[mpich-discuss] error while loading shared libraries: libsvml.so
REQUENA Stephane Stephane.REQUENA at ifp.fr
Mon Jun 23 13:59:50 CDT 2008
Hi Angel
The svml dynamic lib belongs to the intel compilers distribution, your line on the configure seems strange, i think you have
to define the needed variables prior to compile :
LDFLAGS="-L/usr/local/lib -L/opt/intel/fce/9.1.036/lib -L/opt/intel/cce/9.1.042/lib -lsvml -lpthread -lcrypto"
FFLAGS="-axW -O3 -fPIC -tpp7 -xT -fpe0 -I/opt/intel/fce/9.1.036/include -I/opt/intel/cce/9.1.042/include -c"
and then to compile
Hope it helps, best regards
Stéphane
-----Original Message-----
From: owner-mpich-discuss at mcs.anl.gov on behalf of Angel Arancibia
Sent: Mon 23/06/2008 20:16
Subject: [mpich-discuss] error while loading shared libraries: libsvml.so
Hi I compiled mpich2.1.0.7 with smpd (and intel compiler) but I can't
make it work.
The message is:
" /opt/mpi/mpich2-1.0.7/64/bin/smpd: error while loading shared
libraries: libsvml.so: cannot open shared object file: No such file or
directory "
It seems like a library path problem, but I can't find where. In the
configure, I passed the correct path
./configure --prefix=/opt/mpi/mpich2-1.0.7/64/ --with-pm=smpd
--with-pmi=smpd --enable-f90 'LDFLAGS=-L/usr/local/lib
-lpthread -lcrypto' 'FFLAGS=-axW -O3 -fPIC -tpp7 -xT -fpe0
-I/opt/intel/fce/9.1.036/include -I/opt/intel/cce/9.1.042/include -c'
2>&1 | tee config.txt
Then:
make 2>&1 | tee m.txt
make install 2>&1 | tee mi.txt
The complete message is :
(SGE script out)
aarancibia at cluster:~/job_examples/test-oport/test-AMD/64/mpihello$cat
mpich2_smpd.sh.po8918
Cargando Environment
MANPATH=/opt/mpi/mpich2-1.0.7/64/man:/opt/intel/cmkl/9.0/man:/opt/intel/fce/9.1.036/man:/opt/intel/cce/9.1.042/man:/home/sys/sge/man:/usr/share/man
HOSTNAME=era-q8.cluster.ifir.edu.ar
INTEL_LICENSE_FILE=/opt/intel/cce/9.1.042/licenses:/opt/intel/licenses:/home/aarancibia/intel/licenses:/opt/intel/fce/9.1.036/licenses:/opt/intel/licenses:/home/aarancibia/intel/licenses
SGE_TASK_STEPSIZE=undefined
SHELL=/bin/sh
TERM=linux
NHOSTS=1
SGE_O_WORKDIR=/home/aarancibia/job_examples/test-oport/test-AMD/64/mpihello
TMPDIR=/local/8918.1.amd-test
QUIET=no
SGE_O_HOME=/home/aarancibia
SGE_ARCH=lx24-amd64
SGE_CELL=default
RESTARTED=0
ARC=lx24-amd64
USER=aarancibia
LD_LIBRARY_PATH=/opt/mpi/mpich2-1.0.7/64/lib:/opt/intel/cmkl/9.0/lib/em64t:/opt/intel/fce/9.1.036/lib:/opt/intel/cce/9.1.042/lib
SGE_TASK_LAST=undefined
QUEUE=amd-test
SGE_TASK_ID=undefined
SGE_BINARY_PATH=/home/sys/sge/bin/lx24-amd64
PATH=/opt/mpi/mpich2-1.0.7/64/bin:/opt/intel/fce/9.1.036/bin:/opt/intel/cce/9.1.042/bin:/home/sys/sge/bin/lx24-amd64:/local/8918.1.amd-test:/usr/local/bin:/bin:/usr/bin
RUNLEVEL=2
runlevel=2
SGE_STDERR_PATH=/home/aarancibia/job_examples/test-oport/test-AMD/64/mpihello/mpich2_smpd.sh.po8918
UPSTART_EVENT=runlevel
F90=ifort
PWD=/home/aarancibia/job_examples/test-oport/test-AMD/64/mpihello
