[MPICH] mpich2-1.0.3 configure: error: C compiler cannot create executables
    spam.me at gmx.info
    spam.me at gmx.info
    Tue Jan 29 16:29:03 CST 2008
Good evening!
Thanks for your hints. The problem is fixed.
Byby
-------- Original-Nachricht --------
> Datum: Tue, 29 Jan 2008 15:20:54 -0600 (CST)
> Von: Anthony Chan <chan at mcs.anl.gov>
> An: Darius Buntinas <buntinas at mcs.anl.gov>
> CC: spam.me at gmx.info, mpich-discuss at mcs.anl.gov
> Betreff: Re: [MPICH] mpich2-1.0.3 configure: error: C compiler cannot create executables
> Also do "unset CXXFLAGS" if you need C++ support.
> On Tue, 29 Jan 2008, Darius Buntinas wrote:
> > It looks like you might have CFLAGS and LDFLAGS set to -m32, but your
> new
> > machines ias a 64-bit OS installed.  Try this to unset those variables
> > (assuming you're running bash):
> >  unset CFLAGS
> >  unset LDFLAGS
> > and give it a try again.  If this works, look in your .bashrc or
> > .bash_profile to see if you're setting those there.
> > -d
> > On 01/29/2008 03:05 PM, spam.me at gmx.info wrote:
> >> Hello!
> >> I used for a long time a 2xXEON 2,4GHz Workstation with Debian Sarge.
> Now I
> >> changed to a new AMD Athlon X2 computer and installed Kubuntu - Gutsy.
> >> But unfortunately, I get the following error by the configure-command.
> >> What's happend and what can I do to solve the problem?
> >> Thanks a lot!
> >> # | command |
> >> hoffi at Blade:~/install/src/mpich2-1.0.3$ ./configure
> --prefix=$HOME/install
> >> Configuring MPICH2 version 1.0.3 with --prefix=/home/hoffi/install
> >> sourcing /home/hoffi/install/src/mpich2-1.0.3/src/pm/mpd/setup_pm
> >> checking for gcc... gcc
> >> checking for C compiler default output file name... configure: error: C
> >> See `config.log' for more details.
> >> # | config.log |
> >> This file contains any messages produced by compilers while
> >> running configure, to aid debugging if configure makes a mistake.
> >> It was created by configure, which was
> >> generated by GNU Autoconf 2.59.  Invocation command line was
> >>   $ ./configure --prefix=/home/hoffi/install
> >> ## Platform. ##
> >> hostname = Blade
> >> uname -m = x86_64
> >> uname -r = 2.6.22-14-generic
> >> uname -s = Linux
> >> uname -v = #1 SMP Tue Dec 18 05:28:27 UTC 2007
> >> /usr/bin/uname -p = unknown
> >> /bin/uname -X     = unknown
> >> /bin/arch              = unknown
> >> /usr/bin/arch -k       = unknown
> >> /usr/convex/getsysinfo = unknown
> >> hostinfo               = unknown
> >> /bin/machine           = unknown
> >> /usr/bin/oslevel       = unknown
> >> /bin/universe          = unknown
> >> PATH: /home/hoffi/bin
> >> PATH:
> /home/hoffi/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/bin
> >> PATH:
> /home/hoffi/OpenFOAM/OpenFOAM-1.3/src/mico-2.3.11/platforms/linuxGcc4DPOpt/bin
> >> PATH: /home/hoffi/OpenFOAM/linux/j2sdk1.4.2_05/bin
> >> PATH: /home/hoffi/OpenFOAM/hoffi-1.3/applications/bin/linuxGcc4DPOpt
> >> PATH: /home/hoffi/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt
> >> PATH: /home/hoffi/OpenFOAM/OpenFOAM-1.3/wmake
> >> PATH: /home/hoffi/OpenFOAM/OpenFOAM-1.3/bin
> >> PATH: /usr/local/sbin
> >> PATH: /usr/local/bin
> >> PATH: /usr/sbin
> >> PATH: /usr/bin
> >> PATH: /sbin
> >> PATH: /bin
> >> PATH: /usr/games
> >> ## Core tests. ##
> >> configure:2719: checking for gcc
> >> configure:2745: result: gcc
> >> configure:2989: checking for C compiler version
> >> configure:2992: gcc --version </dev/null >&5
> >> gcc (GCC) 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)
> >> Copyright (C) 2006 Free Software Foundation, Inc.
> >> This is free software; see the source for copying conditions.  There is
> NO
> >> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE.
> >> configure:2995: $? = 0
> >> configure:2997: gcc -v </dev/null >&5
> >> Using built-in specs.
