[mpich-discuss] ROMIO individual file pointer
Wei-keng Liao
wkliao at ece.northwestern.edu
Tue Jun 17 23:51:36 CDT 2008
In ROMIO romio/adio/common/ad_set_view.c, line 60 states the individual
file point, fd->fp_ind points to the first byte to be accessed. I can see
fd->fp_ind is set to the right value in this file.
However, in romio/adio/common/ad_read_coll.c, function
ADIOI_Calc_my_off_len() line 443, fd->fp_ind is set to the value of
variable "off". Now, the problem is how "off" is calculated. From the
codes between lines 428 and 438, "off" is moved up to the next flat_file
segment, index j. Since flat_file may contains an empty-length element
(either first or last) whose blocklens[] is equal to zero, when user
buffer size "bufsize" is filled, "off" will not moved to the first byte to
be accessed in the next collective I/O.
This problem appears when I defined a non-contiguous file view and did two
collective I/O consecutively, each requesting data size equal to one whole
file view. Then at the beginning of the second collective I/O, fd->fp_ind
of all processes are having the same value, pointing to the beginning of
the second file view, instead of individual starting offset.
The attached codes demonstrate this problem. If a printf statement for
fd->fp_ind is inserted at the beginning of ADIOI_GEN_WriteStridedColl() in
file ad_write_coll.c, the standard outputs are
0: First collective write -----------------------
0: fd->fpind = 0
1: fd->fpind = 5
2: fd->fpind = 50
3: fd->fpind = 55
0: Second collective write -----------------------
0: fd->fpind = 100
1: fd->fpind = 100 <-- not right
2: fd->fpind = 100 <-- not right
3: fd->fpind = 100 <-- not right
The correct results for the second collective write should be:
0: fd->fpind = 100
1: fd->fpind = 105
2: fd->fpind = 150
3: fd->fpind = 155
My fix to this probelm is to insert the following codes in between
lines 435 and 436 of file ad_read_coll.c.
while (flat_file->blocklens[j]==0) {
j++;
if (j == flat_file->count) {
j = 0;
n_filetypes++;
Wei-keng
#include <stdio.h>
#include <stdlib.h>
#include <mpi.h>
/*----< main() >------------------------------------------------------------*/
int main(int argc, char **argv) {
int rank, np;
char buf[25];
int array_of_sizes[2], array_of_subsizes[2], array_of_starts[2];
MPI_File fh;
MPI_Datatype ftype;
MPI_Status status;
MPI_Init(&argc, &argv);
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &np);
if (argc != 2) {
if (!rank)fprintf(stderr,"Usage: %s filename\n",argv[0]);
MPI_Finalize(); return 1;
if (np != 4) {
if (!rank)fprintf(stderr,"Require 4 MPI processes ... exiting\n");
/*---- Set up MPI file view ---------------------------------------------*/
array_of_sizes[0] = array_of_sizes[1] = 10;
array_of_subsizes[0] = array_of_subsizes[1] = 5;
if (rank == 0 || rank == 1) array_of_starts[0] = 0;
if (rank == 2 || rank == 3) array_of_starts[0] = 5;
if (rank == 0 || rank == 2) array_of_starts[1] = 0;
if (rank == 1 || rank == 3) array_of_starts[1] = 5;
MPI_Type_create_subarray(2, array_of_sizes, array_of_subsizes,
array_of_starts, MPI_ORDER_C, MPI_CHAR, &ftype);
MPI_Type_commit(&ftype);
/* open the file --------------------------------------------------------*/
MPI_File_open(MPI_COMM_WORLD, argv[1], MPI_MODE_CREATE | MPI_MODE_WRONLY,
MPI_INFO_NULL, &fh);
MPI_File_set_view(fh, 0, MPI_BYTE, ftype, "native", MPI_INFO_NULL);
if (!rank) printf("First collective write -----------------------\n");
MPI_File_write_all(fh, buf, 25, MPI_CHAR, &status);
fflush(stdout);
if (!rank) printf("Second collective write -----------------------\n");
MPI_File_close(&fh);
MPI_Finalize();
return 0;
