[mpich-discuss] error while loading shared libraries: libsvml.so
Martin Siegert siegert at sfu.ca
Tue Jun 24 11:49:56 CDT 2008
Hi Angel,
you may want to add the line
-Wl,-rpath,/opt/intel/cce/9.1.042/lib
to you icc.cfg file (and a similar line to ifort.cfg, icpc.cfg)
and then recompile. The problem appears to be that the library is
not found at runtime.
Cheers,
Martin
Martin Siegert
Head, Research Computing
WestGrid Site Lead
Client and Research Services               phone: 778 782-4691
Simon Fraser University                    fax:   778 782-4242
Burnaby, British Columbia                  email: siegert at sfu.ca
Canada  V5A 1S6
On Tue, Jun 24, 2008 at 11:56:40AM -0300, Angel Arancibia wrote:
> Hi Gus
> 2008/6/23 Gus Correa <gus at ldeo.columbia.edu>:
> > Hello Angel and list
> > Angel: This is just a guess, in case you are running your program on a
> > cluster,
> > based on a similar problem I had.
> > libsvml.so is an Intel compiler library.
> > Your Intel compiler is installed in /opt.
> Yes, that is correct.
> > If you are running the code on a cluster, /opt of your frontend machine,
> > where you compile programs, may not be automatically mounted on your
> > computing nodes.
> > These nodes may have their own /opt directories, but the Intel compiler and
> > libraries are not necessarily there.
> > Unless you explicitly export /opt to the computing nodes,
> > you will have trouble with shared libraries installed in /opt.
> > If this is really your problem, here are some alternative ways to get around
> > it.
> Nop, the /opt is a NFS partition, and it is exported to all the nodes.
> > 1) Statically link the Intel libraries (compile with -static-intel).
> > This requires recompilation of your code and of your MPICH2 libraries
> > (include -static-intel in your FFLAGS when you configure MPICH2).
> > This is relatively easy to do, the executable becomes bigger, but doesn't
> > require the Intel shared libraries.
> > Also, you can do this independently of your system administrator,
> > which may be an advantage, in case you are not the system administrator
> > yourself.
> That seems a good solution, although not the best. But if the problem
> persist I'm going to try it.
> > 2) Reinstall your Intel compiler in a directory that is exported to the
> > computing nodes.
> > Then recompile the code.
> > This may require the help of your system administrator.
> > 3) Export /opt to the computing nodes, and mount it there.
> > This may be tricky if the nodes already have their own /opt.
> > Again, this solution may depend on your system administrator help.
> 2 and 3 is currently done.
> > I hope this helps.
> > Gus Correa
> Thanks Gus.
> Angel
