[mpich-discuss] Heterogeneous systems
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Mar 12 16:50:16 CDT 2008
That should be called from within the mpich2 directory, where configure is
located.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Hisham Adel
Sent: Tuesday, March 11, 2008 11:54 PM
To: MPI; MPI_questions
Subject: Fwd: Re: [mpich-discuss] Heterogeneous systems
Hisham Adel <hosham2004 at yahoo.com> wrote:
Date: Tue, 11 Mar 2008 21:39:00 -0700 (PDT)
Subject: Re: [mpich-discuss] Heterogeneous systems
To: Pavan Balaji <balaji at mcs.anl.gov>
Thanks Pavan for your Fast reply.....
I wrote the command line in the terminal but it give me a message like this
"bash: ./configure: No such file or directory"
do u have any comments?
I'm a new user for MPI and Linux.I'm using SUSE Linux.
Thanks in advance
Pavan Balaji <balaji at mcs.anl.gov> wrote:
Forgot to CC the Hisham.
On 03/11/2008 11:18 PM, Pavan Balaji wrote:
> Even 1.0.7rc1 does not support heterogeneity. However, if you don't mind
> a small performance difference, you can just compile the code on the AMD
> system with a 32-bit compiler. Though I've not fully tested it, my
> initial testing seems to reveal that things work fine with this. Here's
> the configure command line if you need:
> $ CFLAGS=-m32 CXXFLAGS=-m32 FFLAGS=-m32 F90FLAGS=-m32 ./configure
> -- Pavan
> On 03/11/2008 10:26 PM, Hisham Adel wrote:
>> I'm working with MPICH2-1.0.6p1 and it don't support heterogeneous
>> systems,there is always fatal error.
>> is MPICH2-1.0.7 support heterogeneous systems?
>> I'm a new user and i'm working on a cluster of 3 Laptops one is
>> AMD 64-bit and the others are Intel 32-bit.
>> I have asked before about a Fatal error which appeared to me and
>> /Rajeev Thakur replied to me and told me that MPICH2 don't support
>> heterogeneous systems.Thanks //Rajeev Thakur/
>> Never miss a thing. Make Yahoo your homepage.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
  _____
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try
<http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR8
HDtDypao8Wcj9tAcJ%20> it now.
  _____
<http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs> your homepage.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080312/33127663/attachment.htm>
