[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Fri Mar 21 12:47:35 CDT 2008
I resolved that issue.
My comp ( Intel centrino 32 bit , 256 MB RAM - Dated, I agree) hangs each
time I launch jumpshot with the slogfile. Since this is an independent
project, I am constrained when it comes to the availability of machines.
Would you recommend that I give it a try on a 64bit AMD, 512MB RAM? ( Will
have to start from installing linux on this machine. Is it worth the effort
?) If it requires higher configuration, would you please suggest a lighter
graphical tool that I can use to present the  occurrence of events and the
corresponding times?
Krishna Chaitanya K
On Fri, Mar 21, 2008 at 8:23 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> On Fri, 21 Mar 2008, Krishna Chaitanya wrote:
> > The file block pointer to the Tree Directory is NOT initialized!, can't
> read
> > it.
> That means the slog2 file isn't generated completely.  Something went
> wrong in the convertion process (assuming your clog2 file is complete).
> If your MPI program doesn't finish MPI_Finalize normally, your clog2
> file will be incomplete.
> >         IS there any environment variable that needs to be initialsed?
> Nothing needs to be initialized by hand.
> A.Chan
> > Thanks,
> > Krishna Chaitanya K
> > On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> >> It's pretty hard to debug this issue via email.  However, you could
> >> try running valgrind on your modified MPICH2 to see if any obvious
> >> bugs pop out.  When you do, make sure that you configure with "--
> >> enable-g=dbg,meminit" in order to avoid spurious warnings and to be
> >> able to see stack traces.
> >> -Dave
> >> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> >>> The problem seems to be with the communicator in MPI_Bcast() (/src/
> >>> mpi/coll/bcast.c).
> >>> The comm_ptr is initialized to NULL and after a call to
> >>> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> >>> communicator object which was created throught MPI_Init().
> >>> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with a
> >>> value other than MPI_SUCCESS.
> >>> During some traces, it used to crash at this point itself. On some
> >>> other traces, it used to go into the progress engine as I described
> >>> in my previous mails.
> >>> What could be the reason? Hope someone chips in. I havent been able
> >>> to figure this out for sometime now.
> >>> Krishna Chaitanya K
> >>> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> >>> <kris.c1986 at gmail.com> wrote:
> >>> This might help :
> >>> In the MPID_Comm structure, I have included the following line for
> >>> the peruse place-holder :
> >>>  struct mpich_peruse_handle_t** c_peruse_handles;
> >>> And in the function, MPID_Init_thread(), i have the line
> >>>  MPIR_Process.comm_world->c_peruse_handles = NULL;
> >>>  when the rest of the members of the comm_world structure are being
> >>> populated.
> >>> Thanks,
> >>> Krishna Chaitanya K
> >>> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> >>> Thanks for the help. I am facing an weird problem right now. To
> >>> incorporate the PERUSE component, I have modified the communicator
> >>> data structure to incude the PERUSE handles. The program executes
> >>> as expected when compiled without the "mpe=mpilog" flag.When I
> >>> compile it with the mpe component, the program gives this output :
> >>> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> >>> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> >>> MPI_COMM_WORLD) failed
> >>> MPI_Bcast(717): Invalid communicator
> >>> On tracing further, I understood this :
> >>> MPI_Init () (  log_mpi_core.c )
> >>>  -- >  PMPI_Init ( the communicator object is created here )
> >>>  -- >  MPE_Init_log ()
> >>>         -- > CLOG_Local_init()
> >>>               -- > CLOG_Buffer_init4write ()
> >>>                     -- > CLOG_Preamble_env_init()
> >>>                           -- >   MPI_Bcast ()  (bcast.c)
> >>>                                   -- > MPIR_Bcast ()
> >>>                                          -- >  MPIC_Recv ()  /
> >>> MPIC_Send()
> >>>                                          -- >  MPIC_Wait()
> >>>                                       < Program crashes >
> >>>      The MPIC_Wait function is invoking the progress engine, which
> >>> works properly without the mpe component.
> >>>       Even within the progress engine, MPIDU_Sock_wait() and
> >>> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> >>> times before the program crashes in the MPIDU_Socki_handle_read()
> >>> or the MPIDU_Socki_handle_write() functions. ( The read() and the
> >>> write() functions work two times, I think)
> >>>      I am finding it very hard to reason why the program crashes
> >>> with mpe. Could you please suggest where I need to look at to sort
> >>> this issue out?
> >>> Thanks,
> >>> Krishna Chaitanya K
> >>> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> >>> wrote:
> >>> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> >>>> Hi,
> >>>>          I tried configuring MPICH2 by doing :
> >>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> >>>> --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> >>>>          It  flashed an error messaage saying :
> >>>> onfigure: error: ./src/util/logging/SLOG does not exist.
> >>> Configure aborted
> >>> The --with-logging is for MPICH2's internal logging, not MPE's
> >>> logging.
> >>> As what you did below is fine is fine.
> >>>>          After that, I tried :
> >>>> ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> >>> CFLAGS=-g
> >>>>         The installation was normal, when I tried compiling an
> >>> example
> >>>> program by doing :
> >>>> mpicc -mpilog -o sample  sample.c
> >>>> cc1: error: unrecognized command line option "-mpilog"
> >>> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more details,
> >>> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> >>> A.Chan
> >>>>          Can anyone please tell me what needs to be done to use
> >>> the SLOG
> >>>> logging format?
> >>>> Thanks,
> >>>> Krishna Chaitanya K
> >>>> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080321/2816564d/attachment.htm>
