[mpich-discuss] Why is my quad core slower than cluster
Gus Correa
gus at ldeo.columbia.edu
Tue Jul 8 14:52:19 CDT 2008
PS:
Zach: A couple of obvious checks, besides Rajeev's important suggestion:
1) Make sure the SMP kernel is running on your home PC:
"uname -a"
(Should show "smp" as part of the string.)
2) Check if Ubuntu triggers all four cores:
"cat /proc/cpuinfo".
(Should show four "virtual" CPUs.)
Gus Correa
Rajeev Thakur wrote:
Try using the Nemesis device in MPICH2 if you aren't already. Configure with
--with-device=ch3:nemesis.
Rajeev
Gus Correa wrote:
> Hello Zach and list
> From all that I've observed on dual-processor dual-core PCs,
> and from all that I've read on the web about dual-processor quad-core
> machines,
> your results are not alarming, but typical.
> I was as disappointed as you are, when I saw my speedup results.
> A lot of people out there had the same frustration too.
> My benchmarks using a standard climate atmospheric model (NCAR CAM3) on
> a dual-processor dual-core Xeon workstation showed a speedup factor of
> 3 (not 4),
> when I moved from one core to four cores.
> Likewise for a dual-processor dual-core Opteron workstation,
> I've got a speedup factor slightly below 3.5. (Better than Xeon, but
> still not 4).
> The problem seems to get worse with quad-cores, again with the
> Opterons slightly ahead of the game.
> Memory/bus contention has been mentioned as the culprit by a lot of
> people.
> One core in a multicore doesn't scale as one (single-core) CPU.
> You will find plenty of references to this problem on the web and on
> many mailing lists:
> here in the MPICH list, on the Rocks Cluster list, on the MITgcm list,
> etc, etc.
> I hope it heals (as helping it cannot)
> Gus Correa
zach wrote:
> I am using a cluster.
> Each pc has two cpus and they are Xeon. Each cpu has 4GB, i think red
> hat is running.
> I also use a pc at home- quad core intel chip, 8gb ram, ubuntu.
> Both are using mpich.
> I have found that my home pc is only running about 1/3 the speed of
> the cluster, and the number of processes (4) and code is the same.
> Can anyone tell me if this is typical, and why, or am I not optimizing
> something properly?
> Thanks
> Zach
