[mpich-discuss] Windows & Name publishing
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Mar 17 11:02:16 CDT 2008
 Yes, we should fix this. The issue arises because SMPD managers don't
contact each other (like in mpd to form a ring) before the job is started.
(PS: This problem could be *fixed* in unix systems by having the SMPD
managers publish names to managers on the hosts listed in the smpd
configuration file.)
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of William Gropp
Sent: Monday, March 17, 2008 10:48 AM
Subject: Re: [mpich-discuss] Windows & Name publishing
That's a very serious bug in smpd - this is exactly what
Lookup_name/Publish_name are for.
Bill
On Mar 17, 2008, at 10:12 AM, Jayesh Krishna wrote:
MPI_Publish_name() from one MPI job and an MPI_Lookup_name() from another
MPI job does not work on windows (Does not work with the SMPD process
manager).
(PS: In windows, the Mandelbrot visualizer, mpich2/examples, connects to the
solver using windows sockets.)
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Andrea Galligani
Sent: Monday, March 17, 2008 9:49 AM
Subject: [mpich-discuss] Windows & Name publishing
I'm writing a client/server application similar to the pman_vis sample.
I would use the name publishing service
to manage the port name. My problem is that the server registers the pair
<port name, service name> without errors but on the client side the
MPI_Lookup_name fails reporting an error code
0C01FF21 hex.
Does somebody knows what is the cause?
I'm using:
Windows XP pro
Visual Studio 2005
MPICH2 v 1.0.6p1 (I compiled the source code)
I start my server using the command
mpiexec -channel mt -n 5 CmdServer.exe
The application work well if I copy the port name manually.
Thanks
Andrea
William Gropp
Paul and Cynthia Saylor Professor of Computer Science
University of Illinois Urbana-Champaign
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080317/a99ca732/attachment.htm>
