[MPICH] Confused about compiling/using mpich2
    Anthony Chan
    chan at mcs.anl.gov
    Sun Jan 13 01:54:55 CST 2008
This is unrelated to your "make testing" results but since
you explicitly configured MPE support, so I would like to point out
that GNU java, i.e. java-1.5.0-gcj-4.2-1.5.0.0, isn't ready
to run jumpshot (you need either SUN's or IBM's java development kit).
A.Chan
On Sat, 12 Jan 2008, Gaetano Bellanca wrote:
> Dear Rajeev
> this is the (final part) of the output of make testing (I checked this before
> and had similar errors of my simulation code).
> Looking in ./threads/pt2pt/testlist
> Unexpected output in threaded_sr: MPI_Init_thread must return
> MPI_THREAD_MULTIPLE in order for this test to run.
> Program threaded_sr exited without No Errors
> Unexpected output in alltoall: [cli_0]: aborting job:
> Unexpected output in alltoall: application called MPI_Abort(MPI_COMM_WORLD,
> 1) - process 0
> Unexpected output in alltoall: [cli_1]: aborting job:
> 1) - process 1
> Unexpected output in alltoall: This test requires MPI_THREAD_MULTIPLE
> Unexpected output in alltoall: [cli_2]: aborting job:
> 1) - process 2
> Unexpected output in alltoall: rank 1 in job 1417  campi17_4545   caused
> collective abort of all ranks
> Unexpected output in alltoall:   exit status of rank 1: return code 1
> Unexpected output in alltoall: rank 0 in job 1417  campi17_4545   caused
> Unexpected output in alltoall:   exit status of rank 0: killed by signal 9
> Program alltoall exited without No Errors
> Unexpected output in sendselfth: MPI_Init_thread must return
> Program sendselfth exited without No Errors
> The options for configure are:
> ./configure --prefix=/opt/mpich2/1.0.6p1/intel10.1 --enable-cxx --enable-f90
> --enable-fast --enable-traceback --with-mpe --enable-f90modules
> --enable-cache --enable-romio --with-file-system=nfs+ufs+pvfs2
> --with-device=ch3:nemesis --with-pvfs2=/usr/local
> --with-java=/usr/lib/jvm/java-1.5.0-gcj-4.2-1.5.0.0
> Before compiling I set : setenv F90 ifort
> and load the environment for Intel compiler.
> In this linux box (ubuntu server kernel 2.6.22-14)  I have a dual Xeon, quad
> core processors. The MotherBoard has 2 network cards, but only one is used at
> the moment.
> Regards.
> Gaetano
> Gaetano Bellanca - Department of Engineering - University of Ferrara
> Via Saragat, 1 - 44100 - Ferrara - ITALY
> Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
> mailto:gaetano.bellanca at unife.it
