble_env_init()
> > >>>                           -- >   MPI_Bcast ()  (bcast.c)
> > >>>                                   -- > MPIR_Bcast ()
> > >>>                                          -- >  MPIC_Recv ()  /
> > >>> MPIC_Send()
> > >>>                                          -- >  MPIC_Wait()
> > >>>                                       < Program crashes >
> > >>>      The MPIC_Wait function is invoking the progress engine, which
> > >>> works properly without the mpe component.
> > >>>       Even within the progress engine, MPIDU_Sock_wait() and
> > >>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> > >>> times before the program crashes in the MPIDU_Socki_handle_read()
> > >>> or the MPIDU_Socki_handle_write() functions. ( The read() and the
> > >>> write() functions work two times, I think)
> > >>>      I am finding it very hard to reason why the program crashes
> > >>> with mpe. Could you please suggest where I need to look at to sort
> > >>> this issue out?
> > >>> Thanks,
> > >>> Krishna Chaitanya K
> > >>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> > >>> wrote:
> > >>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > >>>> Hi,
> > >>>>          I tried configuring MPICH2 by doing :
> > >>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > >>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> > >>>>          It  flashed an error messaage saying :
> > >>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> > >>> Configure aborted
> > >>> The --with-logging is for MPICH2's internal logging, not MPE's
> > >>> logging.
> > >>> As what you did below is fine is fine.
> > >>>>          After that, I tried :
> > >>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> > >>> CFLAGS=-g
> > >>>>         The installation was normal, when I tried compiling an
> > >>> example
> > >>>> program by doing :
> > >>>> mpicc -mpilog -o sample  sample.c
> > >>>> cc1: error: unrecognized command line option "-mpilog"
> > >>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more
> > details,
> > >>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > >>> A.Chan
> > >>>>          Can anyone please tell me what needs to be done to use
> > >>> the SLOG
> > >>>> logging format?
> > >>>> Thanks,
> > >>>> Krishna Chaitanya K
> > >>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080322/8b5c5b6f/attachment.htm>
