[MPICH] Bug in mpiexec_rsh.c builds wrong command line
Jayesh Krishna jayesh at mcs.anl.gov
Mon Jan 28 14:13:16 CST 2008
  After fixing the bug (mentioned below) does SGE work with the latest
version of MPICH2 (Is there any other problems that you see with MPICH2+SGE)
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Friday, January 25, 2008 5:19 PM
To: 'Reuti'
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] Bug in mpiexec_rsh.c builds wrong command line
  Thanks for reporting the bug.
  This bug with be fixed in the next release.
Jayesh
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Reuti
Sent: Friday, January 25, 2008 4:33 PM
Subject: [MPICH] Bug in mpiexec_rsh.c builds wrong command line
one user of SGE noticed, that the daemonless smpd startup isn't working any
longer in MPICH2 1.0.6p1 (http://gridengine.sunsource.net/
howto/mpich2-integration/mpich2-integration.html). After he and I digged in
the code, we found in mpich2-1.0.6p1/src/pm/smpd/ mpiexec_rsh.c a bug. Line
472 must be changed from:
pExe += curLen;
to
pExe = process->exe + curLen;
Otherwise the string will not correctly be built, as curLen is added to pExe
again, which is already pointing to a location somewhere in the middle of
the string.
-- Reuti
