[MPICH] Bug in mpiexec_rsh.c builds wrong command line
    Reuti
    reuti at staff.uni-marburg.de
    Mon Jan 28 15:47:24 CST 2008
Am 28.01.2008 um 21:13 schrieb Jayesh Krishna:
>   After fixing the bug (mentioned below) does SGE work with the latest
> version of MPICH2 (Is there any other problems that you see with
> MPICH2+SGE)
yes, it's working after the patch. For now I'm not aware of
additional problems to integrate in in SGE.
-- Reuti
> Regards,
> Jayesh
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jayesh Krishna
> Sent: Friday, January 25, 2008 5:19 PM
> To: 'Reuti'
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] Bug in mpiexec_rsh.c builds wrong command line
>  Hi,
>   Thanks for reporting the bug.
>   This bug with be fixed in the next release.
> Regards,
> Jayesh
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Reuti
> Sent: Friday, January 25, 2008 4:33 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Bug in mpiexec_rsh.c builds wrong command line
> Hi,
> one user of SGE noticed, that the daemonless smpd startup isn't
> working any
> longer in MPICH2 1.0.6p1 (http://gridengine.sunsource.net/
> howto/mpich2-integration/mpich2-integration.html). After he and I
> digged in
> the code, we found in mpich2-1.0.6p1/src/pm/smpd/ mpiexec_rsh.c a
> bug. Line
> 472 must be changed from:
> pExe += curLen;
> to
> pExe = process->exe + curLen;
> Otherwise the string will not correctly be built, as curLen is
> added to pExe
> again, which is already pointing to a location somewhere in the
> middle of
> the string.
> -- Reuti
