[MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
    madfran
    madfran at set-ezine.org
    Wed Jan 16 18:50:59 CST 2008
Hi,...
1) ok
2) With the cpi.exe found in the directory
   c:\Program Files\MPICH2\bin
   and specifying  1000000000 I see both processors working at 100%
3) Both
   I installed from msi and compiled under cygwin.
   It is a mistake ?
madfran
On Mon, 14 Jan 2008 11:27:37 -0600, Jayesh Krishna wrote
> Hi,
> 1) You do not need to install mpiexec (you only need to install smpd)
>  to use it.
> 2) Try specifying a higher number of iterations (say
> 1000) when running cpi.exe.
> 3) Have you installed the windows
> version of MPICH2 from the installer ? (Or have you compiled MPICH2
> under cygwin ?)
> Regards,
> Jayesh
> -----Original Message-----
> From: madfran [mailto:madfran at set-ezine.org]
> Sent: Saturday, January 12, 2008 1:06 PM
> To: Jayesh Krishna
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
> Hi,...
> >  >>>... execute "smpd.exe -install"."
> >  >>>> In my WinXP, dont work.
> > 	This should work. Is there any specific error message that you see
> > (Is smpd not working the way it is supposed to ?)?
> The problem is they are no way to register and validate user/pass because
> mpiexec is it not install
> > >>>  How did you verify the CPU usage of your MPI pgm?
> > >>>>... With the Windows Task Manager
> > 	How many MPI processes did you launch for your MPI job. Try "mpiexec
> > -n 2 cpi.exe" (Using cpi.exe from MPICH2\examples) and let us know the
> > results.
> Results from cpi (In the install directory, windows OS, size 86.016k)
> C:\Program Files\MPICH2\bin>mpiexec -n 2 cpi.exe Enter the number of
> intervals: (0 quits) 1 pi is approximately 3.2000000000000002, Error
> is
> 0.0584073464102071 wall clock time = 0.001599 Enter the number of intervals:
> (0 quits) 2 pi is approximately 3.1623529411764704, Error is
> 0.0207602875866773 wall clock time = 0.000153 Enter the number of intervals:
> (0 quits) 0
> > >>> Pgms compiled under cygwin don't work...
> > 	Please provide us as much details as possible so that we can help
> you
> > with your problem. Try compiling cpi.c in MPICH2\examples from cygwin
> > and let us know if it works.
> Results from cpi (In the cygwin directory compiled, size 571.908k !)
> C:\cygwin\tmp\mpi\mpich2-1.0.6p1\examples>mpiexec -n 2 cpi.exe
> [unset[unset]: unable to decode hostport from ]: unable to decode hostport
> from 3280
> [3287
> [unset]: aborting job:
> Fatal error in MPI_Init: Other MPI error, error stack:
> MPIR_Init_thread(294): Initialization failed
> MPID_Init(82)........: channel initialization failed
> MPID_Init(333).......: PMI_Init returned -1Fatal error in MPI_Init: Other
> MPI er ror, error stack:
> madfran
