[mpich-discuss] building 32 bit shmem on 64 bit linux system
Daniel Fetchinson fetchinson at googlemail.com
Thu Jun 26 13:21:02 CDT 2008
> It is you to set up your system/env correctly for what ou need to get done.
> I set mine up to work with 6 platforms, including linux 32 and linux 64.
> and that is truely a piece of cake if you put in the time.
> tan
Well, I guess it's a piece of cake if you know what you need to do :)
I'm struggling because I'm not exactly sure on that, so I'm asking for
help here.
I've compiled mpi with CC='gcc -m32' and F77='g77 -m32' and
./configure --with-device=ch_shmem. After that I add the bin directory
of the mpi installation to my PATH. That's all I do and then things
don't work, mpirun is complaing about the wrong device.
Is there anything else I need to set? Tricky system/env settings?
Thanks a lot for any input,
Daniel
>> It must be the mpirun then. Make sure you use the mpirun from the same
>> build. Give the full path if necessary.
>> Rajeev
> Thanks, but there is only one installation of mpi on the machine and
> that installation is the one I keep compiling. So even if it wanted to
> execute the wrong mpicc/mpirun/etc it couldn't because there is only 1
> copy at any given time.
> Nevertheless I recompiled now mpi as well as my program and still I
> get the same error:
> 0 - MPI_INIT : MPIRUN chose the wrong device ch_shmem; program needs
> device ch_p4
> /home/fetchinson/mpich32shmem/bin/mpirun.ch_shmem: line 91: 21976
> Segmentation fault      /home/fetchinson/test "testinput"
> Any ideas?
> Daniel
>>> > Did you recompile the program? Make sure you use the mpicc
>>> from this
>>> > build and not some other mpicc from another directory. Give
>>> the full
>>> > path if necessary.
>>> > Rajeev
>>> Yes, I did recompile the program using mpicc from the newly
>>> built mpi library. Actually, there is only one mpicc on the
>>> whole machine.
>>> Cheers,
>>> Daniel
>>> >> Actually, I spoke a bit too soon. Configure, make, make
>>> install all
>>> >> work but the code still doesn't run, saying:
>>> program needs
>>> >> device ch_p4
>>> >> /home/fetchinson/mpi32shmem/bin/mpirun.ch_shmem: line 91:
> 17761
> "testinput"
>>> >> The exact same code runs on another machine where someone
> else
>>> >> installed a 32-bit shmem mpich1 library, I'm trying to do
>>> the same on
>>> >> a different machine now. It's an intel quad core so I
> suppose the
>>> >> shmem device should work. The configure options I used for
>>> compiling
>>> >> are
>>> >> export CC='gcc -m32'
>>> >> export F77='g77 -m32'
>>> >> Do I need to specify the --with-arch option? Going through
>>> the list
>>> >> of available --with-arch options I'm not sure what I need
> for an
>>> >> Intel(R)
>>> >> Core(TM)2 Quad CPU Q6600 @ 2.40GHz.
>>> >> What am I doing wrong?
>>> >> Cheers,
>>> >> Daniel
>>> >> > Thanks Anthony, that worked!
>>> >> > Concerning MPICH2: I'm not in a position to change
> the
>>> >> communication
>>> >> > routines in the code  I use so this would only be an
> option
>>> >> if MPICH2
>>> >> > is fully backward compatible with MPICH1. Is this the
> case?
>>> >> Can I just
>>> >> > start using MPICH2 without changing anything in the code
> if
>>> >> it works
>>> >> > with MPICH1?
>>> >> > Cheers,
>>> >> > Daniel
>>> >> >> Since you are using MPICH-1, you can try setting CC,
> F77 and F90
>>> >> >> CC="gcc -m32"
>>> >> >> F77="g77 -m32"
>>> >> >> BTW, can you use MPICH2 instead ?  We have shifted
> all our
>>> >> >> development effort to MPICH2 which is more robust
> than
>>> >> MPICH-1.  If
>>> >> >> you are using MPICH2, setting CFLAGS and FFLAGS
> should
>>> >> work, and you
>>> >> >> can use nemesis which shared memory for intranode
> communication.
>>> >> >> A.Chan
>>> >> >> ----- "Daniel Fetchinson"
> <fetchinson at googlemail.com> wrote:
>>> >> >>> Hi folks,
>>> >> >>> I'd like to build the 32-bit shmem mpi
> library because
>>> >> the code I'll
>>> >> >>> use with mpi only works in 32-bit because of
> some
>>> 32-bit specific
>>> >> >>> assembly code. The machine is a 64-bit machine
> with a
>>> >> 64-bit linux
>>> >> >>> distribution (suse).
>>> >> >>> I tried configuring mpich-1.2.7p1 in a number of
> ways:
>>> >> >>> ./configure --with-device=ch_shmem ./configure
>>> --with-arch=LINUX
>>> >> >>> --with-arch=LINUX32 --with-device=ch_shmem
> ./configure
>>> >> >>> --with-arch=i386 --with-device=ch_shmem
>>> >> >>> with and without setting the following
> environment
>>> variables (in
>>> >> >>> bash):
>>> >> >>> export CFLAGS=-m32
>>> >> >>> export FFLAGS=-m32
>>> >> >>> Configuring went all right but none of the above
>>> >> combinations worked
>>> >> >>> with 'make' unfortunately :( The error
> in 'make' is
>>> the following:
>>> >> >>> /home/fetchinson/mpich-1.2.7p1/bin/mpicc  -o
> overtake
>>> overtake.o
>>> >> >>> test.o
> /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse
>>> >> -linux/bin/ld:
>>> >> >>> skipping incompatible
>>> >> /home/fetchinson/mpich-1.2.7p1/lib/libmpich.a
>>> >> >>> when searching for -lmpich
>>> >> -linux/bin/ld:
>>> >> >>> cannot find -lmpich
>>> >> >>> collect2: ld returned 1 exit status
>>> >> >>> make[4]: *** [overtake] Error 1
>>> >> >>> make[3]: [linktest1] Error 2 (ignored) Could not
> link
>>> a C program
>>> >> >>> with MPI libraries
>>> >> >>> make[3]: *** [linktest1] Error 1
>>> >> >>> make[2]: *** [linktest] Error 2
>>> >> >>> make[1]: *** [mpi-lib-test] Error 2
>>> >> >>> make: *** [mpi] Error 2
>>> >> >>> Which makes me believe that I was not able to
> convince the
>>> >> >>> compiler/linker/etc that I really want
> everything in 32-bit.
>>> >> >>> What would be the correct way of compiling the
> whole mpi
>>> >> library to
>>> >> >>> 32-bit?
>>> >> >>> Cheers,
>>> >> >>> Daniel
>>> >> > Psss, psss, put it down! -
> http://www.cafepress.com/putitdown
>>> >> Psss, psss, put it down! - http://www.cafepress.com/putitdown
