[mpich-discuss] building 32 bit shmem on 64 bit linux system
Anthony Chan chan at mcs.anl.gov
Thu Jun 26 15:38:18 CDT 2008
Did you do a "make install" after "make" ?  If not, the install directory
may still have an older installation of mpich-1 which could be ch_p4
and not ch_shmem that you need.
A.Chan
----- "Daniel Fetchinson" <fetchinson at googlemail.com> wrote:
> > It must be the mpirun then. Make sure you use the mpirun from the
> same
> > build. Give the full path if necessary.
> > Rajeev
> Thanks, but there is only one installation of mpi on the machine and
> that installation is the one I keep compiling. So even if it wanted
> to
> execute the wrong mpicc/mpirun/etc it couldn't because there is only
> 1
> copy at any given time.
> Nevertheless I recompiled now mpi as well as my program and still I
> get the same error:
> 0 - MPI_INIT : MPIRUN chose the wrong device ch_shmem; program needs
> device ch_p4
> /home/fetchinson/mpich32shmem/bin/mpirun.ch_shmem: line 91: 21976
> Segmentation fault      /home/fetchinson/test "testinput"
> Any ideas?
> Daniel
> >> > Did you recompile the program? Make sure you use the mpicc
> >> from this
> >> > build and not some other mpicc from another directory. Give
> >> the full
> >> > path if necessary.
> >> > Rajeev
> >> Yes, I did recompile the program using mpicc from the newly
> >> built mpi library. Actually, there is only one mpicc on the
> >> whole machine.
> >> Cheers,
> >> Daniel
> >> >> Actually, I spoke a bit too soon. Configure, make, make
> >> install all
> >> >> work but the code still doesn't run, saying:
> >> program needs
> >> >> device ch_p4
> >> >> /home/fetchinson/mpi32shmem/bin/mpirun.ch_shmem: line 91: 17761
> >> >> The exact same code runs on another machine where someone else
> >> >> installed a 32-bit shmem mpich1 library, I'm trying to do
> >> the same on
> >> >> a different machine now. It's an intel quad core so I suppose
> the
> >> >> shmem device should work. The configure options I used for
> >> compiling
> >> >> are
> >> >> export CC='gcc -m32'
> >> >> export F77='g77 -m32'
> >> >> ./configure  --with-device=ch_shmem
> >> >> Do I need to specify the --with-arch option? Going through
> >> the list
> >> >> of available --with-arch options I'm not sure what I need for
> an
> >> >> Intel(R)
> >> >> Core(TM)2 Quad CPU Q6600 @ 2.40GHz.
> >> >> What am I doing wrong?
> >> >> Cheers,
> >> >> Daniel
> >> >> > Thanks Anthony, that worked!
> >> >> > Concerning MPICH2: I'm not in a position to change the
> >> >> communication
> >> >> > routines in the code  I use so this would only be an option
> >> >> if MPICH2
> >> >> > is fully backward compatible with MPICH1. Is this the case?
> >> >> Can I just
> >> >> > start using MPICH2 without changing anything in the code if
> >> >> it works
> >> >> > with MPICH1?
> >> >> > Cheers,
> >> >> > Daniel
> >> >> >> Since you are using MPICH-1, you can try setting CC, F77 and
> F90
> >> >> >> CC="gcc -m32"
> >> >> >> F77="g77 -m32"
> >> >> >> BTW, can you use MPICH2 instead ?  We have shifted all our
> >> >> >> development effort to MPICH2 which is more robust than
> >> >> MPICH-1.  If
> >> >> >> you are using MPICH2, setting CFLAGS and FFLAGS should
> >> >> work, and you
> >> >> >> can use nemesis which shared memory for intranode
> communication.
> >> >> >> A.Chan
> >> >> >>> Hi folks,
> >> >> >>> I'd like to build the 32-bit shmem mpi library because
> >> >> the code I'll
> >> >> >>> use with mpi only works in 32-bit because of some
> >> 32-bit specific
> >> >> >>> assembly code. The machine is a 64-bit machine with a
> >> >> 64-bit linux
> >> >> >>> distribution (suse).
> >> >> >>> I tried configuring mpich-1.2.7p1 in a number of ways:
> >> >> >>> ./configure --with-device=ch_shmem ./configure
> >> --with-arch=LINUX
> >> >> >>> --with-arch=LINUX32 --with-device=ch_shmem ./configure
> >> >> >>> --with-arch=i386 --with-device=ch_shmem
> >> >> >>> with and without setting the following environment
> >> variables (in
> >> >> >>> bash):
> >> >> >>> export CFLAGS=-m32
> >> >> >>> export FFLAGS=-m32
> >> >> >>> Configuring went all right but none of the above
> >> >> combinations worked
> >> >> >>> with 'make' unfortunately :( The error in 'make' is
> >> the following:
> >> >> >>> /home/fetchinson/mpich-1.2.7p1/bin/mpicc  -o overtake
> >> overtake.o
> >> >> >>> test.o
> >> >> /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse
> >> >> -linux/bin/ld:
> >> >> >>> skipping incompatible
> >> >> /home/fetchinson/mpich-1.2.7p1/lib/libmpich.a
> >> >> >>> when searching for -lmpich
> >> >> -linux/bin/ld:
> >> >> >>> cannot find -lmpich
> >> >> >>> collect2: ld returned 1 exit status
> >> >> >>> make[4]: *** [overtake] Error 1
> >> >> >>> make[3]: [linktest1] Error 2 (ignored) Could not link
> >> a C program
> >> >> >>> with MPI libraries
> >> >> >>> make[3]: *** [linktest1] Error 1
> >> >> >>> make[2]: *** [linktest] Error 2
> >> >> >>> make[1]: *** [mpi-lib-test] Error 2
> >> >> >>> make: *** [mpi] Error 2
> >> >> >>> Which makes me believe that I was not able to convince the
> >> >> >>> compiler/linker/etc that I really want everything in
> 32-bit.
> >> >> >>> What would be the correct way of compiling the whole mpi
> >> >> library to
> >> >> >>> 32-bit?
> >> >> >>> Cheers,
> >> >> >>> Daniel
> >> >> > Psss, psss, put it down! - http://www.cafepress.com/putitdown
