[MPICH] p4 error
Sangamesh B
forum.san at gmail.com
Thu Jan 31 01:10:18 CST 2008
Hi All,
Installed MPICH with Intel Compilers. Configure is as follows:
./configure --prefix=/opt/MPI_LIBS/MPICH-Intel
-cc=/opt/intel/cce/10.1.008/bin/icc
-fc=/opt/intel/fce/10.1.008/bin/ifort --enable-f77 --with-device=ch_p4
--with-arch=LINUX
When I run a CPMD job with 1-4 proceses, the job is getting killed and gives
following error:
# mpirun -machinefile /export/M4 -np 4 ./cpmd.x
/opt/APPLICATIONS/CPMD/singlemol.input > single4.out
Killed by signal 2.
forrtl: error (69): process interrupted (SIGINT)
Killed by signal 2.
Killed by signal 2.
If only one process is used and without redirection, the following error
occurred:
p0_16857: p4_error: interrupt SIGSEGV: 11
And the serial job works fine without any errors.
Can anybody explain what might be the cause for this?
Thanks & regards,
Sangamesh
HPC Engineer
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080131/ca304e45/attachment.htm>
