[MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
Jayesh Krishna jayesh at mcs.anl.gov
Mon Jan 14 11:27:37 CST 2008
1) You do not need to install mpiexec (you only need to install smpd) to use
it.
2) Try specifying a higher number of iterations (say 1000) when running
cpi.exe.
3) Have you installed the windows version of MPICH2 from the installer ? (Or
have you compiled MPICH2 under cygwin ?)
Jayesh
-----Original Message-----
Sent: Saturday, January 12, 2008 1:06 PM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
Hi,...
>  >>>... execute "smpd.exe -install"."
>  >>>> In my WinXP, dont work.
> 	This should work. Is there any specific error message that you see
> (Is smpd not working the way it is supposed to ?)?
The problem is they are no way to register and validate user/pass because
mpiexec is it not install
> >>>  How did you verify the CPU usage of your MPI pgm?
> >>>>... With the Windows Task Manager
> 	How many MPI processes did you launch for your MPI job. Try "mpiexec
> -n 2 cpi.exe" (Using cpi.exe from MPICH2\examples) and let us know the
> results.
Results from cpi (In the install directory, windows OS, size 86.016k)
C:\Program Files\MPICH2\bin>mpiexec -n 2 cpi.exe Enter the number of
intervals: (0 quits) 1 pi is approximately 3.2000000000000002, Error is
0.0584073464102071 wall clock time = 0.001599 Enter the number of intervals:
(0 quits) 2 pi is approximately 3.1623529411764704, Error is
0.0207602875866773 wall clock time = 0.000153 Enter the number of intervals:
(0 quits) 0
> >>> Pgms compiled under cygwin don't work...
> 	Please provide us as much details as possible so that we can help
you
> with your problem. Try compiling cpi.c in MPICH2\examples from cygwin
> and let us know if it works.
Results from cpi (In the cygwin directory compiled, size 571.908k !)
C:\cygwin\tmp\mpi\mpich2-1.0.6p1\examples>mpiexec -n 2 cpi.exe
[unset[unset]: unable to decode hostport from ]: unable to decode hostport
from 3280
[3287
[unset]: aborting job:
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(294): Initialization failed
MPID_Init(82)........: channel initialization failed
MPID_Init(333).......: PMI_Init returned -1Fatal error in MPI_Init: Other
MPI er ror, error stack:
madfran
