[mpich-discuss] error while loading shared libraries: libsvml.so
Angel Arancibia angel.arancibia at gmail.com
Tue Jun 24 14:33:59 CDT 2008
> Hi Angel,
> you may want to add the line
> -Wl,-rpath,/opt/intel/cce/9.1.042/lib
> to you icc.cfg file (and a similar line to ifort.cfg, icpc.cfg)
> and then recompile. The problem appears to be that the library is
> not found at runtime.
> Cheers,
> Martin
Thanks Martin, that solved the problem.
Thanks all for the help and tips
Angel