VERBOSE=yes
SGE_STDOUT_PATH=/home/aarancibia/job_examples/test-oport/test-AMD/64/mpihello/mpich2_smpd.sh.po8918
SGE_ACCOUNT=sge
JOB_SCRIPT=/local/sys/sge//era-q8/job_scripts/8918
JOB_NAME=mpich2_smpd.sh
SGE_ROOT=/home/sys/sge
previous=N
PREVLEVEL=N
F77=ifort
REQNAME=mpich2_smpd.sh
CXX=icc
SGE_JOB_SPOOL_DIR=/local/sys/sge//era-q8/active_jobs/8918.1
ENVIRONMENT=BATCH
PE_HOSTFILE=/local/sys/sge//era-q8/active_jobs/8918.1/pe_hostfile
SHLVL=1
SGE_CWD_PATH=/home/aarancibia/job_examples/test-oport/test-AMD/64/mpihello
NQUEUES=1
SGE_O_LOGNAME=aarancibia
SGE_O_MAIL=/var/mail/aarancibia
TMP=/local/8918.1.amd-test
JOB_ID=8918
LOGNAME=aarancibia
PE=mpich2-testing
SGE_TASK_FIRST=undefined
SGE_O_PATH=/home/sys/scripts/checks:/home/sys/scripts/fixs:/opt/mpi/mpich2-1.0.5p4/feisty-32/bin:/opt/intel/fc/9.1.036/bin:/opt/intel/cc/9.1.042/bin:/home/sys/sge/bin/lx24-x86:/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/bin/X11:/usr/games:/usr/local/condor/bin:/usr/local/condor/sbin:/opt/intel/fortran/stable/bin:/opt/intel/cc/stable/bin
UPSTART_JOB=rc2
CC=icc
SGE_O_HOST=cluster
SGE_O_SHELL=/bin/bash
REQUEST=mpich2_smpd.sh
UPSTART_JOB_ID=3
INCLUDE=/opt/intel/cmkl/9.0/include:
NSLOTS=4
SGE_STDIN_PATH=/dev/null
_=/usr/bin/env
era-q8
-catch_rsh /local/sys/sge//era-q8/active_jobs/8918.1/pe_hostfile
era-q8
era-q8
era-q8
era-q8
startmpich2.sh: check for smpd daemons (1 of 10)
corriendo rsh
era-q8
/home/sys/sge/bin/lx24-amd64/qrsh -inherit era-q8
/opt/mpi/mpich2-1.0.7/64/bin/smpd -port 23918 -d 0
startmpich2.sh: missing smpd on era-q8
Pseudo-terminal will not be allocated because stdin is not a terminal.
directory
startmpich2.sh: check for smpd daemons (2 of 10)
startmpich2.sh: check for smpd daemons (3 of 10)
startmpich2.sh: check for smpd daemons (4 of 10)
startmpich2.sh: check for smpd daemons (5 of 10)
startmpich2.sh: check for smpd daemons (6 of 10)
startmpich2.sh: check for smpd daemons (7 of 10)
startmpich2.sh: check for smpd daemons (8 of 10)
startmpich2.sh: check for smpd daemons (9 of 10)
startmpich2.sh: check for smpd daemons (10 of 10)
startmpich2.sh: got only 0 of 1 nodes, aborting
-catch_rsh /opt/mpi/mpich2-1.0.7/64
directory
Thanks in advance
Angel Arancibia
__________________________
Ce message (et toutes ses pièces jointes éventuelles) est confidentiel et établi à l'intention exclusive de ses destinataires. Toute utilisation de ce message non conforme à sa destination, toute diffusion ou toute publication, totale ou partielle, est interdite, sauf autorisation expresse. L'IFP décline toute responsabilité au titre de ce message.
This message and any attachments (the message) are confidential and intended solely for the addressees. Any unauthorised use or dissemination is prohibited. IFP should not be liable for this message.
Visitez notre site Web / Visit our web site : http://www.ifp.fr
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080623/7a17315c/attachment.htm>