> >> Target: x86_64-linux-gnu
> >> Configured with: ../src/configure -v
> >> --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr
> >> --enable-shared --with-system-zlib --libexecdir=/usr/lib
> >> --without-included-gettext --enable-threads=posix --enable-nls
> >> --with-gxx-include-dir=/usr/include/c++/4.1.3 --program-suffix=-4.1
> >> --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug
> >> --enable-mpfr --enable-checking=release x86_64-linux-gnu
> >> Thread model: posix
> >> gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)
> >> configure:3000: $? = 0
> >> configure:3002: gcc -V </dev/null >&5
> >> gcc: '-V' option must have argument
> >> configure:3005: $? = 1
> >> configure:3028: checking for C compiler default output file name
> >> configure:3031: gcc -m32  -m32 conftest.c  >&5
> >> /usr/bin/ld: skipping incompatible
> >> /usr/lib/gcc/x86_64-linux-gnu/4.1.3/libgcc.a when searching for -lgcc
> >> /usr/bin/ld: cannot find -lgcc
> >> collect2: ld returned 1 exit status
> >> configure:3034: $? = 1
> >> configure: failed program was:
> >> | /* confdefs.h.  */
> >> | | #define PACKAGE_NAME ""
> >> | #define PACKAGE_TARNAME ""
> >> | #define PACKAGE_VERSION ""
> >> | #define PACKAGE_STRING ""
> >> | #define PACKAGE_BUGREPORT ""
> >> | #define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
> >> | #define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
> >> | #define USE_LOGGING MPID_LOGGING_NONE
> >> | #define MPICH_SINGLE_THREADED 1
> >> | #define MPICH_THREAD_LEVEL MPI_THREAD_FUNNELED
> >> | #define USE_THREAD_IMPL MPICH_THREAD_IMPL_NONE
> >> | #define HAVE_ROMIO 1
> >> | /* end confdefs.h.  */
> >> | | int
> >> | main ()
> >> |   return 0;
> >> configure:3073: error: C compiler cannot create executables
> >> ## Cache variables. ##
> >> ac_cv_env_CC_set=set
> >> ac_cv_env_CC_value=gcc
> >> ac_cv_env_CFLAGS_set=set
> >> ac_cv_env_CFLAGS_value=-m32
> >> ac_cv_env_CPPFLAGS_set=
> >> ac_cv_env_CPPFLAGS_value=
> >> ac_cv_env_CPP_set=
> >> ac_cv_env_CPP_value=
> >> ac_cv_env_CXXFLAGS_set=set
> >> ac_cv_env_CXXFLAGS_value=-m32
> >> ac_cv_env_CXX_set=set
> >> ac_cv_env_CXX_value=g++
> >> ac_cv_env_F77_set=
> >> ac_cv_env_F77_value=
> >> ac_cv_env_F90FLAGS_set=
> >> ac_cv_env_F90FLAGS_value=
> >> ac_cv_env_F90_set=
> >> ac_cv_env_F90_value=
> >> ac_cv_env_FFLAGS_set=
> >> ac_cv_env_FFLAGS_value=
> >> ac_cv_env_LDFLAGS_set=set
> >> ac_cv_env_LDFLAGS_value=-m32
> >> ac_cv_env_build_alias_set=
> >> ac_cv_env_build_alias_value=
> >> ac_cv_env_host_alias_set=
> >> ac_cv_env_host_alias_value=
> >> ac_cv_env_target_alias_set=
> >> ac_cv_env_target_alias_value=
> >> ac_cv_prog_ac_ct_CC=gcc
> >> pac_cv_my_conf_dir=/home/hoffi/install/src/mpich2-1.0.3
> >> ## Output variables. ##
> >> ADDRESS_KIND=''
