No subject
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Jul 24 12:21:17 CDT 2008
This is a multi-part message in MIME format.
--Gecko------------1216918185----_
Content-Type: text/plain
>  Hi,
> What is the error that you get (after installing openssl) when you run
> configure/make (Provide us with the configure.log -- the output of
> configure command, config.log & make.log -- output of make command)?
The configure command that I ran is listed as follows.
./mpich2-1.0.7/configure --with-pm=smpd --disable-f77 --disable-f90
--disable-cxx MPICH2LIB_CFLAGS="-fPIC /home/cycchou/openssl-0.9.8/include"
MPICH2LIB_LDFLAGS=-L/home/cycchou/openssl-0.9.8/lib
--prefix=/home/cycchou/mpich2
The output of the configure command regarding the failure is listed as follows.
checking for library containing MD5... no
checking for MD5... no
checking for library containing md5_calc... no
checking for md5_calc function... no
configure: error: SMPD requires MD5 support, and configure could not find
either md5_calc in md5.h or MD5 in openssl/md5.h
configure: error: Configure of src/pm/smpd failed!
I've also attached the config.log to this email.
Thank you very much
-Yucheng
Content-Type: application/octet-stream
Content-Description: config.log
Content-Disposition: attachment; filename=config.log
Content-Transfer-Encoding: base64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--Gecko------------1216918185----_--
