[MPICH] smpd error message on windows - Do you have sufficient privileges ?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Jan 14 13:25:40 CST 2008
 MPICH2 uses this (HKEY_LOCAL_MACHINE\Software\mpich\smpd\process\) registry
entry to store information (like the full path of the executable) pertaining
to an MPI process created by the PM/smpd.
 Check to see if you have sufficient privileges (to access registry entries)
on the machine where you are executing your MPI job.
 Since your program is executing correctly, the error could be during the
cleanup of the registry entries. Please look into the process registry
entries on the machine and let us know if it is clean.
1. Run "regedit.exe"
2. Check the values in HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process  --
This should be clean (no entries) if there are no MPI processes running on
the system. (Also right-click on the process entry and you will know more
about the permissions allocated for the entry)
Jayesh
  _____
Sent: Monday, January 14, 2008 1:03 PM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] smpd error message on windows - Are u using MPICH2 ?
MPICH2 1.0.6
  _____
To: xs_li at hotmail.com
CC: mpich-discuss at mcs.anl.gov
Date: Mon, 14 Jan 2008 11:31:34 -0600
 What is the version of MPICH2 that your are using (Or are you using MPICH)
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Richard Li
Sent: Monday, January 14, 2008 10:00 AM
Subject: [MPICH] smpd error message on windows
I saw the following error message when running our MPICH APP on windows.
"unable to open the HKEY_LOCAL_MACHINE\Software\mpich\smpd\process\3884
registry error 5 acces denied."
While I don't believe that our APP  is affected by the error
message(everything seems to be OK and we get the results we want),
I would like to make sure that nothing is going wrong. Does anyone have any
idea what that error message means and what its
implications are ?
Thanks
Richard
  _____
Share life as it happens with the new Windows Live. Start sharing!
<http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_012008
  _____
Make distant family not so distant with Windows VistaR + Windows LiveT.
Start now!
<http://www.microsoft.com/windows/digitallife/keepintouch.mspx?ocid=TXT_TAGL
M_CPC_VideoChat_distantfamily_012008>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080114/7db03c59/attachment.htm>