> >> ALLOCA=''
> >> AR=''
> >> BSEND_OVERHEAD=''
> >> BUILD_TVDLL=''
> >> CC='gcc'
> >> CC_SHL=''
> >> CC_SHL_DBG=''
> >> CFLAGS='-m32'
> >> CONFIGURE_ARGUMENTS='--prefix=/home/hoffi/install'
> >> CPP=''
> >> CPPFLAGS=''
> >> CREATESHLIB=''
> >> CXX='g++'
> >> CXXFLAGS='-m32'
> >> CXX_LINKPATH_SHL=''
> >> CXX_SHL=''
> >> C_LINKPATH_SHL=''
> >> C_LINK_SHL=''
> >> C_LINK_SHL_DBG=''
> >> DEFS=''
> >> DEVICE='ch3'
> >> DLLIMPORT=''
> >> DOCTEXT=''
> >> DOCTEXTSTYLE=''
> >> ECHO_C=''
> >> ECHO_N='-n'
> >> ECHO_T=''
> >> EGREP=''
> >> ENABLE_SHLIB=''
> >> ETAGS=''
> >> ETAGSADD=''
> >> EXAMPLE_LIBS=''
> >> EXEEXT=''
> >> EXTERNAL_SRC_DIRS=''
> >> EXTRA_STATUS_DECL=''
> >> F77=''
> >> F77CPP=''
> >> F77_COMPLEX16=''
> >> F77_COMPLEX32=''
> >> F77_COMPLEX8=''
> >> F77_INCDIR=''
> >> F77_INTEGER16=''
> >> F77_INTEGER1=''
> >> F77_INTEGER2=''
> >> F77_INTEGER4=''
> >> F77_INTEGER8=''
> >> F77_IN_C_LIBS=''
> >> F77_LIBDIR_LEADER=''
> >> F77_NAME_MANGLE=''
> >> F77_REAL16=''
> >> F77_REAL4=''
> >> F77_REAL8=''
> >> F90=''
> >> F90CPP=''
> >> F90EXT=''
> >> F90FLAGS=''
> >> F90INC=''
> >> F90INCFLAG=''
> >> F90MODEXT=''
> >> F90MODINCFLAG=''
> >> F90MODINCSPEC=''
> >> F90_LINKPATH_SHL=''
> >> F90_SHL=''
> >> F90_WORK_FILES_ARG=''
> >> FC=''
> >> FC_LINKPATH_SHL=''
> >> FC_SHL=''
> >> FFLAGS=''
> >> FINCLUDES=''
> >> FLIBS=''
> >> FWRAPNAME='fmpich'
> >> GCC=''
> >> HAVE_CXX_EXCEPTIONS=''
> >> HAVE_ROMIO='#include "mpio.h"'
> >> INCLUDE_MPICXX_H=''
> >> INSTALL_DATA=''
> >> INSTALL_PROGRAM=''
> >> INSTALL_SCRIPT=''
> >> INT16_T=''
> >> INT32_T=''
> >> INT64_T=''
> >> LDFLAGS='-m32'
> >> LIBOBJS=''
> >> LIBS=''
> >> LIBTOOL=''
> >> LTLIBOBJS=''
> >> MAKE=''
> >> MAKE_DEPEND_C=''
> >> MANY_PM='no'
> >> MKDIR_P=''
> >> MPE_THREAD_LIB_NAME=''
> >> MPICC=''
> >> MPICH_TIMER_KIND=''
> >> MPICVSHOME=''
> >> MPICXX=''
> >> MPICXXLIBNAME='mpichcxx'
> >> MPID_TIMER_TYPE=''
> >> MPIF77=''
> >> MPIF90=''
> >> MPIFLIBNAME='mpich'
> >> MPIFPMPI=''
> >> MPILIBNAME='mpich'
> >> MPIMODNAME=''
> >> MPIU_DLL_SPEC_DEF=''
> >> MPI_2COMPLEX=''
> >> MPI_2DOUBLE_COMPLEX=''
> >> MPI_2DOUBLE_PRECISION=''
> >> MPI_2INT=''
> >> MPI_2INTEGER=''
> >> MPI_2REAL=''
> >> MPI_AINT=''
> >> MPI_BYTE=''
> >> MPI_CFLAGS=''
> >> MPI_CHAR=''
> >> MPI_CHARACTER=''
> >> MPI_COMPLEX16=''
> >> MPI_COMPLEX32=''
> >> MPI_COMPLEX8=''
> >> MPI_COMPLEX=''
> >> MPI_CXXFLAGS=''
> >> MPI_DOUBLE=''
> >> MPI_DOUBLE_COMPLEX=''
> >> MPI_DOUBLE_INT=''
> >> MPI_DOUBLE_PRECISION=''
> >> MPI_F77_BYTE=''
> >> MPI_F77_LB=''
> >> MPI_F77_PACKED=''
> >> MPI_F77_UB=''
> >> MPI_F90FLAGS=''
> >> MPI_FFLAGS=''
> >> MPI_FINT=''
> >> MPI_FLOAT=''
> >> MPI_FLOAT_INT=''
> >> MPI_INT=''
> >> MPI_INTEGER16=''
> >> MPI_INTEGER1=''
> >> MPI_INTEGER2=''
> >> MPI_INTEGER4=''
> >> MPI_INTEGER8=''
> >> MPI_INTEGER=''
> >> MPI_LB=''
> >> MPI_LDFLAGS=''
> >> MPI_LOGICAL=''
> >> MPI_LONG=''
> >> MPI_LONG_DOUBLE=''
> >> MPI_LONG_DOUBLE_INT=''
> >> MPI_LONG_INT=''
> >> MPI_LONG_LONG=''
> >> MPI_MAX_PROCESSOR_NAME=''
> >> MPI_OFFSET=''
> >> MPI_OFFSET_TYPEDEF=''
> >> MPI_PACKED=''
> >> MPI_REAL16=''
> >> MPI_REAL4=''
> >> MPI_REAL8=''
> >> MPI_REAL=''
> >> MPI_SHORT=''
> >> MPI_SHORT_INT=''
> >> MPI_SIGNED_CHAR=''
> >> MPI_STATUS_SIZE=''
> >> MPI_UB=''
> >> MPI_UNSIGNED_CHAR=''
> >> MPI_UNSIGNED_INT=''
> >> MPI_UNSIGNED_LONG=''
> >> MPI_UNSIGNED_LONG_LONG=''
> >> MPI_UNSIGNED_SHORT=''
> >> MPI_WCHAR=''
> >> NEEDSPLIB=''
> >> NO_WEAK_SYM=''
> >> NO_WEAK_SYM_TARGET=''
> >> OBJEXT=''
> >> OFFSET_KIND=''
> >> PACKAGE_BUGREPORT='mpich2-maint at mcs.anl.gov'
> >> PACKAGE_NAME='MPICH2'
> >> PACKAGE_STRING=''
> >> PACKAGE_TARNAME='mpich2-1.0.3'
> >> PACKAGE_VERSION='1.0.3'
> >> PATH_SEPARATOR=':'
> >> PERL5=''
> >> PERL=''
> >> PMPIFLIBNAME='pmpich'
> >> PMPILIBNAME='pmpich'
> >> PROFILE_DEF_MPI=''
> >> RANLIB=''
> >> RANLIB_AFTER_INSTALL=''
> >> SET_CFLAGS=''
> >> SET_MAKE=''
> >> SHELL='/bin/bash'
> >> SHLIB_EXT=''
> >> SHLIB_FROM_LO=''
> >> SHLIB_INSTALL=''
> >> SIZEOF_MPI_STATUS=''
> >> TESTCPP=''
> >> THR_CFLAGS=''
> >> THR_CPPFLAGS=''
> >> THR_DEFS=''
> >> THR_LDFLAGS=''
> >> THR_LIBS=''
> >> VERSION='1.0.3'
> >> VPATH=''
> >> ac_ct_CC='gcc'
> >> ac_ct_CXX=''
> >> ac_ct_F77=''
> >> ac_ct_F90=''
> >> ac_ct_RANLIB=''
> >> bindings=''
> >> bindings_dirs=''
> >> bindir='${exec_prefix}/bin'
> >> build_alias=''
> >> datadir='${prefix}/share'
> >> debugger_dir=''
> >> device_name='ch3'
> >> docdir='${prefix}/doc'
> >> exec_prefix='NONE'
> >> host_alias=''
> >> htmldir='${prefix}/www'
> >> includedir='${prefix}/include'
> >> infodir='${prefix}/info'
> >> libdir='${exec_prefix}/lib'
> >> libexecdir='${exec_prefix}/libexec'
> >> localstatedir='${prefix}/var'
> >> logging_dir=''
> >> logging_name='none'
> >> logging_subdirs=''
> >> mandir='${prefix}/man'
> >> master_top_builddir='/home/hoffi/install/src/mpich2-1.0.3'
> >> master_top_srcdir='/home/hoffi/install/src/mpich2-1.0.3'
> >> modincdir=''
> >> mpe_dir='mpe2'
> >> nameserv_name=''
> >> oldincludedir='/usr/include'
> >> other_install_dirs=' src/pm/mpd src/mpe2'
> >> other_pm_names=''
> >> pac_prog=''
> >> pm_name='mpd'
> >> pmi_name='simple'
> >> prefix='/home/hoffi/install'
> >> program_transform_name='s,x,x,'
> >> romio_dir='romio'
> >> sbindir='${exec_prefix}/sbin'
> >> sharedstatedir='${prefix}/com'
> >> subdirs=''
> >> subsystems=' src/mpi/romio src/pmi/simple src/pm/mpd src/mpe2'
> >> sysconfdir='${prefix}/etc'
> >> target_alias=''
> >> ## Output files. ##
> >> MPE_THREAD_FUNCS=''
> >> MPE_THREAD_TYPEDEFS=''
> >> ## confdefs.h. ##
> >> configure: exit 77
